EAGLE User Support (English) BUS Tutorials / examples of how to use
  • Views 2124 views
Finding it a bit difficult to understand BUSs which I suspect will simplify
the appearance of a schematic by bringing more than one wire into the
common bus line.
Does anyone have some advice or examples.
Regards
Ray B
    Am 27.09.2011 14:48, schrieb Chuck Huber:
    On 09/26/2011 03:47 PM, Morten Leikvoll wrote:
    >> (I have asked for improved bus support so buses easily can be copied and
    >> reused.)
    Bus wires still don't drag attached nets with them.  Maybe this should
    be thrown into the suggest group.
         - Chuck
    AFFIRMATIVE
    Joern Paschedag
    reused.)
        - Chuck
    For the assistance of others attached is self documented schematic example
    Sharing is enjoying ...
    Regards
    Ray B
    Thanks guys.... That Danish Tutorial is excellent
    Regards
    Ray B
    simplify the appearance of a schematic by bringing more than one wire
    into the common bus line.
    This tutorial gives a good exposure to Busses
    http://dmi.uib.es/~jguerrero/labSistemes/eagle_tut.pdf
    news.cadsoft.de
    The current eagle bus is only there for redundancy when drawing the
    schematic. You need to name it with all the signals you want it to carry
    (comma seperated) and all nets ending at it will be checked against that
    list at ERC. If some net not belonging to the bus is found or one is
    missing you get a warning.
    Signals ending with an index can be compressed in the bus name.
    reused.)
