EAGLE User Support (English) Changes in schematic not visible in Layout ?
  • Views 260 views
I have been using Eagle 5.11 succesfully until today.
One of my designs, a schematic and layout of an audio converter needs to be
modified.
However, if I make changes in the schematic, such as disconnecting
components from nets, it does not change in the Layout.
This is very annoying, the link between the schematic and layout seems to
be gone. Even when Ratsnest is applied in the layout.
What should I do? I do not want to start drawing the 4 layer PCB over
again!
Greetings,
Marc
    Hi
    1) Make certain the sch & brd is in the same directory
    2) You need to manualy rip the tracks (check if new part is added to brd)
