EAGLE User Support (English) Duplicating my *.brd design in the same layout area
  • Replies 11 replies
  • Views 1735 views
I have a layout design that is about 2cm X 2cm.  I am ready to send in
my design for the PCB manufacturer to produce the PCBs.  Although this
is just prototyping, I would to maximize the PCB usage, which is
required by the PCB manufacturer to be of minimum size of 5cm X 5cm.
Basically, I would to make use of the 5cm X 5cm board to have two of my
2cm X 2cm design in it.  The PCB manufacturer won't do it.
So, my only chance is put TWO of my design side by side in the same
layout, that is, same *.brd file.  How would I duplicate the same design
with in the same layout?
Thanks!
    Chuck I am interested in getting a copy of the panelization spec you mentioned above.  Could you email me a copy. Thanks.
    On 6/20/2011 10:14 PM, AL wrote:
    On 6/20/2011 12:51 PM, Gary Gofstein wrote:
    >> On 6/20/2011 12:29 PM, AL wrote:
    >>> Thanks, Chuck! I shall attempt your suggestions and will post back
    >>> feedback, so that others can benefits.
    >> Whenever I order boards, especially small boards, they always send me
    >> /lots/ of extras. So maybe, just do nothing image
    Please tell me the vendor image I am using www.seeedstudio.com at
    http://www.seeedstudio.com/depot/fusion-pcb-service-p-835.html?cPath=185
    $10 (US dollars) for 10 double-side 5cm x 5cm PCB boards.
    The problem is that they won't cut for me. Since I will be cutting them,
    I might as well maximize the space usage; otherwise, I can fit my boards
    on a breadboard or the casing. image
    But, I am interesting knowing the vendor you use.
    Thanks.
    s/I can fit/I can't fit
    Thanks.
    them, I might as well maximize the space usage; otherwise, I can fit my
    boards on a breadboard or the casing. image
    Thanks.
    On 06/20/2011 01:30 PM, AL wrote:
    On 6/20/11 6:40 AM, Chuck Huber wrote:
    >> I then draw a .010" copper trace on the top
    >> side around the perimeter of the board.
    Hi Chuck,
    Just one quick question on the above.  Any reason why using the copper
    trace?  I realize it's for marking the boundary of each copy of the
    board, but can I not make the boundary by using tDocument trace/line?
    I was assuming that you'd be making barebones boards - top and bottom
    copper only.  You can put the perimeter trace on any layer you want as
    long as it's visible on the finished product.  tPlace and tNames both
    default to being included in the top screen print.  tDocument would
    work, too, provided you add that layer to the top screen print section
    of your cam job.
    For production boards, I provide my board house with gerber files for a
    single copy of the board.  In a separate document, I instruct them to
    panelize it into a 2x2 array (or what ever is appropriate), and to
    include .400" process rails along two opposite edges.  In that same
    document, I also instruct them to add three fiducial marks along the
    process rails.  The reason for the process rails is to allow automated
    equipment at the assembly house to more efficiently handle the panel,
    and to prevent parts from being moved around by tooling before it goes
    into the reflow oven.  I specify .400" rails (relatively large) so that
    the panel can be handled by hand.
    (The panelization spec is too large for this news group.  I'll send it
    directly to you by email.  If anyone else would like a copy, let me know.)
    For panelization, I prefer to specify tab routing, simply because it's
    easier to break the boards off of the panel.  I found that with the
    v-groove scoring, the boards had to be bent too much to separate them,
    which, as one might expect, would often break the solder joint on SMD
    packages, leading to intermittent failures, and failures over time.  I
    have encountered instances where an SMD resistor actually broke in half,
    and instances where a resistor simply popped off the board.
    The down-side to tab routing is that is costs a little more for the
    additional board area.  The up side is that you have a higher yield and
    are able to avoid some causes of intermittent operation and early
    failure.  I'll go with reliability.
    Once I get the board, I will have cut out the copies.   Any tips of
    which best tool to use?
    Well, if you go the one-up board with tab routes as I described above
    and let the board house array the board for you, all you'll need is a
    pair of wire snips to snip the board out of the panel.  A little sand
    paper or a hand file will knock the stub off the board in no time.
    If, however, you have array'ed the board yourself (per our earlier
    discussion), you can use a band saw or a jig saw to separate the boards,
    then use a hand file or a belt sander to trim the board down to a more
    accurate size.
    I would avoid using any type of scissors, like aircraft snips or sheet
    metal snips.  The shearing force will often delaminate the fiberglass
    layers in the vicinity of the cut, which can result in broken vias (yet
    another problem introducing intermittent operation).
    The key is to avoid bending the board.  A band saw and a belt sander
    have worked well for me.
    Best regards,
        - Chuck
    Hi Chuck,
    Thanks again!
    I'm sure this has been addressed before, but here's how I do it.
    Once I have the board layout for one board correct, I save everything,
    then close the schematic.  I then draw a .010" copper trace on the top
    With all layers turned on, I group the entire board, tag it at the
    origin, then paste copies of it in an array, leaving about .100" spacing
    between each copy in both the X and the Y directions.  To meet the 5cm x
    5cm minimum size, you can produce a 2x2 array with the copies positioned
    so that these size requirements are met.
    Important: Save the board as xxx-Array.brd, so you don't overwrite
    your original design.
    The .100" is wide enough to allow a band saw to cut the individual
    boards out of the array.  I also use a belt sander to sand the board
    down to its original size, using the 10mil trace around each board as a
    guide.
    Enjoy,
         - Chuck
    Thank you very much for your help!  Thanks to Jacob's suggestion as
    well, but duplicating pieces in the schematic is very problematic,
    because all parts are named incrementally, thus, causing board to have
    different part names.  I am giving Chuck's suggestion a go.
    guide.
    Enjoy,
        - Chuck
