EAGLE User Support (English) Solder mask problem
  • Views 844 views
Solder mask problem
In the attached .brd the top solder mask contains a border that's much
larger than the actual board.  While I can't find a way to see the mask in
Eagle 4.16r2, you can get a sense of it by zooming to fit and noticing the
board occupies only the lower left of the screen instead of the whole
screen.  I can see the mask when viewing the .stc (created by the
gerber274x.cam job) in Viewmate.  How can I fix this?  I don't know how to
modify it at all, but I don't even know what I want to do.  image  Do I want
to delete the border, or just shrink it to the size of the board?  Thanks.
    Aah, thanks, Warren!
    mask in Eagle 4.16r2, you can get a sense of it by zooming to fit and
    noticing the board occupies only the lower left of the screen instead
    of the whole screen.  I can see the mask when viewing the .stc
    (created by the gerber274x.cam job) in Viewmate.  How can I fix this?
    I don't know how to modify it at all, but I don't even know what I
    want to do.  image  Do I want to delete the border, or just shrink it to
    the size of the board?  Thanks. --
    Turn on all the layers. You can then see the 4 wires in layer tStop causing
    the issue.
    Delete those 4 wires.
    WINDOW fit to verify all ok.
    Verify all ok with the new gerbers
    HTH
    Warren
    Here it is.
    Karl Lautman wrote:
    Ooops.  The .brd is 53K and I'm only allowed to attach files up to
    50K.  In the absence of the file, does anybody have any ideas what
    the problem/fix might be?  Thanks.
    zip the board file. It will then be about 16kB and you can then attach it,
    Warren
    Ooops.  The .brd is 53K and I'm only allowed to attach files up to 50K.  In
    the absence of the file, does anybody have any ideas what the problem/fix
    might be?  Thanks.
    No file attached
