EAGLE User Support (English) How do I move a whole track from one layer  to another?
  • Views 3090 views
I'm trying to move a track from the top layer to the bottom, if I just
highlight the track, right click, select properties and then change the
layer, it only moves current segment of track to the selected layer.
I tried to group together the whole track, I selected GROUP and used click
+ ctrl to select each segment of the track, then I right clicked (as
before) selected properties and then chose the correct layer. But, even
though the whole track was selected, only the segment I'd clicked on
actually moved layers.
  • Richard_H
    Richard_H over 14 years ago in reply to e14 Contributor
    Am 11.11.2011 18:05, schrieb Lima:
    works a treat - thanks
    In case you want to change more signals you can use
    copy-layer-to-any-layer.ulp
    Richard Hammerl
    After grouping the wires, goto change->layer, pick new layer, press
    ctrl+rmb.
    (sorry for missing quote)
