EAGLE User Support (English) Useful keyboard shortcuts
  • Replies 24 replies
  • Subscribers 190 subscribers
  • Views 14887 views
As stated before, EAGLE's work flow can be speeded up quite a lot by
using a combination of BOTH mouse clicks and keyboard usage. Using the
predefined menu shortcuts that require TWO key strokes is one
possibility, defining your OWN keyboard shortcuts is yet ANOTHER one,
which then only need ONE key stroke.
Of course this DOES require some time for the setup, but you save
THOUSANDS of key strokes later. Please find below a (rather long)
collection of the keyboard commands used in our institute. Lots of
people may find the function keys disagreeable because they are NOT the
CadSoft ones, but of course you can easily throw them away. The control
key combinations more or less always use the first character of the
corresponding command and therefore should be easy to memorise.
The ULPs used are (with the exception of 'designlink') NOT the ones from
CadSoft, but selfmade ones.
This of course is only an EXAMPLE. It works VERY well with us, but other
people might find this objectionable. Feel free to use it, take some
ideas from it or just ignore it, but please don't condemn me for it -
it's just not worth bickering over...
Andreas Weidner
Excerpts from 'eagle.scr' (some longish lines MIGHT be broken in two by
my newsclient):
SCH:
  1. Define schematic editor keyboard shortcuts
ASSIGN F2 'WINDOW Fit'
ASSIGN F3 'RUN backward'   #switch to previous sheet
ASSIGN F4 'RUN forward'   #switch to next sheet
ASSIGN F5 'RUN griddisplay'   #switch grid on/off
ASSIGN F6 'RUN gridtype'   #switch grid to dots/lines
ASSIGN F7 'RUN grid20'   #double the current grid
ASSIGN F8 'RUN grid05'   #halfen the current grid
ASSIGN F9 'INFO'
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN F12 'RUN togglecursor'   #make cursor small/large
ASSIGN C+A 'ADD'
ASSIGN CS+A 'ATTRIBUTE'
ASSIGN C+B 'BUS'
ASSIGN C+C 'CUT;'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E 'ERRORS'
ASSIGN CS+E 'ERC'
ASSIGN C+F 'RUN find'   #search for objects
ASSIGN CS+F 'RUN designlink'
ASSIGN C+G 'GROUP'
ASSIGN CS+G 'GROUP All;'
ASSIGN C+H 'CHANGE LAYER Info; CHANGE Size 0.1in; CHANGE Ratio 16;
CHANGE Font Vector; TEXT'   #heading text with predefined parameters
ASSIGN C+I 'INFO'
ASSIGN CS+I 'INVOKE'
ASSIGN C+J 'JUNCTION'
ASSIGN C+K ''
ASSIGN C+L 'CHANGE Size 0.05in; CHANGE Ratio 8; CHANGE Font Vector;
CHANGE Xref Off; LABEL'   #label with predefined parameters
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N 'NET'
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN'
ASSIGN C+P 'PASTE'
ASSIGN CS+P 'CHANGE Package'
ASSIGN C+Q ''
ASSIGN C+R ''
ASSIGN CS+R ''
ASSIGN C+S 'WRITE;'
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'CHANGE LAYER Info; CHANGE Size 0.06in; CHANGE Ratio 8;
CHANGE Font Vector; TEXT'   #text with predefined parameters
ASSIGN CS+T 'CHANGE Technology'
ASSIGN C+U 'UPDATE;'
ASSIGN C+V 'VALUE'
ASSIGN CS+V ''
ASSIGN C+W 'WIRE'
ASSIGN CS+W 'WINDOW'
ASSIGN C+X 'CHANGE Size 0.05in; CHANGE Ratio 8; CHANGE Font Vector;
LABEL Xref'   #cross reference with predefined parameters
ASSIGN C+Y 'REDO'
ASSIGN CS+Y 'RUN redo'   #choose more than one action to redo
ASSIGN C+Z 'UNDO'
ASSIGN CS+Z 'RUN undo'   #choose more than one action to undo
BRD:
  1. Define board editor keyboard shortcuts
ASSIGN F3 'WINDOW Last'
ASSIGN F4 'RATSNEST'
ASSIGN F9 'INFO'
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN C+A 'ADD'
ASSIGN C+B ''
ASSIGN C+C 'CUT;'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E 'ERRORS'
ASSIGN CS+E 'ERC'
ASSIGN C+G 'GROUP'
ASSIGN C+H 'HOLE'
ASSIGN C+I 'INFO'
ASSIGN CS+I ''
ASSIGN C+J ''
ASSIGN C+K ''
ASSIGN C+L 'LOCK'
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N 'SIGNAL'
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN'
ASSIGN C+P 'PASTE'
ASSIGN C+Q ''
ASSIGN C+R 'MITER 0; ROUTE'
ASSIGN CS+R 'RIPUP'
ASSIGN C+S 'WRITE;'
