Olin wrote on Tue, 11 October 2011 10:05
Chuck Huber wrote on Tue, 11 October 2011 09:56
As Olin pointed out, the "WIRE" command should be called "LINE" in
the
schematic.
Not just in the schematic. In the board, WIRE is used to draw lines
except when they are wires, then you use ROUTE.
WIRE should really be called LINE all around, but it's way too late to
fix this poor choice of names now.
Not really. I'd suggest that in EAGLE 6 "LINE" be used and "WIRE" would be
considered an alias to "LINE". Then in the future, WIRE could be
deprecated with a SET command to continue to use it as an alias to "LINE".
That way, it makes more sense out of the box with a path forward to
cleaning it up.
James.
James Morrison ~~~ Stratford Digital
Specializing in CadSoft EAGLE
Online Sales to North America
Electronic Design Services
EAGLE Enterprise Toolkit
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
