EAGLE User Support (English) Determine OS from within ULP
  • Replies 13 replies
  • Subscribers 178 subscribers
  • Views 1149 views
Greetings
I'm developing my first ULP that needs to react differently depending on the
operating system.
What is considered the preferred method of determining the Operating System
from within a ULP?
Any advice appreciated.
Warren
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:iudv2t$ucs$1@cheetah.cadsoft.de...
    Greetings
    the
    operating system.
    System
    from within a ULP?
    I'd say use the system() function to try executing "ver" for windows..
    "uname " or "lsb_release -a" for linux.. And something similar for
    mac?
    Not a good solution tho.
    Former Member over 14 years ago in reply to Former Member
    Morten Leikvoll wrote on Wed, 29 June 2011 05:51
    "Warren Brayshaw" <<private_email>> wrote in message
    news:iudv2t$ucs$<private_email>...
    Greetings
    depending on
    the
    operating system.
    Operating
    System
    from within a ULP?
    for
    mac?
    I looked into something like this about a year ago for the same reason.
    From memory, I believe the ver command was the way I did it.  In Windows
    you get back an error message and Mac and Linux give you something you can
    parse.  I had to pipe it to a file and then search the file.  Ugly, but it
    did work.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Am 29.06.2011 16:28, schrieb James Morrison:
    did work.
    Everything executed via the 'system' command has the problem that it at
    least flashes the DOS shell window (when run under Windows), which is a
    nuisance. If you're only interested in knowing the difference between
    Windows and anything else, do it as follows:
    int IsWindows() {
       //Returns 1, if EAGLE is running under Windows (0 for Linux/Mac)
       if ((strsub(argv[0],0,1)=="/") && (strsub(argv[0],0,2)!="//"))
         return 0;
       return 1;
    This does NOT call any external program and, for our institute, works
    reliably since years. But, yes, I AM interested in getting to know how
    to reliably tell the difference between a Mac and Linux...
    Andreas Weidner
    >>  reason. From memory, I believe the ver command was the way I did
    >> it.  In Windows you get back an error message and Mac and Linux give
    >> you something you can parse.  I had to pipe it to a file and then
    >> search the file.  Ugly, but it did work.
    at least flashes the DOS shell window (when run under Windows), which
    is a nuisance. If you're only interested in knowing the difference
    between Windows and anything else, do it as follows:
    int IsWindows() {
         return 0;
       return 1;
    Andreas Weidner
    Thanks for the replies everyone. If there are further methods being used by
    others I would like to here about them.
    My current needs, as I understand them at this point, is to be able to
    determine Windows from the other two. Andreas' solution is elegant.
    Other ideas:
    For those installations where there are two paths in the Eagle
    Options/Directories you could detect the semicolon (Windows) or colon
    (Linux-Mac) in eaglerc.usr
    Detecting eaglerc.usr or .eaglerc may be possible also but gives no more
    than Andreas' solution.
    That said it would be good to determine a technique that does differentiate
    between Linux and Mac.
    Something like detecting a root folder lib (Linux) or Library (Mac)? Or var
    (Linix) vs System (Mac)?
    In a well locked down institution, can a user still detect the presence of
    these folders?
    I have been trying a few ideas via JavaScript or vbs to get past the
    flashing command window and this could be another path to obtaining the OS
    but comes with security issues.
    Would be OK for institutions with a certificate server.
    Right now I'm having an issue with the system() command (I think)  adding
    eagles install path ahead of my path. Yet to solve that one, if its possible
    Regards
    Warren
    Greetings
    the
    operating system.
    System
    from within a ULP?
    May I ask why you need to detect this? Depending on what you try to do,
    there could be alternative solutions..
    do, there could be alternative solutions..
    The need is to provide the correct formatting for the strings passed with
    the system() ULP command and the formatting of batch files created by the
    ULP and used by the OS script processors.
    When the system() command is involved it appears to be most common (easier)
    for a ULP to be crafted solely for use with Windows or Linux/Mac. I wish to
    make a ULP that will work in both environments hence the formatting needs to
    be appropriate for the OS in use.
    Warren
    news:iuhjh9$8o3$1@cheetah.cadsoft.de...
    (easier)
    to
    to
    So I guess a platform dependant batch file that takes the same arguments on
    all platforms could sort the case?
    I guess you can make linux autorun a xxx.bat file (not sure bout mac), and
    windows can for sure.
    I tried creating a file called test.bat on both (set the x flag on linux),
    and I could run them both with "./test.bat" from shell's (I haven't got
    linux eagle install, so you may want to try it)
    >> with the system() ULP command and the formatting of batch files
    >> created by the ULP and used by the OS script processors.
    >> (easier)
    >> wish to
    >> needs to
    arguments on all platforms could sort the case?
    mac), and windows can for sure.
    linux), and I could run them both with "./test.bat" from shell's (I
    haven't got linux eagle install, so you may want to try it)
    Thanks for the input Morten:
    The thread has moved away from my request for methods to detect the
    operating system from within a ULP.
    Further ideas from those with expeience with achieving this would be
    appreciated.
    Warren
    >>> (easier)
    >>> wish to
    >>> needs to
    appreciated.
    Yea I know I branced off the main topic, but when I thought about it a
    couple of times I lean to that the optimal place to do it is outside eagle.
    Sounds cleanest to me in any case.
    >> can
    >> did work.
    int IsWindows() {
    return 0;
    return 1;
    Andreas Weidner
    isn't there a way to run the shell window minimized in windows? i think
    a shortcut that is declared to be minimized and just passes args to
    cmd.exe would do the trick.
    i think it is also possible to run a program in windows completely
    invisibly but it can't be done from the OS interface, you have to hex
    the shortcut file. it's documented but i haven't had much luck with it.
