EAGLE User Support (English) Create PCB part library
  • Views 362 views
  • drc
  • pcb_library
  • drc_exclude
Hope i post this on the right place, i'm new to this forum.
I'm using eagle for a while now and i like the way of working and the many options in the program.
Something that would be very usefull to me (and others i guess) would be the posibility to create a library part from a board.
With this option you can build your own blocks that are specific for an operation.
In this way users can save many time, dont have to design/route things twice.
Maybe it would be better to create a new library for this option.
Users could create parts like a +5VDC  supply (included layout & standard parts) or whatever you use often.
I´ve already done this by cutting from a board and pasting into a package.
The problem is here that the pad & holes cannot be added.
Another problem are the endless drc errors created by this method.
An exclude from drc check would solve the problem too and be in lot of situations usefull i guess.
Hope the idea is clear.
Greetings,
Bram
    Hi Jorge,
    Thanks for the quick reply.
    Guess i have to wait a bit longer.
    Just checked out the beta version.
    Think the XML structure breaks the projects open and makes it accesable to all kinds of software.
    This could be enough allready to do such jobs.
    Grtz,
    Bram
    On 11/17/2011 10:32 AM, Bram Herck, van wrote:
    Hello Bram,
    What your referring to is the idea of hierarchy, being able to treat
    parts of a design or a single design as a block which can then be
    incorporated into other designs.
    With the release of V6 we will be taking the first steps in this
    direction with the Paste From feature. What this allows you to do is to
    import an existing board/schematic into your design as a unit
    maintaining consistency. So in your example if you already have a +5VDC
    supply designed all you have to do is use the Paste From feature to
    bring it into your design.
    Now it's not quite perfect because you can't define ports and the design
    and really black box it. It's more like a Cut-Paste without the DRC errors.
    Now that we have an XML file structure, future releases of V6 should
    improve the feature till a hierarchical workflow is fully supported.
    hth,
    Jorge Garcia
