EAGLE User Support (English) DRC is not detecting a violation - 2 files [1/1]
  • Views 326 views
I have set the clearance to 4 mils in all DRC fields, since this is the
minimum required from PCB house. I have attached 2 pictures, one of them
is showing a distance of only 2 mils (grid set to 1 mil) between 2 vias
that wasn?t captured by the DRC. On the other picture there are the DRC
configs.
Why is this happening? It should have detected the error on the
clearance.
Thiago
    Thiago <thiago_hr@yahoo.com.br> wrote:
    In article <j4touq$vnu$1@cheetah.cadsoft.de>,
    warrenbrayshaw@paradise.net.nz says...
    >> Thiago wrote:
    >>> Yes, they are the same signals (GND), and the clearance to same
    >>> signals are set to 0 (to skip overlap errors, since I have some vias
    >>> over pads). But I set to 4 mils the clearance to same signals and it
    >>> is still not generating errors. Weird.
    >> There is no check between vias of the same signal name, only between SMD and
    >> SMD,PAD,VIA
    >> HTH
    >> Warren
    I see. So, between vias I should take care about the clearance
    "manually" ?
    This is a problem issue in Eagle. Especially on HDI layouts where the
    manufacturer has much better quality control an issues like that can lead
    to lower lifetime because it can cause leftover chemicals in the manuf
    process, or issues that optical inspection will trigger on.
    I dont know the reason for having same net vias that close, but merging
    them with a wide wire may help you out. The problem is that Eagle doesnt
    warn you about them.
    SMD,PAD,VIA
    HTH
    Warren
    "manually" ?
    SMD,PAD,VIA
    HTH
    Warren
    news.cadsoft.de
    In article <j4ruvg$kot$1@cheetah.cadsoft.de>,
    Thiago wrote:
    the minimum required from PCB house. I have attached 2 pictures, one
    of them is showing a distance of only 2 mils (grid set to 1 mil)
    between 2 vias that wasn?t captured by the DRC. On the other picture
    there are the DRC configs.
    clearance.
    Thiago
    Perhaps the signal names of  those two vias the same?
    Your 4mil settings only apply to different signals
    Warren
    Yes, they are the same signals (GND), and the clearance to same signals
    are set to 0 (to skip overlap errors, since I have some vias over pads).
    But I set to 4 mils the clearance to same signals and it is still not
    Thiago wrote:
    clearance.
    Thiago
    Warren
    Viewed and responded to from the newsgroup at
    news.cadsoft.de
