EAGLE User Support (English) PDF Creator file not searchable (Eagle 4.16)
  • Replies 16 replies
  • Subscribers 179 subscribers
  • Views 1926 views
Hello Folks,
Font is set to porportional everywhere, not vector. Yet PDF files
generated with PDF Creator are not searchable. Doing the very same thing
in Orcad 16.3, they are searchable.
What gives?
Regards, Joerg
    Hi Joerg,
    try the EAGLE 5.11 freeware with the build in PDF export functionality.
    This should give you really small file sizes together with searchable text.
    Rene
    Former Member over 14 years ago in reply to Former Member
    René König wrote:
    Hi Joerg,
    Thanks, Rene, but I can't do that. I use Eagle as a consultant which the
    freeware doesn't allow. Got to honor the rules. Ok, I could continue
    using 4.16 (is licensed here) and 5.11 only for the occasional PDF
    print. But I guess technically that would already be a license violation
    and the king of Bavaria might send his troops over here image
    I didn't want to upgrade to version 5 because it did not include
    hierarchical schematics. If version 6 does and nothing gets broken I
    plan to upgrade.
    Regards, Joerg
    I'm pretty sure he won't. image
    As far as I understand, it is perfectly fine to use the freeware license
    for generating any kind of output - IMHO this also applies to the PRINT
    command and PDF. IIRC, every board house is also allowed to use the
    freeware for generating gerber files from EAGLE boards.
    However, it might also be an issue with PDF Creator, and/or the way it
    interacts with EAGLE. I am using pdfFactory for many years, and AFAIR
    the PDFs have always been searchable - as long as non-vector fonts were
    used.
    I could try this for you, but not now - you'd have to wait until monday
    when I have access to an older 4.16 installation and the time to test
    that again.
    (In fact, even today I use pdfFactory since it allows me to collect
    several prints into a single PDF file, and besides the files are
    somewhat smaller.)
    Tilmann
    Ok, then I should be able to generated searchable PDFs with Eagle. Would
    be nice to get a blessing by one of the Cadsoft engineers though image
    used.
    PDF Creator doesn't have an issue. When I do the same thing with Orcad
    16.3 I get searchable PDF files, on the same computer.
    that again.
    But only if you've got the time.
    somewhat smaller.)
    That is nice, and I actually need something like that. Another CAD tool
    (Mentor IC Station) appears to have a print engine from around the days
    of the Neanderthal man. It cannot print a whole hierarchy so you must
    spool it off one file at a time and in the ancient postscript format.
    Meaning I'll have to concatenate all that. But I also need an OCR
    program because what comes out of that CAD is not searchable.
    My paperless office software (PaperPort) can concatenate lots of TIFF
    files into one PDF document so that's take care of. OCR is another
    matter. Acrobat didn't do a 100% job (an IC designer friend just tried
    it on a news article) so I'll have to try Nitro, Phantom and some others
    to see what's best.
    Regards, Joerg
    >> used.
    As I said, it might be an issue with the combination of EAGLE and PDF
    Creator.
    >> that again.
    I just had to check something at my laptop - where a 4.16 installation
    resides. Printed a schematic to pdfFactory and got a searchable PDF file.
    >> somewhat smaller.)
    I can strongly recommend FinePrinter as well as pdfFactory. They are
    really affordable, and worth every cent.
    Tilmann
    >>> used.
    Creator.
    >>> that again.
    Thanks, interesting. So it seems PDF Creator and Eagle really don't like
    each other much. I wonder why.
    >>> somewhat smaller.)
    In case someone else has similar issues, these programs are here:
    http://fineprint.com/pdf/
    I'll need something with good OCR though because of the issues with this
    other CAD (Mentor IC Station). The PDF format has some quirks. For
    example, some searchable documents created with Adobe Acrobat are not
    well searchable in Foxit. Weird, and not cool because I never know what
    my clients will be using.
    Regards, Joerg
    René König <rk@tbkoenig.de> wrote:
    Hi Joerg,
    One of the 5.x versions also had this problem but it got fixed. Search in
    the old threads for more details.
    In case nothing else works for you, a few years back Juergen Messerer
    posted a .ULP script
    (ftp://ftp.cadsoft.de/eagle/userfiles/ulp/eagle2ps-1.1.ulp) that exports
    eagle files to postscript that you could then convert (using freeware
    ghostscript) to PDF.  A year or so later I stumbled across it and made a
    few updates to it and released it as well
    (ftp://ftp.cadsoft.de/eagle/userfiles/ulp/eagle2ps_v2.1.ulp).
    It's a few more steps, but before searchable PDF generation (v5), Juergen's
    and my script worked wonders here at my company, and since being downloaded
    almost 4,000 times since I can only hope that it has helped others as
    well.
    As I mentioned, it's a bit more involved as you need to also install
    Ghostscript (a two part package as I recall, GhostGum as GhostView or
    something like that), run the .ULP to generate a .ps file, an then open
    with GhostView and "converttoPDF" and save as PDF. But it gets the job
    done. The default parameters hopefully should work just fine.
    good luck,
    .dane
    well.
    Interesting. Coincidentally I just installed Ghostgum because another
    (huge) CAD software for IC design has even more problems. The issue is,
    while I can convert PS to PDF neither file is searchable. Meaning if a
    transistor designator is M17 and you search for "M17" it will not find it.
    Regards, Joerg
    The whole problem with "printing" to PDF with Eagle v4 is that it prints
    everything as line segments. So printing to a PDF generator still just
    prints line segments. At least that is what I found.
    The script that I referenced above is not something you "print" to but
    rather a user script that you "run" that generates a postscript file from
    your schematic file. The .ULP user script then processes through text as
    text and exports to postscript as text, which ghostgum can then convert to
    text PDF. Line segments are still line segments, but text is text.
    Since you already have ghostgum installed, give the script a shot and let
    me know how you get along with it.
    You can email me at dane dot ulp at lewisinnovative dot com for help with
    the script.
    cheers,
    .dane
