EAGLE User Support (English) Duplicating my *.brd design in the same layout area
  • Replies 11 replies
  • Views 1768 views
I have a layout design that is about 2cm X 2cm.  I am ready to send in
my design for the PCB manufacturer to produce the PCBs.  Although this
is just prototyping, I would to maximize the PCB usage, which is
required by the PCB manufacturer to be of minimum size of 5cm X 5cm.
Basically, I would to make use of the 5cm X 5cm board to have two of my
2cm X 2cm design in it.  The PCB manufacturer won't do it.
So, my only chance is put TWO of my design side by side in the same
layout, that is, same *.brd file.  How would I duplicate the same design
with in the same layout?
Thanks!
    I think what you can do is take your schematic and copy it (group,
    highlight all, click the cut button, click on your parts, click paste,
    click to duplicate everything). When you click back to your schematic,
    you'll have another set of parts there and you can place them exactly like
    the other set.
