EAGLE User Support (English) Eagle Freeware asking for a license file
  • Subscribers 187 subscribers
  • Views 276 views
I'm running Backtrack 5 linux Info from "About the GNOME desktop" "Version 2.30.2, Distributor: Ubuntu, Build Date 6/25/2010" if that helps
When i run the eagle file, it worked once, but now(a few days later) it says "Eagle needs to install a license file on your computer in order to work. Select Use License File if you have a personalized EAGLE license file. Select Freenimum if you have an EAGLE code from http://www.element-14.com/eagle-freemium ." only options are "cancel" "freemium" and "use license file"
Hitting cancel just closes it, and i don't have a license file. Is this a known bug or anything? or how can i fix this? can i download a license file to use for the free version?
I select "freeware" during the install
