EAGLE User Support (English) CLI is faster than GUI myths
  • Replies 17 replies
  • Subscribers 189 subscribers
  • Views 1530 views
Id like to start this thread to address the "CLI is faster than GUI" myths.
I challenge diehard CLI users to add their favorite command that they think
cant be done as efficient in a GUI, and I'll try to find a equally efficient
way to do it the GUI way.
Ill start adressing the group selection tool and the precision adjustment
myths.
A proper GUI would let you select the components you want to change with
either a select window drag (not having to activate the group) like a
powerpoint presentation design. It will also let you add and remove using
ctrl (or shift) selects like you do in a (win) filebrowser. Also, a filter
selection tool could help you add component based on name or other
parameters.
Then when right clicking one of the selected parts, it would pop up a
property window where all properties are presented (and props with different
values are marked as "dont change" by default), and it will give you the
option to overwrite them with a new value. All properties can be handled
like that, even fine positioning.
    Morten Leikvoll wrote on Fri, 11 November 2011 11:42
    >Scenario 1: Move PCB elements (components, traces, vias, ...) by some
    exact, very small amount, say 0.001mm. I don't think that is
    even
    possible with GUI since the grid won't display. You could argue
    then, why
    does it matter to move such a small amount, but I like to be
    accurate image
    That one is easy. Two alternatives would work in a common gui
    environment.
    1.Right click the element and select properties. At properties win you
    will
    find coords and you can change them (much like today, and I use i a
    lot). A
    relative checkbox could switch to relative coor mode, and would work
    on
    many elements.
    2. A relative move action in a menu entry that does it directly on the
    selected components. For most gui toolsl all the actions available in
    context menus are also found in the main menu.
    Are you answering with how to do a task with an ideal GUI or with EAGLE 5
    as it stands today?  If it's the first one (ideal GUI) then it's a useless
    exercise as that GUI doesn't exist.  Of course the perfect GUI would work
    perfectly.  But that's not very useful.
    I'm assuming you're trying to answer with how EAGLE 5 works today.
    Your first alternative above only works on an individual component.  I need
    to shove everything over.
    Your second alternative doesn't exist in EAGLE so it's a moot point.
    And while it's a small amount, it maybe be enough to just squeeze some
    space to get a trace into a dense area and avoid DRC values.  So it's not
    just theoretical.  Sometimes even 0.001mm make a differnce.  You could just
    ignore the DRC error but I don't do that unless there is no other option.
    It still remains that you can't do this with the current EAGLE GUI.  I'm
    open to being shown differently.  And writing a ULP to do it and then
    clicking a button to run the ULP doesn't count.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Am 11.11.2011 20:27, schrieb Dietmar Schwertberger:
    Am 11.11.2011 17:42, schrieb Morten Leikvoll:
    >>> exact, very small amount, say 0.001mm. I don't think that is even
    >>> possible with GUI since the grid won't display. You could argue then,
    >>> why
    >>> does it matter to move such a small amount, but I like to be accurate image
    >> environment.
    >> will
    >> lot). A
    >> relative checkbox could switch to relative coor mode, and would work on
    >> many elements.
    A third alterntive may be to use the arrow keys.
    Maybe there's even one more way:
    There's enough space for a context sensitive toolbar.
    When you move something, this toolbar could display four boxes
    for absolute and relative coordinates and at the same time allow the
    user to enter new values.
    When you click to select the next component, the toolbar remains, such
    that you can directly enter the position. At the same time, you can
    press Ctrl+Y (re-do) to apply the same relative movement to this
    component.
    Dietmar
    >> possible with GUI since the grid won't display. You could argue then, why
    That one is easy. Two alternatives would work in a common gui environment.
    1.Right click the element and select properties. At properties win you will
    find coords and you can change them (much like today, and I use i a lot). A
    many elements.
    I used to have a drawing program where you could move and place by pixel
    using the arrows.
    In Eagle, this could e.g. move by a grid size. Pressing Alt+Arrow would
    move by the alternative grid size.
    Pressing Shift-Arrow would move by a multiple of the grid.
    Pressing Ctrl+Arrow would snap to grid (just as now with MOVE and Ctrl).
    Pressing CtrlAltArrow would snap to the alternative grid.
    To assist the user, the properties dialog box may display some info
    about how to move using the arrow keys.
    BTW. with the current MOVE command already the following improvements
    could be made for more precise and comfortable placement and movement:
      - display not only the cursor position, but also the position in
        alternative grid (I often have one mil and one  mm grid)
      - display offset to starting position of component
    In general, I would appreciate if most dialogs would be 'multilingual',
    i.e. display mil, inch and mm at the same time (maybe as tooltip).
    A first step is there already: you can always enter a value+unit in
    dialog boxes and CLI.
    Dietmar
    e14 Contributor over 14 years ago in reply to lix
    Lix Paulian <communitymanager@premierfarnell.com> wrote:
    I think only realistic, practical cases should be taken seriously.
    Commands/procedures that either are useless or very seldom performed
    should not be submitted.
    Lix
    I'm happy to answer any strange challenge. Even suggest better ways to
    accomplish the same result. But the most timesavers are most interesting.
  • lix
    lix over 14 years ago in reply to e14 Contributor
    I think only realistic, practical cases should be taken seriously. Commands/procedures that either are useless or very seldom performed should not be submitted.
    Lix
    many elements.
    Morten Leikvoll wrote on Fri, 11 November 2011 04:59
    myths.
    think
    efficient
    Good idea I think.  This could actually be educational to people on both
    sides.
    James.
