EAGLE User Support (English) Copy block
  • Subscribers 189 subscribers
  • Views 797 views
  • block
  • copy
Copy block
david_f
david_f over 15 years ago
Hi guys,
I'm in charge of a test board PCB and I've 20 similar blocks.
I'd like to know if it's possible to copy a placement/wiring according to the schematic.
Thanks for help.
David.
  • david_f
    david_f over 15 years ago in reply to Morosh
    Thx Maurice for this ulp files. But some files are missing when I use duplicate_board.ulp .
    I've an other problem when I copy/paste my block: Some nets are linked on a connector and when I duplicate the block on the board only, these nets disappear. How can I rename them while I can't select them with the "rename" function?
  • Morosh
    Morosh over 15 years ago
    On 07/11/2011 12:52, david fournier wrote:
    Hi guys,
    Thanks for help.
    David.
    Try  ftp://ftp.cadsoft.de/eagle/userfiles/ulp/duplicating_v45.zip
    Maurice
    e14 Contributor over 15 years ago in reply to david_f
    the key is to name every net with an unique name (no $nnn). the supply
    nets need not to be named individually, they will count up, e.g. gnd1, gnd2
    after pasting rename all to "gnd" & answer the question to connect them with
    yes. do this with the other supply nets in the same way.
    hth
  • david_f
    david_f over 15 years ago in reply to e14 Contributor
    Thanks for your answer Josef-Michael.
    But with this way, I've got a problem with the cummon nets. In fact, when I copy/paste a block, the cummon nets are not connected together in the board.
    Is there a solution to this instead of put cummon nets one by one?
    Regards.
    David
    Group: Polygon or rectangle (->online help)
    Cut (->online help)
    Paste (->online help) as often you want
    Works with:
    sch + brd (Back-Forward-Annotation ACTIVE)
    brd only (NO Back-Forward-Annotation)
    r
  • david_f
    Can someone help me, please?
