EAGLE User Support (English) scrolling horizontal / vertical using mouse/trackpad
  • Subscribers 187 subscribers
  • Views 2823 views
Dear all,
I'm using Eagle 5.11.0 on Mac OS X.
I would like to use trackpad/mouse to scroll/zoom the schematic/board
without using cursors or manually press the scroll bars.
Default behavor for both mouse scrollwheel and trackpad is zoom.
By changing Option -> User Interface -> Mouse wheel zoom to 0 it will
switch to scroll mode.
However the scroll mode only support vertical scroll, not horizontal
which is not very usefull.
So my question is if anybody know how to enable both
horizontal/vertical scrolling for mouse wheel/trackpad for Eagle in OS
X ?
The ideal would be to both zoom/scroll using the trackpad guestures.
That would make Eagle much more productive on smaller screens.
Best regards,
Jon
    Whats wrong with holding middle button/wheel and move mouse to pan?
    Seems not working for me on OS X. Maybe some special settings needs to
    be enabled for this or it might be windows specific.
    Even tought the CMD/CTRL key makes it much more easy to move around in
    schematic, it would be great if Cadsoft has planed/implemented trackpad
    guestures for next version of Eagle.
    Best regards,
    Jon
    "Jon Suphammer" <jon@suphammer.rm.net> wrote in message
    news:j78jji$e5j$1@cheetah.cadsoft.de...
    Dear all,
    On 2011-10-14 06:17:21 +0000, Tilmann Reh said:
    I suggest to try activating "pan by ctl key" - that's much more
    convenient, IMHO. You just hold down ctl and then the mouse/trackpad
    pans the window content.
    Along with scroll wheel zoom that's perfect for me.
    Thanks Tilmann, this works great.
    I found on OS X it's command key instead of control.
    To activate the function I found two ways you could activate/deactivate this.
    From EAGLE:
    Type 'SET Interface.UseCtrlForPanning 1'
    From .eaglerc:
    Interface.UseCtrlForPanning = "1"
    Best regards,
    Jon
    X ?
    Tilmann
