EAGLE User Support (English) How do you set the width of a dlgListVi ew Column?
  • Subscribers 180 subscribers
  • Views 247 views
I have just started learning to understand ULP Scripting!
I am trying to modify the BOM.ULP script for better functionality.
One of the columns ("Parts") shows the designators side by side and this
column can be very wide if you have a lot of designators. ( Assuming the
"ListType" is selected as "Values")
Q1) What I want to do is limit the width after the list is loaded so I can
see all the columns in the dialog.
The user can still change the width at anytime later ( So they can see all
the values)
Also,
Q2) Is there a better editor that the one built in, one that recognises
eagle code? and formats it as such?
    Does anyone now about this?
    Dave M
  • Richard_H
    Richard_H over 14 years ago in reply to Former Member
    Am 26.07.2011 02:24, schrieb davem:
    Dave M
    it is not possible to define a certain width for dlgListView, but
    you can define the width for dlgVboxLayout by using dlgSpacing.
    ListView used in this context will follow the width of the BoxLayout.
    HTH
    Richard Hammerl
