EAGLE User Support (English) How to batch change component package
  • Views 1828 views
Hi, everyone:
I am a new user of EAGLE. I got a problem.
I had finish the schematic design, but I have to change all the package of capaticors appear in the design from 0402 to 0805. Is there any ULP could realize this task? Otherwise, I have to do it one by one manuelly.
Thanks a lot.
    Mengxi Lin wrote:
    Hi, everyone:
    by one manuelly.
    Thanks a lot.
    Answered many times previously
    One of the threads
    eagle.support.eng
    Component Replacement
    7 April 2011
    In summary, you can do it en masse if the two packages are in the same
    device set.
    What you type for the replacement package depends on the library/part  you
    are using for your 0402/0805 part.
    Alf wrote back then:(7 April 2011)
    select elements in BRD with GROUP, type in
    CHANGE PACKAGE R-EU_R0603
    btw.
    CHANGE PACKAGE R-US_R0603
    Name of deviceset   ^^^^^
                         package variant
    The shortness version:
    ch pac R-US_R0603
    and now click with rigth mouse button at the group.
    Only elements defined this package in deviceset can change.
    TIP:
    SET Option.ToggleCtrlForGroupSelectionAndContextMenu 1;
    HELP SET (enter)
    HTH
    Warren
    news.cadsoft.de
