EAGLE User Support (English) Airwire global enable?
  • Views 421 views
Am working on a board that a predecessor had designed. Found a number of
traces that had the "airwires hidden" property set. Realized this when a
segment was ripped up and no airwire appeared.
Is there a way to re-enable as a group all airwires? I'd feel better about
releasing the changed board if no airwires were hidden.
A simple way of checking for airwires is create a display alias called 'SFA'
(search for airwires) in which only Unrouted, Dimension and Holes (to show
board outline) are enabled. Airwires then are easily seen.
tia - Oppie
    "Andreas Weidner" <andreas.weidner@aei.mpg.de> wrote in message
    news:j9u1d1$47j$1@cheetah.cadsoft.de...
    Am 15.11.2011 15:26, schrieb Oppie:
    >> about releasing the changed board if no airwires were hidden.
    Type
      ratsnest *
    or, in short form,
      ra *
    into the command line. Additional information is available in the help
    pages of the 'ratsnest' command.
    Perfect! I forgot about the command line options, particularly the Asterisk
    All good now and board released. Thanks for the help.
        Oppie
    On 11/15/2011 11:10 AM, Tilmann Reh wrote:
    Andreas Weidner schrieb:
    >> Type
    >>     ratsnest *
    >> or, in short form,
    >>     ra *
    or, in /really/ short form,
         r *
    SCNR image
    Tilmann
    Also check if he air wire layer is hidden or wrong color.
    Paul R.
    Type
       ratsnest *
    or, in short form,
       ra *
         r *
    SCNR image
    Tilmann
    Type
       ratsnest *
    or, in short form,
       ra *
    Andreas Weidner
