EAGLE User Support (English) short-cuts for processed/approved DRC Errors?
  • Views 743 views
Gustav_M
Gustav_M over 14 years ago
Hi
When Eagle has produced the list of DRC errors, then I often find myself
clicking through a long list of errors.
Are there some keyboards short-cuts for processing and/or approving DRC
Errors?
This would make the DRC error list faster to go through.  image
    Andreas Weidner wrote:
    Am 17.10.2011 10:07, schrieb Gustav:
    >> DRC Errors?
    The EAGLE DRC window DOES have shortcuts, but unfortunately, they are
    NOT shown by default - at least on Windows machines (this is a problem
    of Windows' rubbish defaults, though, and NOT of CadSoft):
    While having the DRC window open under Windows, press the ALT key:
    Some characters from the button texts should now get underlined.
    Those are
    the ones that you can use in conjunction with the ALT key to 'press'
    that button. Why Microsoft threw the underlining away will forever be
    a mystery to me. You can activate it again in Windows 7 somewhere in
    the Windows control panel: Control Panel / Ease of Access Center /
    Make the Keyboard easier to use (or something like that).
    E.g., on a German installation, the shortcuts include ALT+B for
    approving ('billigen'). I suspect that English shortcuts would be
    different.
    Andreas Weidner
    PS: The Linux machines I've seen ALWAYS show the underlining, so
    everything is MUCH easier to see...
    Thanks for the tip Andreas.
    Centered    ALT+C
    Clear All    ALT+E
    Processed     ALT+P
    Approve    ALT+A
    The path to change the setting in WIN2000
    Control Panel / Display / Effects / Hide keyboard navigation indicators
    until I use the alt key
    Warren
    news.cadsoft.de
    Errors?
    While having the DRC window open under Windows, press the ALT key: Some
    characters from the button texts should now get underlined. Those are
    that button. Why Microsoft threw the underlining away will forever be a
    mystery to me. You can activate it again in Windows 7 somewhere in the
    Windows control panel: Control Panel / Ease of Access Center / Make the
    approving ('billigen'). I suspect that English shortcuts would be different.
    Andreas Weidner
    Gustav wrote:
    Hi
    myself clicking through a long list of errors.
    DRC Errors?
    I find the following technique the most efficient:
    Having clicked on the first error,
    Left hand uses the  up and down arrows on the keyboard.
    Right hand on the mouse positioned over the "Approve" button.
    HTH
    Warren
    news.cadsoft.de
