EAGLE User Support (English) text size
  • Subscribers 189 subscribers
  • Views 352 views
text size
hello everyone,how is it possible to make smaller text (for pins) when
building a symbol,to build a device?My text is too big ,and different
text for different pins write over each other ,making the whole unreadable.
thanks
best regards
a.nierveze
I use the last version of eagle (v5)in freeware mode
Alain Nierveze
492 allée Montesquieu
33290 Le Pian Medoc
France
nierveze@radio-astronomie.com
www.radio-astronomie.com
    in the lbr-editor it is not possible to change the internal position & size
    of the text. long on the wishlist, but never implemeted image
    workaround: select visible & click select none (tip: group before & then
    Ctrl+right mousebutton). use the text-button & type the text. move the text
    to the pin.
    Advantage: you can change the position, size & ratio.
    Disadvantage: you must keep track if changes occur.
    r
    e14 Contributor over 14 years ago in reply to Morosh
    hello,thanks for your answer,I opened the library,opened the symbol,cliked
    'change size' and clicked a smaller size,clicked on the text symbol,retyped
    the text,ok...no change!!!
    well I missed something???
    thanks for the help,best regards
    a.nierveze
    "Maurice SAAB" <morisaab@yahoo.fr> a écrit dans le message de news:
    jagt2l$js5$1@cheetah.cadsoft.de...
    >> unreadable.
    >> thanks
    >> best regards
    >> a.nierveze
    type(or click): change size <new_size>;
    M.
  • Morosh
    Morosh over 14 years ago
    thanks
    best regards
    a.nierveze
    type(or click): change size ;
    M.
