EAGLE User Support (English) copy component in library and then change footprint...how?
  • Subscribers 189 subscribers
  • Views 473 views
js1234
js1234 over 14 years ago
Hi
How to edit existing component and copy as new component then change
footprint?!
THANKS for info!
    e14 Contributor over 14 years ago in reply to js1234
    On 9/27/2011 1:03 PM, Joe wrote:
    Thanks!
    Is possible copy one component from any library to my library?
    Open the destination library, then,
    Open Eagle's control panel and expand the library tree.
    Go to the library/part that you want to copy, drag and drop the part (or
    just the symbol or package) into the destination library.
  • js1234
    js1234 over 14 years ago in reply to e14 Contributor
    Thanks!
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:j5t9cl$ack$1@cheetah.cadsoft.de...
    On 09/27/2011 03:32 PM, Joe wrote:
    >> Hi
    >> footprint?!
    >> THANKS for info!
    The best way is to set your news reader to get all messages. In June there
    was a good thread found with search for lib edit using thunderbird. Or use
    the forums http://www.eaglecentral.ca/ which I never use.
    It is general recommendation to not edit the cadsoft libs as when you
    update you will loose your changes. Make your own lib and copy them as
    needed and verify they match your need.
    Hi
    footprint?!
    THANKS for info!
    there was a good thread found with search for lib edit using
    thunderbird. Or use the forums http://www.eaglecentral.ca/ which I never
    use.
