EAGLE User Support (English) Re: import image into GND plane?
  • Subscribers 187 subscribers
  • Views 211 views
tuk schrieb:
I haven't created a new thread
You have - unintentionally, as it seems.
..I was asked to clarify the question which
I did ..given the lack of ideas/suggestions over what seems like quite a
basic task  ...I thought it was reasonable to reply
Your posts lack the references to the previous posts, that's why they
appear to start a new thread here in the newsgroups. Maybe you used "new
message" instead of "reply", maybe the web forum gateway is broken
again... :-\
On the topic:
At least for me it's still unclear as to what your problem is. Perhaps
you can also provide an image about how it appears in gerbv. You might
also upload a board file containing a test case with your imported
bitmap and then post a link so we can have a look at your data.
Tilmann
    autodeskguest over 14 years ago
    again... :-\
    On the topic:
    Tilmann
