EAGLE User Support (English) DRC clearance errors on unrouted board
  • Views 1795 views
I placed all components onto my board, and ran a DRC on the unrouted board.
It shows tons of  clearance errors. It seems that most of my components do
not fulfil the design rules, but I thinkthey should conform with them.
Example: a simple 0805 cap has according to DRC not enough clearance between
its own pads, although there is 0.4 mm of space there while all clearance
settings are set to 0.2 mm (DRC Clearance tab). Surprisingly enough, when I
set all clearances to 0, the problem remains the same.
I experience the very same with many imported and personally made
components.
Please help me because I am pretty stuck.
Pepe
    Warren, a review of specs in net classes solved the problem! Thank you very
    much for your help!
    Pepe
    Pepe wrote:
    Hello, thanks for your answer!
    This is a 2 layer board, all components are placed on top, and all
    errors of this kind are on layer 1.
    The full space between the capacitors pads is highlighted but not the
    pads themselves. Another similar example is an SOT143B package, while
    both libraries were taken from Cadsoft. Another interesting case is a
    USB mini receptacle with 5 identical, equally spaced smd pads (self
    made) and Eagle seems to be complaining only about one pair of them
    (see attachment).
    The error message is in the usual dialog box, it says "Error (121) -
    Clearance" layer 1.
    All edit boxes in the Clearance tab of DRC are set to 0.2 mm (9 x 0,2
    mm) and all problematic areas are larger/wider.
    I also tried changing the clearance settings to unrealistically small
    values (e.g: 9 x 0.01 mm) but the number of errors and the errors
    themselves (highlighted space too) remained unchanged.
    Any idea/suggestion?
    Pepe
    As well as the DRC clearances on DRC/Clearance  you need to check the
    clearance requirements of NET CLASSES. If  they are larger than the DRC
    setting the DRC will use those values.
    HTH
    Warren
    news.cadsoft.de
    This is a 2 layer board, all components are placed on top, and all errors of
    The full space between the capacitors pads is highlighted but not the pads
    themselves. Another similar example is an SOT143B package, while both
    libraries were taken from Cadsoft. Another interesting case is a USB mini
    receptacle with 5 identical, equally spaced smd pads (self made) and Eagle
    seems to be complaining only about one pair of them (see attachment).
    Clearance" layer 1.
    All edit boxes in the Clearance tab of DRC are set to 0.2 mm (9 x 0,2 mm)
    I also tried changing the clearance settings to unrealistically small values
    (e.g: 9 x 0.01 mm) but the number of errors and the errors themselves
    Pepe
    M_]C_X `02D9)1@`!`0```0`!``#_VP!#`! +# X,"A .#0X2$1 3&"D;&!86
    M&#(D)AXI.S0^/3HT.3A!25Y004591C@Y4F]366%D:6II/T]S>W)F>EYG:67_
    MVP!#`1$2$A@5&# ;&S!E0SE#965E965E965E965E965E965E965E965E965E
    M965E965E965E965E965E965E965E967_P `1" &9`3X#`2(``A$!`Q$!_\0`
    M'P```04!`0$!`0$```````````$"`P0%!@7J#A(6&AXB)BI*3E)66EYB9FJ*CI*6FIZBIJK*SM6VM[BYNL#Q,7&
    MQ\C)RM+3U-76U]C9VN'BX3EYN?HZ>KQ\O/T]?;W/GZ_\0`'P$``P$!`0$!
    M`0$!`0````````$"`P0%!@<("0H+_\0`M1$``@$"! 0#! <%! 0``0)W``$"
    M`Q$$!2$Q!A)!40=A<1,B,H$(%$*1H;'!"2,S4O 58G+1"A8D-.$E\1<8&1HF
    M)R@I*C4V-S@Y.D-$149'2$E*4U155E=865IC9&5F9VAI:G-T=79W>'EZ@H.$
    MA8:'B(F*DI.4E9:7F)F:HJ.DI::GJ*FJLK.TM;:WN+FZPL/$Q<;'R,G*TM/4
    MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W/GZ_]H`# ,!``(1`Q$`/P#SBBB@ HH
    MHH *FC=7013'`'W'_N?_`%OY=1W!AHI-7 =(C1N4<8(IM3Q,LL?DR$ @?NF)
    MQ@YZ$^AY_'TYJ%E9&*L"K X((Y!H3 2BBBF 4444`%%%% !1110`4444`%%%
    M% !1110`4444`%%%% !1110`4444`%%%% !1110`4444`%%%% !1110`4444
    M`%%%% !1110`5.K+.HCD(60#".3P1_=/]#VZ'CI!12: 5E9&*L"K`X((Y!I*
    ML#_2D1!_KD&U?^F@[#ZCH/48';FO0F 4444P"BBB@ HHHH **** "BBB@ HH
    MHH **** "BBB@ HHHH **** "BBB@ HHHH **** "BBB@ HHHH **** "BBB
    M@ HHHH **** "K'_`!]_]?'_`*,_^R_G]>M>E5F1@RDJP.00>0:30"45.RK.
