EAGLE User Support (English) Text rotation and reading direction
  • Subscribers 187 subscribers
  • Views 932 views
I have some text at angle 270 that reads bottom to top and when I rotate it
to 275 it flips to read top to bottom.  I've tried using the Spin check box
for it and it still reads top to bottom.  How can I force it to read bottom
to top at 271º+?
  • Richard_H
    Richard_H over 14 years ago
    Am 19.11.2011 19:29, schrieb FarrAwway:
    to top at 271º+?
    This can't be done in the current EAGLE version. The spin flag
    allows you to have text rotated in any angle (the automatic correction
    so that text is readable from the bottom or right of the drawing will
    be switched off), but it does not change the reading direction.
    There will be an option to change the reading direction (from
    bottom to top or vice versa) for a drawing in general in new version 6.
    Richard Hammerl
