EAGLE User Support (English) Hobbyist license: Missing available signal layers
  • Subscribers 187 subscribers
  • Views 292 views
zainka
zainka over 14 years ago
Hi
I just purchased the hobbyist license which according to Cadsoft.de has
it limits tied down to six signal layers on 100x160mm board. However, I
can only see top and bottom. I  guess the other layers visible should
have been Rout2, Rout3, Rout14 and Rout15 ??
When, in controlpanel, I go to "Help/About Eagle", I can see that I have
the hobbyist license under topic "Registered to" and the proforma says
so aswell, but "about eagle" also says "studen version" aswell. But i
know that I applied for an individual license, and not student.
This is what "about eagle" says:
Single User License ###MY LICENSE###
Student Version - NOT FOR COMMERCIAL USE!
Registered to:
HOBBYIST LICENSE
Vidar ... and so on
My proforma says "EAGLE-HOBBYIST 1User Standard V5"
Have I got the wrong license???
Best regards Vidar(Z)
  • Richard_H
    Richard_H over 14 years ago
    Am 08.11.2011 15:59, schrieb Vidar (Z):
    Hi
    Registered to:
    HOBBYIST LICENSE
    Vidar ... and so on
    You have the correct license, but you have to introduce the layers
    for your layout.
    This is done in the layer setup where you tell EAGLE which layers
    your board shall consist of. Please check the settings in the
    Design Rules, Layers tab.
    For creating a 4 layer board, you can, for example, use the following
    setup:   (12+1516)
    More information in the manual about Multilayer boards.
    Richard Hammerl
