EAGLE User Support (English) Delete Library packages
  • Views 415 views
Are there plans for an easier way to delete packages from a library
other than typing the name each time?
    James Morrison wrote:
    John Friede wrote on Fri, 28 October 2011 10:41
    >> Hello,
    It is a bit of a pain, especially if you have long package names
    (which I do).  My trick is to first type "ren" (for rename) and a
    dialog will appear with the package name prepopulated.  then use
    Ctrl+C to use OS to copy the string to clip board and hit cancel.
    Then type "del" (for delete) and the Ctrl+V into the text box.
    I suspect James meant type "rem"(for remove) and then Ctrl+V into the text
    box.
    Warren
    news.cadsoft.de
    It is a bit of a pain, especially if you have long package names (which I
    do).  My trick is to first type "ren" (for rename) and a dialog will appear
    with the package name prepopulated.  then use Ctrl+C to use OS to copy the
    string to clip board and hit cancel.  Then type "del" (for delete) and the
    Annoying but better than having to type in a long name (and getting it
    wrong).
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
  • Richard_H
    Richard_H over 14 years ago
    Am 28.10.2011 16:41, schrieb John Friede:
    There are no plans for the near future, but I will keep your
    request in mind and forward it to our development people....
    Richard Hammerl
