EAGLE User Support (English) EAGLE file formats
  • Subscribers 189 subscribers
  • Views 6617 views
EAGLE file formats
This message is for the Cadsoft staff.
I'm looking to write a library (think libeagle.so) for reading and writing EAGLE files so that open source programs can work with EAGLE's widespread format without the need for silly export/import scripts.  I'm aware of Cadsoft's intent to move to an xml based format but I'm not willing to wait two years for that to happen and would like to be able to access all existing EAGLE files.
I'm requesting information about the internal format of .sch/.brd files.  A header file with struct definitions would suffice but documentation or some source code would be great.  I know it's not a complex format as in an hour with hex editor and some .sch files, I was able to deduce the basic structure for schematics.  It's very crude but it's a start.
If nothing else, it would be nice if you could verify what information is correct:
NOTES:
* file is almost completely composed of 18 byte rows
* rows start with a row type identifier byte
* braces indicate repeatable elements/sections
* format is: hex identifier byte then description
0x10 file_start;
0x11 unknown;
0x12 start_layers;
  0x13 layer;
0x14 end_layers;
  0x15 library_declaration;
  0x17 part_declarations_start; // library name
    0x37 package_list; // base name of packages (part name)
      0x36 declaration; // package name
      0x3C definition_reference;
    0x2D end_package_list; // pin name base
  0x18 part_drawings_start; // library name
    0x1D symbol_start; // drawing
      0x22 draw_shape;
      0x2C pin_name;
      0x31 text_label;
    0x1E package_start; // package name
      0x2A unknown;
      0x2B pad_name;
      0x26 unknown;
      0x22 draw_shape; // repeat
      0x31 text_label; // repeat
  0x19 part_drawings_end
0x1A schematic;
0x38 part_from_library; // part name/value
0x30 part_position; // maybe
=== more stuff here ===
This is a chance to get some good PR for free.
Think it over before posting any kneejerk responses.
    On 8/31/2011 10:56 PM, Gravis wrote:
    Besides, we want to establish the new XML file format as the EAGLE
    > format.
    If you actually want to do that then releasing an open source and read/write library for your new XML format would help you greatly.. Yes, I'm aware of what a DTD spec file is but it doesnt make it less of a pain to make a well written library.
    Supporting an additional interface to the old binary format
    > would pretty much counteract that.
    You aren't going to drop legacy support because it would make a LOT of files people have made unreadable.  I want to be able to read those files just like EAGLE.  Is that really too much to ask?
    The new XML file format is scheduled to be available by the end of this year,
    > so you won't have to wait two years.
    Schedules are great in theory but for all I know this could end up like Duke Nukem Forever.
    > I'm afraid we can't release that source code to the public.
    Can't or won't?  they are VERY differnent things.  I'm certain there is nothing preventing Cadsoft from releasing such information but feel free to tell me why Cadsoft can't.  I do not appreciate being lied to.
    Hi Gravis,
    The new version will still support legacy files.
    Before accusing Klaus of being a liar, it maybe good to look at the fact
    that back in early September of 2009 EAGLE was purchased by Newark.
    Hence, Klaus no longer owns EAGLE nor does have full creative control
    any more.
    I hope that helps clear things up.
    Best Regards,
    Jorge Garcia
    e14 Contributor over 14 years ago in reply to kcadsoft
    format.
  • kcadsoft
    kcadsoft over 14 years ago
    I'm looking to write a library (think libeagle.so) for reading and writing EAGLE files so that open source programs can work with EAGLE's widespread format without the need for silly export/import scripts.  I'm aware of Cadsoft's intent to move to an xml based format but I'm not willing to wait two years for that to happen...
    There will be an "eagle.dtd" file that contains the entire XML format
    description for boards, schematics and libraries.
    format. Supporting an additional interface to the old binary format
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    correct:
    NOTES:
    • file is almost completely composed of 18 byte rows
    • rows start with a row type identifier byte
    • braces indicate repeatable elements/sections
    • format is: hex identifier byte then description
    0x10 file_start;
    Sounds like a good idea, also for design version control and long time
    mantainance needs.
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
