EAGLE User Support (English) Trace lock and re-optimization
  • Views 671 views
It would be nice to be able to lock traces the way components are
locked. This would allow experimenting with routing on one part of the
board, issuing a global 'ripup' command, without worrying about ripping
up existing traces.
If this feature is implemented it would also allow for another feature
I've always wanted: re-optimization. Imagine running Autoroute but
without the routing pass. That is, only the optimization passes are run.
This would be very helpful to clean up a manual routing job.
In re-optimization, any trace that is not locked is fair game for the
autorouter to re-route according to existing costs (without changing the
connectivity). Of course, locked traces remain untouched.
Andrew.
    Am 06.09.2011 23:42, schrieb Andrew Sterian:
    locked.
    Yes, please! (see also my post from 2010-07-19)
    Some additional wild thoughts on that subject:
      1. Locked/unlocked parts can easily be distinguished by their
         diagonal vertical handles. Other objects should stay as they
         are now if unlocked. If locked, I'm not really sure how to
         display that:
          - Vias COULD get a diagonal cross if locked.
          - Wires, polygons etc. COULD get diagonal crosses at each
            ent point if locked.
          - Or one just does NOT show the 'locked' status at all
            (because screen display could get quite messy)
      2. At the moment, grouping some area and moving it only a bit
         MIGHT result in DRC errors: If the user doesn't know that
         the group contains locked objects, everything else is moved,
         the locked objects aren't, and the resulting mess might not
         be so bad as to be seen immediately.
      3. Other programs don't show the lock status at all, BUT warn
         the user when changing the board: 'This group contains
         locked objects. Do you want to proceed with moving?' If the
         user selects YES, the board might be messed up due to some
         objects moving and others staying, but at least the user
         was warned that things might happen. Selecting NO aborts
         the moving.
      4. At least the following behaviour is possible when trying
         to move (or otherwise change) locked objects:
          - Notify the user ('You must first unlock the objects')
            and do nothing.
          - Notify the user ('Locked objects will not be processed')
            and proceed only with the unlocked objects.
          - Notify the user ('Even locked objects will be processed')
            and proceed with the action as if the objects were
            NOT locked.
          - Ask the user what to do ('Locked objects: Process them,
            Ignore them, Cancel').
    I don't really care WHICH of the above would be implemented (they all
    have advantages and disadvantages), but being able to lock ALL object
    types and being notified if things might go wrong would be just spiffing...
    Andreas Weidner
    "Andrew Sterian" <a.sterian@emsyde.com> wrote in message
    news:j4644n$dlo$1@cheetah.cadsoft.de...
    It would be nice to be able to lock traces the way components are locked.
    This would allow experimenting with routing on one part of the board,
    issuing a global 'ripup' command, without worrying about ripping up
    existing traces.
    I've always wanted: re-optimization. Imagine running Autoroute but without
    the routing pass. That is, only the optimization passes are run. This
    Andrew.
    +1
    Andrew Sterian wrote on Tue, 06 September 2011 17:42
    up existing traces.
    run.
    the
    I agree Andrew, this could be useful.  Even if just to protect a highly
    optimised section of the layout (like a power supply for instance).
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
