How do I insert bmp image into pcb copper?
My pcb on the component side has GND fill so less copper is stripped from
the board. I want to include a graphic in this blank area of copper...
so far:
I can import my bmp image into Layer 1 TOP using import-bmp.ulp ..the image
being the round object in the pic below
http://www.eaglecentral.ca/forums/index.php?t=getfile&id=5982&private=0
now when I auto-route the GND fill is applied ..and because both the GND
fill and the imported bmp belong to Layer 1 TOP...the fill does not cover
the bmp object.
Like so..this is exactly what I need
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
