EAGLE User Support (English) Re: quick question from a customer who received the files in Eagle format
  • Views 115 views
On 11/21/2011 2:38 PM, eSilviu wrote:
"Jorge Garcia"<jorge@cadsoftusa.com>  wrote in message
news:jae950$krg$3@cheetah.cadsoft.de...
>> On 11/21/2011 9:15 AM, eSilviu wrote:
>>> Question 2:
>>> How do I measure clearance betweem two IC pads?
>>> There is a quick answer? Why?
>> Hi eSilviu,
>> See Jerome's response, or use the dimension tool in V6 once it's released.
>> Best Regards,
>> Jorge
Those two are REAL QUESTIONS, that needs answer in max 24h... not half year.
I can't answer my customer with "RTFM" or "Wait 1 year, maybe Cadsoft will
implement a ruller "
Hello eSilviu,
You could also set the grid to a small increment (1mil or whatever is
convenient), use the mark command to place a relative origin at one end
of what you want to measure and then take your mouse cursor to the other
point, you can then read off the distance directly by looking at the
relative mouse coordinates.
This is a reasonable solution that doesn't involve counting squares, or
some sort of wacky workaround.
Best Regards,
Jorge
  • kcadsoft
    kcadsoft over 14 years ago
    >>> Question 2:
    >> Hi eSilviu,
    >> Best Regards,
    >> Jorge
    You do know that this is the suggest forum, right?
    We have a support forum for support questions image
    If you want to measure the distance between two points in EAGLE, the
    MARK command is what you should use, as Jorge has suggested.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
