EAGLE User Support (English) Useful keyboard shortcuts
  • Replies 24 replies
  • Subscribers 182 subscribers
  • Views 13664 views
As stated before, EAGLE's work flow can be speeded up quite a lot by
using a combination of BOTH mouse clicks and keyboard usage. Using the
predefined menu shortcuts that require TWO key strokes is one
possibility, defining your OWN keyboard shortcuts is yet ANOTHER one,
which then only need ONE key stroke.
Of course this DOES require some time for the setup, but you save
THOUSANDS of key strokes later. Please find below a (rather long)
collection of the keyboard commands used in our institute. Lots of
people may find the function keys disagreeable because they are NOT the
CadSoft ones, but of course you can easily throw them away. The control
key combinations more or less always use the first character of the
corresponding command and therefore should be easy to memorise.
The ULPs used are (with the exception of 'designlink') NOT the ones from
CadSoft, but selfmade ones.
This of course is only an EXAMPLE. It works VERY well with us, but other
people might find this objectionable. Feel free to use it, take some
ideas from it or just ignore it, but please don't condemn me for it -
it's just not worth bickering over...
Andreas Weidner
Excerpts from 'eagle.scr' (some longish lines MIGHT be broken in two by
my newsclient):
SCH:
  1. Define schematic editor keyboard shortcuts
ASSIGN F2 'WINDOW Fit'
ASSIGN F3 'RUN backward'   #switch to previous sheet
ASSIGN F4 'RUN forward'   #switch to next sheet
ASSIGN F5 'RUN griddisplay'   #switch grid on/off
ASSIGN F6 'RUN gridtype'   #switch grid to dots/lines
ASSIGN F7 'RUN grid20'   #double the current grid
ASSIGN F8 'RUN grid05'   #halfen the current grid
ASSIGN F9 'INFO'
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN F12 'RUN togglecursor'   #make cursor small/large
ASSIGN C+A 'ADD'
ASSIGN CS+A 'ATTRIBUTE'
ASSIGN C+B 'BUS'
ASSIGN C+C 'CUT;'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E 'ERRORS'
ASSIGN CS+E 'ERC'
ASSIGN C+F 'RUN find'   #search for objects
ASSIGN CS+F 'RUN designlink'
ASSIGN C+G 'GROUP'
ASSIGN CS+G 'GROUP All;'
ASSIGN C+H 'CHANGE LAYER Info; CHANGE Size 0.1in; CHANGE Ratio 16;
CHANGE Font Vector; TEXT'   #heading text with predefined parameters
ASSIGN C+I 'INFO'
ASSIGN CS+I 'INVOKE'
ASSIGN C+J 'JUNCTION'
ASSIGN C+K ''
ASSIGN C+L 'CHANGE Size 0.05in; CHANGE Ratio 8; CHANGE Font Vector;
CHANGE Xref Off; LABEL'   #label with predefined parameters
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N 'NET'
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN'
ASSIGN C+P 'PASTE'
ASSIGN CS+P 'CHANGE Package'
ASSIGN C+Q ''
ASSIGN C+R ''
ASSIGN CS+R ''
ASSIGN C+S 'WRITE;'
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'CHANGE LAYER Info; CHANGE Size 0.06in; CHANGE Ratio 8;
CHANGE Font Vector; TEXT'   #text with predefined parameters
ASSIGN CS+T 'CHANGE Technology'
ASSIGN C+U 'UPDATE;'
ASSIGN C+V 'VALUE'
ASSIGN CS+V ''
ASSIGN C+W 'WIRE'
ASSIGN CS+W 'WINDOW'
ASSIGN C+X 'CHANGE Size 0.05in; CHANGE Ratio 8; CHANGE Font Vector;
