EAGLE User Support (English) PIN text size/location
  • Views 242 views
The "smash" command allows you to change the position of and scale the
text size for "NAME" and "VALUE".  I can not seem to find how to do this
with pin numbers though.  I have a small 3 terminal voltage reference
that if I allow pin numbers to be visible, they are cluttered together
and way to big.  Is there any way to change that?
    Unfortunately not. Use PINs with invisible pin names and place your own
    text objects as you prefer. Take care that they are not automatically
    changed with the pin names later, if you modify them.
    Tilmann