    MIDC 60#+H!P1_>']1VZCCI!0F 4444P"BBB@`HHHH **** "BBB@`HHHH **
    M** "BBB@`HHHH **** "BBB@`HHHH **** "BBB@`HHHH **** "BBB@`HHH
    MH **** %5F1@RDJP.00>0:F=5FB:9 %92/,4#CG^(#L/7T)'K@04Z-VC<.AP
    M12: ;14TB*Z&6$8`^^G]S_ZW\NA[$PT)W ****8!1110`4444 %%%% !1110
    M`4444 %%%% !1110`4444 %%%% !1110`4444 %%%% !1110`4444 %%%% !
    M1110`4444 %%%% #HW:-PZ'!%23HI FA'[ML`C^XV.1_/'M[@U#3XI6B;( (
    M(PRGHP]#2:Z@,HJ66)0OFQ$F(G'/53Z'_'O^8$5-.X!1110`4444`%%%% !1
    M110`4444`%%%% !1110`4444`%%%% !1110`4444`%%%% !1110`4444`%%%
    M% !1110`4444`%%%% !1110!)!Y4@)&Y#PZ9^\.X_S]:)8OPRG=&WW6QU]
    MCZ'V_I@U'4D4OEY5ANC;[RYZ^X]#[_TR*3[H".BKXM56)75%EC<$B1FV\C/&
    M,^P_7MS411>T4 SR,R]/;K2YD:>S=KE6BK11>T4`SR,R]/;K047M% ,\C,O3
    MVZT[A[-E6BK11>T4`SR,R]/;K047M% ,\C,O3VZT7#V;*M%6BB]HH!GD9EZ>
    MW6@HO:* 9Y&9>GMUHN'LV5:*M%%[10#/(S+T]NM!1>T4`SR,R]/;K1</9LJT
    M5:*+VB@&>1F7I[=:"B]HH!GD9EZ>W6BX>S95HJT47M% ,\C,O3VZT%%[10#/
    M(ST]NM%P]FRK15HHO:`9Y&9>GMUHVB@&>1F7I[=:+A[-E6BK11>T4 SR
    M,R]/;K047M% ,\C,O3VZT7#V;*M%76A0QY$2*"I.1)G'7CKST'ZU2H3N3*+B
    M%%%%,D**** '2(T;E'&"*;4T;JZ"*8X`^X_]S_ZW\NH[@QR(T;E'&"*28#:*
    M**8!1110`4444 %%%% !1110`4444 %%%% %ZWD`B6-P3&\9R1_"1OP?KR>/
    MK]14EB:)L$@@C*L.C#U%3(/EC.#_`*IN>W\51Q2J%\J4$Q$YXZJ?4?X=_P`B
    M)V=S26R(J*?+$T,A1B#P"".A!&0?R-,JC,**** "BBB@`HHHH **** "BBB@
    M`HHHH **** #Y8S@_ZIN>W\55JLH/EC.#_`IN>W\55J2-);^NP4444S,
    M****`"IHW5T$4QP!]Q_[G_UOY=1W!AI\,,EQ,L4*%W8X`%)JX#DMIGN1;I&6
    ME8X"CO[Y],<YZ8K47PS?,H)>!21G!8Y'Z5T&D:<FGVRJY$DN.7Q]WO@>V:BO
    MM<M*X,B1R!U0`C\R?:A/N!B_\`",7O_/6W_P"F_PH_P"$8O?>MO_`-]-
    M_A6E_P`)/9?
