When creating ( for example) labels in dialogs, the text label is always
LEFT aligned.
Can you please somehow provide an option for other Alignments?
This will place the text label NEXT TO an edit field for example.
If you have a few edit fields along horizontally, the label of the next
field is closer to the previous field, looks confusing .
In general, it would be good to have options for text alignment of other
dialog objects where possible, maybe you could use some constants, and
these can be used OPTIONALLY ( so as not to break any existing code) when
defining any dialog object that displays text.
eg alignLeft, alignCentre, alignRight , could be the constants and to use
and an example in use could be..
dlgLabel("Description", alignRight)
also, now that i think about this, it would be nice to have other options
for text such as..
Colour, Styles - Bold, Italic and maybe Fonts
All the default styles would stay as they are, so if no formatting options
are specified, the defaults are use.
What do you think?
Dave M
Dave M
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