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'CHANGE Font Vector; CHANGE Ratio 16; CHANGE Size 0.05inch;
ASSIGN C+V 'VALUE'
ASSIGN CS+V 'VIA'
ASSIGN C+W 'WIRE'
ASSIGN C+X 'CHANGE Package'
ASSIGN C+Y 'REDO'
ASSIGN C+Z 'UNDO'
LBR:
  1. Define library editor keyboard shortcuts
ASSIGN F2 '';
ASSIGN F3 '';
ASSIGN F4 '';
ASSIGN F9 'INFO';
ASSIGN F10 'UNDO';
ASSIGN F11 'REDO'
DEV:
  1. Define device editor keyboard shortcuts
ASSIGN F2 'WINDOW Fit';
ASSIGN F3 'RUN backward'   #switch to previous device
ASSIGN F4 'RUN forward'   #switch to next device
ASSIGN F9 'INFO'
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN C+A 'ADD'
ASSIGN C+B ''
ASSIGN C+C 'CONNECT'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E ''
ASSIGN CS+E ''
ASSIGN C+F ''
ASSIGN C+G 'GROUP'
ASSIGN C+H ''
ASSIGN C+I 'INFO'
ASSIGN CS+I ''
ASSIGN C+J ''
ASSIGN C+K ''
ASSIGN C+L 'LAYER'
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N 'PACKAGE'
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN;'
ASSIGN C+P 'PREFIX'
ASSIGN CS+P ''
ASSIGN C+Q ''
ASSIGN C+R ''
ASSIGN CS+R ''
ASSIGN C+S 'RUN savelib'   #show default layers, save library, restore
layers
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'TEXT'
ASSIGN CS+T ''
ASSIGN C+U ''
ASSIGN C+V 'VALUE'
ASSIGN CS+V ''
ASSIGN C+W 'WIRE'
ASSIGN C+X ''
ASSIGN C+Y 'REDO'
ASSIGN C+Z 'UNDO'
SYM:
  1. Define symbol editor keyboard shortcuts
ASSIGN F3 'RUN backward'   #switch to previous symbol
ASSIGN F4 'RUN forward'   #switch to next symbol
ASSIGN F9 'INFO'
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN C+A ''
ASSIGN CS+A ''
ASSIGN C+B ''
ASSIGN C+C 'CUT;'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E ''
ASSIGN CS+E ''
ASSIGN C+G 'GROUP'
ASSIGN C+H ''
ASSIGN C+I 'INFO'
ASSIGN CS+I ''
ASSIGN C+J ''
ASSIGN C+K ''
ASSIGN C+L 'LAYER'
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N ''
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN'
ASSIGN C+P 'PASTE'
ASSIGN CS+P ''
ASSIGN C+Q ''
ASSIGN C+R ''
ASSIGN CS+R ''
layers
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'TEXT'
ASSIGN CS+T ''
ASSIGN C+U ''
ASSIGN C+V ''
ASSIGN CS+V ''
ASSIGN C+W 'WIRE'
ASSIGN C+X ''
ASSIGN C+Y 'REDO'
ASSIGN C+Z 'UNDO'
PAC:
  1. Define package editor keyboard shortcuts
ASSIGN F3 'RUN backward'   #switch to previous package
ASSIGN F4 'RUN forward'   #switch to next package
ASSIGN F9 'INFO';
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN C+A ''
ASSIGN CS+A ''
ASSIGN C+B ''
ASSIGN C+C 'CUT;'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E ''
ASSIGN CS+E ''
ASSIGN C+G 'GROUP'
ASSIGN C+H 'HOLE'
ASSIGN C+I 'INFO'
ASSIGN CS+I ''
ASSIGN C+J ''
ASSIGN C+K ''
ASSIGN C+L 'LAYER'
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N ''
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN'
ASSIGN C+P 'PASTE'
ASSIGN CS+P ''
ASSIGN C+Q ''
ASSIGN C+R ''
ASSIGN CS+R ''
layers
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'TEXT'
ASSIGN CS+T ''
ASSIGN C+U ''
ASSIGN C+V ''
ASSIGN CS+V ''
ASSIGN C+W 'WIRE'
ASSIGN C+X ''
ASSIGN C+Y 'REDO'
ASSIGN C+Z 'UNDO'
  • ylongo
    ylongo over 7 years ago
    This guy adapted this hotkeys for 9.2.2
    https://github.com/plasmoid/eagle_hotkeys
    Robert Pearce wrote on Fri, 29 July 2011 05:54
    On Thu, 28 Jul 2011, Joern Paschedag wrote to us saying :
    >Hi Dave,
    >you don't like the way Olin is thinking but you are not better.
    >You even don't really know eagle but want everything changed, because
    >it is not working your way.
    >You write long letters about what you have done in your business
    life,
    >but to me it looks like you havn't learned a damn thing from it.
    >So PLEASE stop beeing the all-round entertainer here.
    Thank you Joern, for a well considered and extremely polite post. Olin
    may be abrasive but he's quite often right. And he's experienced.
    Dave: take note.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    To Rob ,Joern
    What should I "take note" off?