LABEL Xref'   #cross reference with predefined parameters
ASSIGN C+Y 'REDO'
ASSIGN CS+Y 'RUN redo'   #choose more than one action to redo
ASSIGN C+Z 'UNDO'
ASSIGN CS+Z 'RUN undo'   #choose more than one action to undo
BRD:
  1. Define board editor keyboard shortcuts
ASSIGN F3 'WINDOW Last'
ASSIGN F4 'RATSNEST'
ASSIGN F9 'INFO'
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN C+A 'ADD'
ASSIGN C+B ''
ASSIGN C+C 'CUT;'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E 'ERRORS'
ASSIGN CS+E 'ERC'
ASSIGN C+G 'GROUP'
ASSIGN C+H 'HOLE'
ASSIGN C+I 'INFO'
ASSIGN CS+I ''
ASSIGN C+J ''
ASSIGN C+K ''
ASSIGN C+L 'LOCK'
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N 'SIGNAL'
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN'
ASSIGN C+P 'PASTE'
ASSIGN C+Q ''
ASSIGN C+R 'MITER 0; ROUTE'
ASSIGN CS+R 'RIPUP'
ASSIGN C+S 'WRITE;'
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'CHANGE Font Vector; CHANGE Ratio 16; CHANGE Size 0.05inch;
ASSIGN C+V 'VALUE'
ASSIGN CS+V 'VIA'
ASSIGN C+W 'WIRE'
ASSIGN C+X 'CHANGE Package'
ASSIGN C+Y 'REDO'
ASSIGN C+Z 'UNDO'
LBR:
  1. Define library editor keyboard shortcuts
ASSIGN F2 '';
ASSIGN F3 '';
ASSIGN F4 '';
ASSIGN F9 'INFO';
ASSIGN F10 'UNDO';
ASSIGN F11 'REDO'
DEV:
  1. Define device editor keyboard shortcuts
ASSIGN F2 'WINDOW Fit';
ASSIGN F3 'RUN backward'   #switch to previous device
ASSIGN F4 'RUN forward'   #switch to next device
ASSIGN F9 'INFO'
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN C+A 'ADD'
ASSIGN C+B ''
ASSIGN C+C 'CONNECT'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E ''
ASSIGN CS+E ''
ASSIGN C+F ''
ASSIGN C+G 'GROUP'
ASSIGN C+H ''
ASSIGN C+I 'INFO'
ASSIGN CS+I ''
ASSIGN C+J ''
ASSIGN C+K ''
ASSIGN C+L 'LAYER'
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N 'PACKAGE'
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN;'
ASSIGN C+P 'PREFIX'
ASSIGN CS+P ''
ASSIGN C+Q ''
ASSIGN C+R ''
ASSIGN CS+R ''
ASSIGN C+S 'RUN savelib'   #show default layers, save library, restore
layers
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'TEXT'
ASSIGN CS+T ''
ASSIGN C+U ''
ASSIGN C+V 'VALUE'
ASSIGN CS+V ''
ASSIGN C+W 'WIRE'
ASSIGN C+X ''
ASSIGN C+Y 'REDO'
ASSIGN C+Z 'UNDO'
SYM:
  1. Define symbol editor keyboard shortcuts
ASSIGN F3 'RUN backward'   #switch to previous symbol
ASSIGN F4 'RUN forward'   #switch to next symbol
ASSIGN F9 'INFO'
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN C+A ''
ASSIGN CS+A ''
ASSIGN C+B ''
ASSIGN C+C 'CUT;'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E ''
ASSIGN CS+E ''
ASSIGN C+G 'GROUP'
ASSIGN C+H ''
ASSIGN C+I 'INFO'
ASSIGN CS+I ''
ASSIGN C+J ''
ASSIGN C+K ''
ASSIGN C+L 'LAYER'
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N ''
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN'
ASSIGN C+P 'PASTE'
ASSIGN CS+P ''
ASSIGN C+Q ''
ASSIGN C+R ''
ASSIGN CS+R ''
layers
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'TEXT'
ASSIGN CS+T ''
ASSIGN C+U ''
ASSIGN C+V ''
ASSIGN CS+V ''
ASSIGN C+W 'WIRE'
ASSIGN C+X ''
ASSIGN C+Y 'REDO'
ASSIGN C+Z 'UNDO'
PAC:
  1. Define package editor keyboard shortcuts
ASSIGN F3 'RUN backward'   #switch to previous package
