EAGLE User Support (English) Options Assign
  • Subscribers 189 subscribers
  • Views 387 views
Options Assign
Your "Options Assign" looks good on its surface but it has one outstanding
weakness. It is not customizable for the different editor windows.
What might make for a good keyboard shortcut in the schematic editor would
not necessarily be very intuitive in the PCB window. You should make it so
that the user can assign a different meaning to one particular key
combination for the different editor windows.
For instance I might want C+R to be "Route" in the PCB editor but that would
have no meaning in any other editor window. Then if I then wanted C+R to be
and C+R to be "Redo" in the schematic editor, it is not possible with your
current implementation.
    e14 Contributor over 14 years ago in reply to jeromeabcpcb
    My mistake - I see you are correct.
    "Jerome" <jlamy@abc-pcb.com> wrote in message
    news:j3ijel$ukq$1@cheetah.cadsoft.de...
    "Lorenz"  a écrit dans le message de groupe de discussion :
    pfto57tc2l0puhrhbpf8h2qls5f7oequ1p@4ax.com...
    that's not correct.
    eagle stores key assignments for schematic, board & library editors
    separately.
    Lorenz
    For exemple I have set in eagle.scr :
    1.   Defaults for circuit board windows.
    BRD:
    assign C+W route;
    1.   Defaults for schematic windows.
    SCH:
    assign C+W net;
    So that the same key shortcut has a similar behavior (connection) on both
    windows.
    Jerome
    Jerome wrote:
    >Newsgroups: eagle.suggest.eng
    >that's not correct.
    >separately.
    >#   Defaults for circuit board windows.
    >BRD:
    >assign C+W route;
    >#   Defaults for schematic windows.
    >SCH:
    >assign C+W net;
    >windows.
    I've just used your example eagle.scr and it works for me as expected.
    Perhaps there are multiple eagle.scr files on you computer and a
    different one is used than you think?
    Lorenz
  • jeromeabcpcb
    jeromeabcpcb over 14 years ago in reply to e14 Contributor
    that's not correct.
    separately.
    Lorenz
    BRD:
    assign C+W route;
    SCH:
    assign C+W net;
    windows.
    Jerome
    that's not correct.
    separately.
    Lorenz
