EAGLE User Support (English) Re: I'm confused about adding NETS
  • Subscribers 187 subscribers
  • Views 107 views
On 10/11/2011 09:48 AM, Chuck Huber wrote:
On 10/11/2011 08:29 AM, Olin Lathrop wrote:
>> Element 14 User wrote on Mon, 10 October 2011 20:58
>>> I'm confused, should I be using the Wire command to connect components
>>> in the schematic or using the Net command.
>> Always use NET to make schematic connections.
>> The command names in Eagle are perfectly logical.  WIRE is used to draw
>> lines except when they respresent wires, then you use NET.
touche! That's good, Olin.
Jeff, Also be advised that CUT doesn't cut - it copies.
I also might point out that schematics really don't have wires.  The
schematic is really all about identifying /networks/ of connections in a
manner that is presentable in a form that we all know as a schematic.
One can think of wires as a physical manifestation of network connections.
As Olin pointed out, the "WIRE" command should be called "LINE" in the
schematic.
Enjoy,
    - Chuck
