EAGLE User Support (English) Decoupling caps
  • Views 450 views
Decoupling caps
I am familiar with decoupling caps. If you look at the schematic at
http://www.sparkfun.com/datasheets/DevT ... o_UART.pdf , you will see
that the decoupling caps are all in one place rather than one for each
power pin, which is what I always do when drawing up schematics, and is
not nice at all. The approach in the above mentioned schematic is really
nice and clean, but I don't quite understand how is that the schematic
is able to match a decoupling cap to each of the power pins.
Thanks for any explanation!
    broken link. image
    Oops...Here is the link
    http://www.sparkfun.com/datasheets/DevTools/XMOS/XS1-Dev-Board-v15_No_UART.pdf
    Am 31.08.2011 00:49, schrieb AL:
    It is easier to read in the schematic, but it's up to the layouter to
    place them properly to the ICs.
    Joern Paschedag
    broken link. image
    It is not, it needs not, and it cannot.
    Placement of parts in schematic resp. board is not related in any way.
    It's your task (and freedom) to place the parts as required, and make
    the proper (short) connections. For the CAD system, only the connections
    to a net is relevant.
    It's common practice to draw decoupling caps as blocks in the schematic,
    though they are spread over the whole board. This normally makes the
    schematic easier to read. In special cases, draw caps "where they belong".
    Tilmann
