EAGLE User Support (English) Removing components from schematics and board s.
  • Views 1758 views
I've started with a working (and consistent) schematic and board. I've been
trimming down the schematic to remove a number of unwanted components, when
I switch to the board view the unwanted  components have been removed
(which is what I want!) but many redundant tracks and lots of unused via's
still remain, am I doing something wrong? Or do I have to do this editing
manually.
    lima7 wrote on Tue, 01 November 2011 05:19
    been trimming down the schematic to remove a number of unwanted
    components, when I switch to the board view the unwanted  components have
    been removed (which is what I want!) but many redundant tracks and lots
    of unused via's still remain, am I doing something wrong? Or do I have to
    do this editing manually.
    You're not doing anything wrong.  Devices must be deleted in schematic
    (this is the way EAGLE enforces it, I think it helps maintain consistency).
    However, when you delete a device it will only rip up traces in the PCB if
    the entire net is deleted in the schematic.  Otherwise, it doesn't know
    what to do and thus leaves it for your attention (which is the right thing
    to do, IMHO).
    So yes, you would then have to go and ripup any traces or trace segments
    that you want to remove.
    And if you have polygons you'll have to delete them manually as well, even
    if you delete all the nets associated with it.  HINT:  If you hold down the
    shift key while deleting a polygon segment it will delete the whole polygon
    and not just the segment.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