    KC_`+Y7_&C_`(2>R_YY7'_?*_XTP,W_`(1B]_YZV_\`WTW^
    M%'_",7O_`#UM_P#OIO\`"NFL[IVU2XB#!'S@-UX./Z52O->M;*Z>WECFIC
    M)4#'(SZ] &-_P`(Q>_\];?_`+Z;_"C_`(1B]_YZV_\`WTW%:7_``D]E_SR
    MN/\`OE?\:/\`A)[+_GE<?]\K_C0!@WVD7EBI>6,-$"!YB'(Y_6J-=_;7,&H6
    MOF1D/&XPRL.GJ"*YW6=!^RH;BTW-$,ET/)7W'M_GZ &%1110`4444 64'RQG
    M!_U3<]OXJK590?&<'_5-SV_BJM21I9?UV)HW5T$4QP!]Q_[G_UOY=1W!CD
    M1HW*.,$4(C.<(I8^@&:LQ0RRJ(98W& ?+<J?E/I]"?RSGURGH0DV5**E-M.I
    M(,,@(X(*&DSS?\`/&3_`+Y-.Z'ROL1T5)]GF_YXR?\`?)HSS?
    9/^^31<
    M.5]B.BI/L\W_`#QD_P"31]GF_YXR?\`?)HN'*Q'14GV>;_`)XR?]\FC[/-
    M_P`\9/\`ODT7#E?8CHJ3[/-_SQD_[Y-'V>;_`)XR?]\FBX<K[$=%2?9YO^>,
    MG_?)HSS?
    9/
    ^31<.5]B.BG/&\>-Z,N>F1BFTR;6+*#Y8S@_ZIN>W\55JL
    MH/EC.#_JFY[?Q56I(TELOZ[!1113,PHHHH 559V"J"S,< `9)-=KI&E1Z=#D
    MX>=A\[_T'M_.N2TW_D)6O_79/YBNVU!F33[EE)5EB8@@X(.#0!D:[K?D[K2T
    M;]YT>0?PP]_Y?7ISD4JA?*E!,1.>.JGU''?\B(J*&K@/EB:)L$@@C*L.C#
    MU%,J6*50OE2@F(G/'53ZC_#O^1#98FB;!(((RK#HP]123Z,#LO#W_(%M_P#@
    M7_H1KG/$/_(:N/\`@/\`Z"*Z/P]_R!;?_@7_`*$:YSQ#_P`AJX_X#_Z"*8&;
    M1110!;TW4)M.N/,BY4\.A/##_'WKL[*M[(O;OG&-RD8*_6N!K:\*?\A*3_
    M`*XG:T`.\1:5':$74&%CD;:8_0]>/;C_/;#KK/%?_(-C_Z[#35R= !1110
    M!90?&<'_5-SV_BJM5E!\L9P?]4W/;*JU)&DME_78NZ7_Q\M_N'8K4KTO
    M_CY;_</\Q6I64]SMPWP$H(E 5B XX5CW]C_C_D1D%20001P0:2IA^^0+_P`M
    M%Z?[0]/K_GTK/8WV(:***H84444`%%%%`!1110`4444`9^K?\LOQ_I6=6CJW
    M_+\?Z5G5M#8\S$?Q&64'RQG!_U3<]OXJK590?&<'_5-SV_BJM31,ME_78*
    M***9F%%%% '=PZ9X>U^ZBN="G%E>K*KM:3':& 8DX'/.!GY20 `,#-6-:MIK
    M73[I9XV0F%\9Z'Y>QKAM+8KJEHRDAA,A!';YA7I3ZNAL9HM5B^U6HC;>`/GQ
    MM['(: /*Z*["^\)6NIH;OPI=QW475[9WPZ$MQC.,#K][!XZG-<G/!-
    M;3-#<120RK]Y)%*L._(-`$=2Q3LB67A)R4SQGU'H??^G%144-7`[?0E5='
    MM]C;U^;#8Q_$?UKFO$/_`"&KC_@/_H(KI/#IQHMOW!W<?\"-<[XCC9=8F?\`
    MA;;@_P# 1M+R8&71113`*VO"G_(2D_ZXG:UBUM>%/^0E)_UQ/\UH TO%?_
    M`"#8_P#KL/Y-7)UUGBO_`)!L?_78?R:N3H **** +*#Y8S@_ZIN>W\55JLH/
    MEC.#_JFY[?Q56I(TELOZ[%W2_P#CY;_</\Q6I6;HL?FWXCSC>-N?3)%=5_8?
