EAGLE User Support (English) Making your own Fiducials
  • Views 2019 views
I have searched here on the forum to find out where and how fiducials are
done and discovered they are in the marks library. That's all good and well
except I want to make my own, and put them in my own library. I have made a
fiducial, or so it seems, yet I cannot import it into my layout becuase
Eagle complains about back-annotation. I don't understand, in essence my
package (because that's what those "marks" are) is basically the same thing
as the ones in that library. It consists of a pad with a stop mask.
what's the problem, why does it not let me import my fiducial?
thanks,
OW
    Owen wrote:
    Yes, I believe you're right. I DO have a pad, actually it's a round
    pad. And I understand now that it's expecting a symbol of some kind.
    I'llhave to check with the dsigner to see if he wants to have to add
    a symbol in the schematic.
    I'll have a look at sparkfun (wth does that mean anyway!?)
    http://www.sparkfun.com
    Sparkfun Eagle library
    https://github.com/sparkfun/SparkFun-Eagle-Library/archives/master.
    Yes, I believe you're right. I DO have a pad, actually it's a round pad.
    And I understand now that it's expecting a symbol of some kind. I'llhave to
    check with the dsigner to see if he wants to have to add a symbol in the
    schematic.
    Thank you again!
    OW
    are done and discovered they are in the marks library. That's all
    good and well except I want to make my own, and put them in my own
    library. I have made a fiducial, or so it seems, yet I cannot import
    it into my layout becuase Eagle complains about back-annotation. I
    don't understand, in essence my package (because that's what those
    "marks" are) is basically the same thing as the ones in that library.
    marks.lbr packages that work as you say do not use any pads.
    When you specify a pad in your package, Eagle stops you from adding it to a
    board if the schematic is open. I guess the logic is; if there is a pad
    there must be a symbol for this device so you can only ADD into the
    Schematic. If you close the schematic, add your fudicial and then open the
    schematic, all will be well and still consistant.
    You could create a fudicial symbol, and device. Place those into your
    schematic
    If you have the Sparkfun library, check out 'fudicial', they do it this way.
    HTH
    Warren
