EAGLE User Support (English) Re: I'm confused about adding NETS
  • Subscribers 187 subscribers
  • Views 130 views
Chuck Huber wrote on Tue, 11 October 2011 09:56
As Olin pointed out, the "WIRE" command should be called "LINE" in the
schematic.
Not just in the schematic.  In the board, WIRE is used to draw lines except
when they are wires, then you use ROUTE.
WIRE should really be called LINE all around, but it's way too late to fix
this poor choice of names now.
