EAGLE User Support (English) Freemium still limited to light dimensions
  • Views 571 views
I've signed up for and licensed the Freemium version of Eagle as I need to make a long, skinny board (140mm x 55mm), but I seem to be having trouble getting it to allow parts out to the 150x100mm dimensions. The code appears to have worked, and I can create more than one sheet and can run four layers, but I still seem limited in area.
Is there some other setting I need to change? Thanks.
    On 11/10/2011 5:28 PM, Warren Brayshaw wrote:
    Hi Jorge
    I hope you have taken it upon yourself to get all these discrepancies
    cleaned up as they are identified. The offerings and the wording around them
    need to be consistent across your corporation.
    Warren
    Hi Warren,
    Yes I'm going to forward the discrepancy to Newark and Element-14.
    They'll take care of it from there.
    Best Regards,
    Jorge
    Alright, thanks for the clarification.
    Looks like I'll have to try and convince my boss to pony up the money for the pro version, just to be future proof.
    Jorge Garcia wrote:
    On 11/10/2011 4:54 PM, Dave Williams wrote:
    >> Is this not the correct page?
    http://www.element14.com/community/community/knode/cad_tools/cadsoft_eagle/freemium
    >> (/community/knode/cad_tools/cadsoft_eagle/freemium)
    >> Thanks for your reply,
    >> Dave
    Hi Dave,
    It seems you've found a discrepancy on Newarks website.Check out this
    link.
    http://www.element14.com/community/community/knode/cad_tools/cadsoft_eagle/products?view=overview
    hth,
    Jorge
    Hi Jorge
    Warren
    news.cadsoft.de
    http://www.element14.com/community/community/knode/cad_tools/cadsoft_eagle/freemium (/community/knode/cad_tools/cadsoft_eagle/freemium)
    Dave
    Hi Dave,
    It seems you've found a discrepancy on Newarks website.Check out this link.
    hth,
    Jorge
    Dave
    Hi Dave,
    If you look at the website, you'll notice that the size limitations for
    the freemium and the freeware are the same. The advantage the freemium
    has is that it allows 4 layers and 4 schematic sheets.
    Best Regards,
    Jorge