    M_3Q_XY_]>LY)MG70G&,-3'HK8_L/_IX_\<_^O1_8?_3Q_P".?_7J>5FOM8=S
    M-_U__77_`-#_`/K_`,_KUAK8_L/_`*>/_'/_`*]/DT7S&_:/F/?)U/KUI<
    MK0>UAW,2BMCP_\`IX_\<_\`KT?V'_T\?.?_7I\K#VL.YCT5L?V'_T\?^.?
    M_7H_L/\`Z>/_`!S_`.O1RL/:P[F/16Q_8?\`T\?^.?\`UZ/[#_Z>/_'/_KT<
    MK#VL.YCT5L?V'_T\?.?_7H_L/\`Z>/_`!S_`.O1RL/:P[G+ZM_RR_'E9U:
    M_B&#[-A!KE9O#VH1S,L<0E0'APP&1]": -'5O!MW K76DLNI6#$^6\#!W SCD#K
    MSD?GH2<5SD,,EQ,L4*%W8X`%=#I'_"2:)NL@RH3EHFD4HW3.1GV R,'WKM
    M8ETW4F%Q=I':ZF\:K+,G"L0/?M]<'@#/% &'IEJUE816[,&9`<D=,DD_UKE]
    M:G4:S=#B2)BH90>X4#KV(Y_SD5TWBZ+4=)@*PP2&%NMT@RJC@?\``2<CK^&>
    MW"4;@22Q>7AE.Z-ONMCK['T/M_3!J.I(IGBR%.4;[R'[K?44LL2A?-B),1..
    M>JGT/^/?\P%Z@15U'AS2[BUE>YN%\O<FU4/7G!R?3ITHT+1/)VW=VO[SJD9_
    MA]S[_P`OKTT]2U"'3K?S)>6/"(#RQ_P]Z8&?XK91I\2Y&XR@@9Y(P?\`$5RE
    M3WEW->W#33MECT'8#T'M4% !1110!90?+&<'_5-SV_BJM5E!\L9P?]4W/;^*
    MJU)&DME_78TO#_\`R%8OJ/\`T(5WU<#X?_Y"L7U'_H0KOJ74M?"@HHHH`***
    M* %Z\TE'2EQGI^53L E%'3K13 ****8!1110!Q?BS_D(_P"?1:PZW/%G_(1_
    MSZ6'3CL15^[OR+*#Y8S@_ZIN>W\55JLH/EC.#_`*IN>W\55J$$ME_78***
    M*9F%%%% !1110!KZ)K6""<EK9C]2A]1[>W^3O?V]IG_/S_`.0V_P`*XJB@
    M#M?[>TS_`)?_(;?X5G:OX@0P3I[DEA\TN"-H]!GO[_`.1S=% &]H'BW4=#
    M588V6>T!SY$G;)!.T]1W]1R3BMA='\/^*(Q)I%PNG:BPRUHYRI;YB0/RZKP`
    M/NBN)HH`N:EI5]I4PBO[:2!C]TMRK=.A'!ZCI4=C<_9;R*8Y*JP+@#.1D''Z
    M5T6G^-9S:FPUR!=1LI $8MQ(!QW[XP3SSGG=5B]\)66IV[WGA6\6Z (W6K,`
    MRY)[G!'3@-U )R: $O=>M8[-IK1O.8G:!M("GW_SS^>.1FFDN)FEF<N['))J
    M1TGL;AHIX7CD`P\4JE20><$'GT/Y&FRQ*%\V(DQ$XYZJ?0_X]_S 6P$5%%%,
    M`HHHH LH/EC.#_JFY[?Q56JR@^6,X/\`JFY[?Q56I(TELOZ[&EX?_P"0K%]1
    M_P"A"NK@?#_`/R%8OJ/_0A7?4NI:%!1110`4444 %%%% "Y([T9'<?E245
    M/*@%P/7\Z-I],_2DHHLX!12[CWYM'![8^E%WV XKQ9_P`A'_/HM8==%XH@
    M$FH?-&&[(QVD\#N>/UK"EMIX5W21.J$X#X4_0]#3BT14[OR)$'RQG!_U
    M3<]OXJK590?+&<'_`%3<]OXJK52"6R_KL%%%%,S"BBB@`HHHH **T=(TJ349
    MLG*0*?G?@]_Y5T:Z!IJJ 8"Q QDNV3M '%T5VO]@Z9_P`^W_D1O\:Q]9T'
    M[*AN+3<T0R70\E?<>W^?H 85%%% !4UI=3V-U'<VLK131G*NO;_/I4-%`'90
    M>*-/UV!+Q3;A ?+O(<AD.,9('KUXXSCY>*@U/PE>60%[H4QU&RD!^:'#,!
