EAGLE User Support (English) VIA in pad for BGA
  • Subscribers 179 subscribers
  • Views 943 views
VIA in pad for BGA
I am trying to route a board with a BGA. The manufacturer recommended
layout method is to use filled vias directly in the BGA pad. I am
attempting to place a via directly coincident with the BGA pad (using
the ROUTE command and mouse) I get the error: "Can't set via to layer
'16' at (x y)"
Where x and y are of course the actual dimensions.
My DRC settings are 0mil for any vias and smds and pads of the same signal.
I'll try to illustrate this with the attached PNG files if allowed, or
you can see the images at this link: http://imgur.com/a/BgPqU
I appreciate any help.
Martin Klingensmith
    "Martin Klingensmith" <martin@nnytech.net> wrote in message
    news:j04ve8$bik$1@cheetah.cadsoft.de...
    '16' at (x y)"
    I guess Eagle doesnt allow vias on pad, but you can get around it by routing
    just a tiny wire out from the center of the pad before you change layer.
    After that you can move the via back to the pad. You will get an overlap DRC
    error, but you can choose to approve it.
    (also read http://blog.screamingcircuits.com/via_in_pad/ )
  • Richard_H
    Richard_H over 14 years ago
    Am 20.07.2011 00:11, schrieb Martin Klingensmith:
    '16' at (x y)"
    Martin Klingensmith
    I suppose it is a matter of Layer Setup. Could you check the settings
    in the Design Rules? What is the Layer Setup there?
    Richard Hammerl
