EAGLE User Support (English) Re: Prolonged pads and openings/drills/
  • Views 212 views
I am looking to do something similar to this. For a USB connector with
through-hole mounting, I need irregular pads/holes as shown below.
Is it possible to do this with Eagle?
Michael
    Zeta wrote:
    >What I still don't know is how to delete a symbol/device from a library.
         "remove package/symbol/device-name"
    be aware that a symbol or package can't be deleted as long as it is
    used by a least one device.
    Lorenz
    What I do is to open the library symbol, select it all and then Copy the Group. After that I just create a new symbol and use the paste command to place the old symbol in the center.
    Is it possible to copy an existing library-symbol to another name so I
    can use it as a starting point afterwards for editing and making a
    different package with it?
    regards,
    hugo