ASSIGN F4 'RUN forward'   #switch to next package
ASSIGN F9 'INFO';
ASSIGN F10 'UNDO'
ASSIGN F11 'REDO'
ASSIGN C+A ''
ASSIGN CS+A ''
ASSIGN C+B ''
ASSIGN C+C 'CUT;'
ASSIGN CS+C 'COPY'
ASSIGN C+D 'DELETE'
ASSIGN C+E ''
ASSIGN CS+E ''
ASSIGN C+G 'GROUP'
ASSIGN C+H 'HOLE'
ASSIGN C+I 'INFO'
ASSIGN CS+I ''
ASSIGN C+J ''
ASSIGN C+K ''
ASSIGN C+L 'LAYER'
ASSIGN C+M 'MOVE'
ASSIGN CS+M 'MARK'
ASSIGN C+N ''
ASSIGN CS+N 'NAME'
ASSIGN C+O 'OPEN'
ASSIGN C+P 'PASTE'
ASSIGN CS+P ''
ASSIGN C+Q ''
ASSIGN C+R ''
ASSIGN CS+R ''
layers
ASSIGN CS+S 'SPLIT'
ASSIGN C+T 'TEXT'
ASSIGN CS+T ''
ASSIGN C+U ''
ASSIGN C+V ''
ASSIGN CS+V ''
ASSIGN C+W 'WIRE'
ASSIGN C+X ''
ASSIGN C+Y 'REDO'
ASSIGN C+Z 'UNDO'
    On 7/26/2011 7:44 PM, davem wrote:
    Olin said - "Third, the command line is a essential and important part of
    Eagle."
    I really don't think so.
    I have just nearly completed a project schematic/board over the last 3
    months, with a lot of stuff on it, WITHOUT EVER USING THE COMMAND LINE!
    I am not saying at all get rid of it, no way, but its not the "be all" and
    "end all" feature that Olin makes it out to be, its just another (old
    fashioned) way of doing things.
    One thing a command line system requires is REMEMBERING EVERYTHING, Single
    keys like "M" for move, "T" for Top Layer etc are very easy to "remember"
    and as stated by most we only need a handful of common tasks, but not
    everything,
    Command line control is NOT INTUITIVE for NEW USERS and TURNS NEW USERS
    AWAY!!!!
    Dave M
    Hi Dave,
    I thought I would chime in before things get out of control. The idea
    behind EAGLE has always been to give user's options. If you look in the
    transition from version 4 to version 5 several changes to the user
    interface and workflow where made. In order to not upset our veteran
    users hooks where included in EAGLE's internal setup files so that users
    could have EAGLE behave the way it did in version 4.
    Any major changes we've ever made in the interface have always given the
    option to the user to return to an older setup and that trend continues
    till today.
    The command line is not a relic, AutoCAD last time I checked still has a
    command line because some people find it easier or faster to use. I
    noticed in your other posts that your working on learning the ULP
    language. Maybe you know this already, perhaps you don't, but all of the
    data accessed by a ULP is read-only. A ULP on it's own cannot change
    anything. In order to make any changes a ULP is setup to write a script
    which is a list of command line entries which EAGLE executes one by one
    upon the ULP's exit.
    In short, use whatever you feel most comfortable with, your suggestion
    is reasonable and if implemented we will give the users who don't like
    to work that way the option to disable it.
    hth,
    Jorge Garcia
    P.S Don't mind Olin's attitude too much, that's the way he is we can't
    change it. Glean what's useful to you from his comments and disregard
    the rest if you are so inclined.
