HI,
I have a current board design which requires for one through hole component
( but used 48 times) to have a different pad size for TOP and BOTTOM.
I need a through hole pad ROUND that has a 3mm ID and a 5mm OD for the TOP
PAD but with a 8MM OD for the bottom pad and plated in the hole.
I have tried using 2 pads, but that just creates the same for top and
bottom, I have tried using the MIRROR check box for a pad, but it does not
save it, or inform you of an error.
I have played with RESTRING, but thats too confusing and changes all pads
on a board, I have other devices which don't require this type of pad so
restring is useless.
I know that the next release of eagle cad has more options for "unusua"l
pad shapes/sizes, but I need a solution in the next week!
I can't believe eagle cad does not cater for this?
Dave M
PS Can a ULP be written to modify pad sizes ( I dont care what the DRC
tells me)
If eagle cad cant do this, I have several other boards that require the
same part, all dues in the next few weeks!! I may have to use ANOTHER CAD
Application!
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
