EAGLE User Support (English) Attribute Display from Script/Command
  • Views 1381 views
Hi
Reading throuht the help file on attributes, I'm not able to find how to set
the Display property of an attribute. I add attributes like this in the
schematic:
attribute LED1 MF 'AVAGO TECHNOLOGIES';
But the default for Display is "Value", but I want it to be "Off". I
manually have to
attribute LED1
and edit it by hand with mouse / keyboard. How can I do this from the
script/command prompt (attribute command).
Stian Skjelstad
    Firstly, to clarify your issue.
    As you add attributes, one by one, the values are displayed. So you have a
    number of them displayed and this is why you feel you need to use GROUP to
    change the attribute display property to 'OFF' for all of them.
    If so, in keeping with your script/keyboard desires, try the attached ULP
    to turn off the attributes of a specified part.
    RUN AttOff LED1
    To reduce keystrokes, shorten (rename) the ulp file name to AO .
    RUN AO LED1
    Some provisions apply as the ULP emulates mouse actions:
    If the layer is not visable when the ULP is run the display property of the
    attributes on that layer are not modified. If you later turn on that layer
    the attribute will display. It is likey with the expected use this would
    not be an issue.
    When targeting the compete schematic you may also find of use:
    GROUP ALL;
    CHANGE DISPLAY OFF (>0 0);
    All attributes of all parts will turn off.
    HTH
    Warren
    "Stian Skjelstad" <stian@servoelectronics.no> wrote:
    "René König" <rk@tbkoenig.de> wrote in message
    news:j8lota$ldi$1@cheetah.cadsoft.de...
    >> Hi,
    >> the CHANGE DISPLAY command is used to control the attribute's visibility,
    >> see HELP CHANGE:
    >> CHANGE DISPLAY OFF;
    That meens I have to GROUP, which implies using the mouse to select them. No
    way to do this via the PART and ATTRIBUTE names? Something like this (which
    is not working, but just here as an example of what I look for)
    CHANGE DISPLAY OFF LED1 MF
    check out the ingroup() setgroup() and clrgroup() ulp commands, they are
    very useful.
    CHANGE DISPLAY OFF;
    I was a bit to quick in my last response.. I can go around my problem by
    calling delete first (if already visible).
    ATTRIBUTE LED1 MF DELETE;
    CHANGE DISPLAY OFF;
    ATTRIBUTE LED1 MF 'AVAGO TECHNOLOGIES';
    But as far as I can see, the CHANGE DISPLAY will only work for attributes
    not already created, else you have to use GROUP, which implies mouse action.
    Stian Skjelstad
    see HELP CHANGE:
    CHANGE DISPLAY OFF;
    Stian Skjelstad
    visibility, see HELP CHANGE:
    CHANGE DISPLAY OFF;
    Rene