    Jorge Garcia wrote on Thu, 28 July 2011 04:21
    HI Jorge, I did not know that, I am still reading and trying out things
    with the scripting language, I can write code ( other languages) so I am
    not worried about it.
    I am still trying to work out the structure/program flow of a script.
    So you are saying that I can only READ Data with a ULP, But I Can CHANGE
    Data only when the script finishes?
    So If I wanted to say, change the grid colour, I could read the current
    value, display it, then write the value, but if I wanted to say have an
    APPLY Button in my dialog, I would not see the change until the dialog
    closes?
    I would like to now more about this..
    Dave M
    davem wrote on Wed, 27 July 2011 18:50
    Yes, although a ULP can run a script upon exit.
    Quote:
    But I Can CHANGE Data only when the script finishes?
    No.  A script can change data.
    This is all in the documentation, of course.  Read the help section on ULPs
    for details.
    I recently just started using Eagle, so please excuse me if my recomendation is off base from the norm.
    In the past, I used drawing tools like Illustrator which have a nice array of confusing shortcuts which require a lot of time to master; but at the same time there are a lot of tools that you will need for one drawing.
    With Eagle, and other cad tools, there are really only a handfull that I've found necessary.  Any good modern keyboard will have macro support.  I know that the Logitechs have this, as well as some of the gaming keyboards (don't be turned off by the gaming name, these peripherials are often the best on the market for general use too).  After a few days of laying out a board I had a good feal for my most used commands (move, rip, route, ratsnest, and group), and set them to the macro buttons so they are entered in the command line for me.  Anything else and the abreviated forms of the commands are fast enough (del for delete, and i for info).
    I feal that less is more in this case, and a hundred shortcuts to remember will just slow down the workflow.
    Am 27.07.2011 01:44, schrieb davem:
    Eagle."
    everything,
    AWAY!!!!
    Dave M
    Hi Dave,
    you don't like the way Olin is thinking but you are not better.
    You even don't really know eagle but want everything changed, because it
    is not working your way.
    You write long letters about what you have done in your business life,
    but to me it looks like you havn't learned a damn thing from it.
    So PLEASE stop beeing the all-round entertainer here.
    Joern Paschedag
    Former Member over 14 years ago in reply to Former Member
    you can save time using it.
    I disagree, a good mnemonic is better to memorize than a single
    letter.
    Although I'm not that fanatic as Stephenson, I'm convinced that a
    command line is extremly useful.
    These days, many people are no more willing to learn, though.
    Oliver
    On Thu, 28 Jul 2011, Joern Paschedag wrote to us saying :
    >Hi Dave,
    >it is not working your way.
    Thank you Joern, for a well considered and extremely polite post. Olin
    may be abrasive but he's quite often right. And he's experienced.
    Dave: take note.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    closes?
    Dave M
    Hi Dave,
    Using you're example, I think this will become clear. Olin's explanation
    is spot on so I won't repeat it.
    The ULP would read the current value. Based on whatever algorithm you
    coded the ULP will determine what value the grid color should be.
    It will then dynamically write a script file which contains the command
    line statements necessary to change the grid color. Once the ULP is done
    creating the script file it will exit. If you look in the ULP
    documentation you'll see that there is a built-in function called exit().
    Once the ULP runs this exit() function is will close sending whatever
    command was inside the parentheses to the command line to be run. That
    one command is usually a call to the script which then executes the changes.
    As you can see, the ULP can read parameters from the various editors and
    determine what changes need to be made. In order to actually make the
    changes the ULP will write a script which will be called once the ULP
    exits. The script takes care of actually making the changes.
    If you would like to see a simple example see the, ex-run-script.ulp
    included with EAGLE.
    hth,
    Jorge Garcia
    Cadsoft Support
    for details.
    closes?
    Dave M
    Hi Dave,
    hth,
    Jorge Garcia
    Cadsoft Support