    The fact that Joern said "i have learned NOTHING in my business life"? how
    the hell do you know such things?
    The fact that Olin said I am a "bad engineer" and that I am using the
    "wrong computer"?
    you guys are the ones putting personal insults into comments just because
    you do not want to listen to other peoples ideas and incase cadsoft makes a
    change and "breaks" your way of working,
    All the suggestions I have made would implement changes but would not
    effect the current way of doing things ( unless I have said otherwise) , so
    that means that it would not effect YOUR workflow. but especially for new
    users ( and existing) it would be easier.
    If someone here ( or any forum) attacks me personally , be prepared to cop
    it back and allow me to defend myself. even if that includes a small
    history of my working life.
    Dave M
    >Hi Dave,
    life,
    Dave: take note.
    this message are    |
    Don't believe a     |
    word.               |
    To Rob ,Joern
    "wrong computer"?
    Dave M
    Hi Jorge,
    I have figured out how the the ULP scripting language does this. I have
    done a LOT OF READING in the last week on the scripting language. ( not
    much PCB design work got done though!)
    I have managed to get the updating of some ATTRIBUTES working with just a
    few lines of code.
    So Thanks,
    Anyhow this topic has gone of the original topic, of keyboard shortcuts.
    I will make separate posts in support forum about the Scripting language,
    so far its looks pretty easy.
    Dave M
    On 7/27/2011 6:50 PM, davem wrote:
    Jorge Garcia wrote on Thu, 28 July 2011 04:21
    >> Maybe you know this already, perhaps you don't, but all of the
    >> data accessed by a ULP is read-only. A ULP on it's own cannot change
    >> anything. In order to make any changes a ULP is setup to write a script
    >> which is a list of command line entries which EAGLE executes one by one
    >> upon the ULP's exit.
    HI Jorge, I did not know that, I am still reading and trying out things
    with the scripting language, I can write code ( other languages) so I am
    not worried about it.
    I am still trying to work out the structure/program flow of a script.
    So you are saying that I can only READ Data with a ULP, But I Can CHANGE
    Data only when the script finishes?
    So If I wanted to say, change the grid colour, I could read the current
    value, display it, then write the value, but if I wanted to say have an
    APPLY Button in my dialog, I would not see the change until the dialog
    closes?
    I would like to now more about this..
    Dave M
    Hi Dave,
    Using you're example, I think this will become clear. Olin's explanation
    is spot on so I won't repeat it.
    The ULP would read the current value. Based on whatever algorithm you
    coded the ULP will determine what value the grid color should be.
    It will then dynamically write a script file which contains the command
    line statements necessary to change the grid color. Once the ULP is done
    creating the script file it will exit. If you look in the ULP
    documentation you'll see that there is a built-in function called exit().
    Once the ULP runs this exit() function is will close sending whatever
    command was inside the parentheses to the command line to be run. That
    one command is usually a call to the script which then executes the changes.
    As you can see, the ULP can read parameters from the various editors and
    determine what changes need to be made. In order to actually make the
    changes the ULP will write a script which will be called once the ULP
    exits. The script takes care of actually making the changes.
    If you would like to see a simple example see the, ex-run-script.ulp
    included with EAGLE.
    hth,
    Jorge Garcia
    Cadsoft Support
    davem wrote on Wed, 27 July 2011 18:50
    Yes, although a ULP can run a script upon exit.
    Quote:
    But I Can CHANGE Data only when the script finishes?
    No.  A script can change data.
    This is all in the documentation, of course.  Read the help section on ULPs
    for details.
    closes?
    Dave M
    Hi Dave,
    hth,
    Jorge Garcia
    Cadsoft Support
    >Hi Dave,
    >You write long letters about what you have done in your business life,
    Dave: take note.
    this message are    |
    Don't believe a     |
    word.               |
    Am 27.07.2011 01:44, schrieb davem:
    Olin said - "Third, the command line is a essential and important part of
    Eagle."
    I really don't think so.
    I have just nearly completed a project schematic/board over the last 3
    months, with a lot of stuff on it, WITHOUT EVER USING THE COMMAND LINE!
    I am not saying at all get rid of it, no way, but its not the "be all" and
    "end all" feature that Olin makes it out to be, its just another (old
    fashioned) way of doing things.
    One thing a command line system requires is REMEMBERING EVERYTHING, Single
    keys like "M" for move, "T" for Top Layer etc are very easy to "remember"
    and as stated by most we only need a handful of common tasks, but not
    everything,
    Command line control is NOT INTUITIVE for NEW USERS and TURNS NEW USERS
    AWAY!!!!
    Dave M
    Hi Dave,
    You even don't really know eagle but want everything changed, because it
    Joern Paschedag
    you can save time using it.
    I disagree, a good mnemonic is better to memorize than a single
    letter.
    Although I'm not that fanatic as Stephenson, I'm convinced that a
    command line is extremly useful.
    These days, many people are no more willing to learn, though.
    Oliver
