EAGLE User Support (English) How can you add attributes for ALL Parts ?
  • Replies 7 replies
  • Subscribers 190 subscribers
  • Views 2520 views
HI,
I would like to add some GLOBAL ATTRIBUTE's for ALL Parts.
1) Manufacturer
2) Part Number
3) Full Description
4) Cost Each
5) CircuitGroup
etc..
Can this be done?
So far with attributes I have to add the same attribute(s) for each part
separately.
This is a time waster!
Dave M
    Nevermind, I found it. Now what I'm wondering is what is the name of the
    attribute IN THE CODE. How is it coded in EAGLE, so I can access its value
    for my own ulp I am going to make? (well, to be honest I am modifying an
    existing ulp and I have to add that column inside it).
    e14 Contributor over 15 years ago in reply to Morosh
    Hello Maurice,
    where are you supposed to run the ulp from? Inside the desired library?
  • rtzaudio
    rtzaudio over 15 years ago
    On 6/18/2011 8:03 PM, davem wrote:
    HI,
    1) Manufacturer
    2) Part Number
    3) Full Description
    4) Cost Each
    5) CircuitGroup
      etc..
    Can this be done?
    separately.
    See the ULP "set-all-devices-attribute.ulp". I use this for similar
    purposes and it should do what you want. You need to create a SCR file
    that contains the attributes you wish to add/delete also as this is fed
    to this ULP as the input parameters.
    You should also be able to use "run-loop-all-lbr-ulp.ulp" to execute the
    "set-all-devices-attribute.ulp" on all your libraries globally.
    Bob
  • Morosh
    Morosh over 15 years ago
    "davem" <imix@bigpond.net.au> wrote in message
    news:itject$ism$1@cheetah.cadsoft.de...
    HI,
    1) Manufacturer
    2) Part Number
    3) Full Description
    4) Cost Each
    5) CircuitGroup
    etc..
    Can this be done?
    separately.
    Dave M
    check ftp://ftp.cadsoft.de/eagle/userfiles/ulp/add_attrib_lbr.ulp recently
    uploaded
    Maurice
    HI,
    1) Manufacturer
    2) Part Number
    3) Full Description
    4) Cost Each
    5) CircuitGroup
      etc..
    Can this be done?
    separately.
    Dave M
    Hi Dave,
    If you look on www.cadsoftusa.com-> Downloads-> ULPs, I believe the
    attrib-add.ulp should fit the bill. If it's not exactly what you need
    there are two or three other attribute ULPs which you may want to check out.
    hth,
    Jorge Garcia
    HI Olin,
    These "Global" attributes are for the current BOM List ( or PartsList of
    the Project) not for all the parts in the eagle library, But I would what
    them for all my parts in MY Library.
    The idea is that every time I make a new board I make a new BOM and all the
    DATA for purchasing/manufacturing has to be ENTERED in each time, This is a
    very important part of the process.
    During design I wish to "LOCK IN"  info at least as far as Manufacturers
    part numbers, where I can source them, and some kind of way I can
    communicate this info with my suppliers, WITHOUT having to create all this
    on Spreadsheets! I don't want to maintain a separate spreadsheet for this
    Important information, I want it "LOCKED" in with my project,
    I would even like to type in design notes for each part.
    Having said that I would probably want my data to be stored IN MY DATABASE
    of parts ( My Library ) So that when I choose parts, all the info will be
    available in my new design, If I need to create new parts I will do this in
    MyLibrary, But those Default attributes will be there to "Prompt" Me for
    the info,and enter it in once I have firmed up the details of each part.
    I know that pricing changes, But  part of my job is to Cost up the BOM to
    decide if the design if feasible. Make changes and re-cost. This is best
    done in EagleCad as I am making changes, Not a separate spreadsheet.
    The circuit group attribute would be for the BOM , not the library list,
    This is so I can "group" parts ( and data) for separate parts of the
    circuit ( i.e power supply etc)
    Dave M
    davem wrote on Sat, 18 June 2011 20:03
    1) Manufacturer
    2) Part Number
    3) Full Description
    4) Cost Each
    5) CircuitGroup
    etc..
    Can this be done?
    Probably not with your attitude and need for instant gratification.
    However, some of this is possible with a little patience.  I have
    manufacturer, part number, description, and other BOM information
    associated with most parts in my libraries now.  This makes BOM generation
    mostly automatic, which is very nice.
    I don't think putting the cost in the library is a good idea since that
    changes regularly.  Without software that interfaces to various
    distributors and looks up the prices in real time, I don't think this part
    of BOM generation can be automated.
    I have no idea what "CircuitGroup" is supposed to mean.
    Simply adding empty attributes to all parts is pointless, so I don't see
    the value of running a script to add these globally.  It's just as easy to
    add them when you would set the attribute to the proper value later.  I
    have a ULP called ATTR_ALL that creates and sets a attribute for all
    packages and technologies of a device.  That is about as high level as it
    makes sense to set this information globally.  Otherwise there is lots of
    individual information by package and technology which has to be set
    individually once somehow.
    Sometimes using a script can help this process.  It can be useful to run
    the ATTR_ALL ULP just to get the script it creates, then edit it with the
    individual information per package and technology.
    ATTR_ALL and the rest of the attribute and BOM making system are included
    in my Eagle Tools release at http://www.embedinc.com/pic/dload.htm.
