EAGLE User Support (English) Generating EXCELLON files from command line
  • Views 347 views
Hi there,
I've been able to generate gerbers from the command line but not having any
luck with the following invokation:
"C:\Program Files
(x86)\EAGLE-5.11.0\bin\eagle.exe" -X -dEXCELLON -RB30002.drl -oB30002.drd
-D0.025 B30002.brd Drills Holes
Eagle starts running in the background and takes 25% of my CPU until I kill
the task. does anybody know how to generate drd files from the command line?
Neil
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:j5jdm5$ll5$1@cheetah.cadsoft.de...
    Neil MacMunn wrote:
    >> Hi there,
    >> having any luck with the following invokation:
    >>> "C:\Program Files
    >>> -oB30002.drd -D0.025 B30002.brd Drills Holes
    >> I kill the task. does anybody know how to generate drd files from the
    >> command line?
    Command should be all on one line, you are likely doing  that.
    The  -D needs to be a -E
    A full path to your board file is needed
    The drill file can be just the file name if it is in your board folder, as
    can be the output file
    Thanks Warren. -E did it.
    Neil MacMunn wrote:
    Hi there,
    >> "C:\Program Files
    command line?
    HTH
    Warren
    news.cadsoft.de