    MNQM('WQZX]#D"N4K<\)7E_::L/L,YC1@#,I *LH/0@_ED<C)H R9$5T,L(P!
    M]]/[G_UOY=#V)AKTS5(-$U=A<7\BZ;?M\BW(/RN=IX;/!'L>2 !GM7*>)?"E
    MYHG[_:);4GF2,$A.<#.>F>/7KC)ZE; <]1113 LH/EC.#_JFY[?Q56JR@^6,
    MX/\`JFY[?Q56I(TELOZ[&EX?_P"0K%]1_P"A"N^K@?#_`/R%8OJ/_0A7?4NI
    M:%!1110`4444 %%%% !1110`4444 %%%% '%+/^0C_`)]%K&BFEA;=%(\;
    M$8RK$'%;/BS_`)"/?1:PZ%L15[OR-%IF5#%'^[;EEP<_-U(P2?Q]:K
    M?Z&__/>'TDS_P"@X_6E0?&<'_5-SV_BJM245T"6R+'V1F_U,L4OZ"3Z
    M-@G\!44L,L+;98WC8C.&4@XIE2Q7,T*[$<["<E#RI/N#P:>IF1458^T1O_KK
    M:,D]6C1OP_A'Y?XT>7;/]RX:,]<2IP/;*YS0HOW KU>TC3FU*ZV$E8D&78
    M#MZ#W/\`C52")IYXX5(#2,%!/3).*?4DU0#E6&RM<
    M*!'#$I. .@')KEKSQ%>27#&V?R8NBKM!)]SGO2:WK+7S&" E;93]"Y]3[>W^
    M1D4`::Z_J2L"9PP!S@HN#E=1INH0ZC;9%PPX=">5/^'O7"5/9W<UE<+- V
    M&'4=B/0^U &QKNB>3NN[1?W?5XQ_#[CV_E].F!7=Z;J$.HV_F1<,.'0GE3_A
    M[UAZ[HGD[KNT7]WU>,?P^X]OY?3H`8%%%% !6UX4_P"0E)_UQ/\`-:Q:VO"G
    M_(2D_P"N)_FM`&EXK_Y!L?\`UV'\FJ]\--1NWOY=.>=FM$@:18R =K;E'!ZC
    MJ>.G-4?%?_(-C_Z[#35)\,?1AN/O1O_0TH F_X6#K$D>"ULVVCYU\MR5
    M]_O=/?MT/8F'_A8^L?\`/M8_]\/_`/%5R"LR,&4E6!R"#R#4_E_:@7B4"11E
    MT' Q_>']17'2;VW&E?8ZY?B%JQ53]FL4+$['P"-W^U[?SJ)?B)K3YVVEDV
    M/2-S_P"S5S<:JJ1O@L!&PW=C][@"J[,TGSR'"#H!_(47-G322N=K:>/-8ED(
    MDMK$#'96SGC_`&JZ3_A(9LX\M<^GEM7EME,L<QDE.U-NT<?I7?>8J?*ARQY)
    M/\S4WE<T4:?O\RA--2YXVG_??\`Q5'_``FFI?\`/&T_[Y;_`.KE/MM
    MOMW>9QG'W31]MM]N[S.,X^Z:B\SJY,/_`$SJ_P#A--2_YXVG_?+?_%4?\)IJ
    M7_/&T_[Y;_XJN4VVW=YG&<?=-'VVWV[O,XSC[IHO,.3#_TSJ_^$TU+_GC:
    M?]\M_P#%4?\`"::E_P`\;3_OEO\`XJN4VVW=YG&<?=-3+=6IL992QRLB*&
    MVMCD,2/T%%YBY,/_`$SI?^$TU+_GC:?]\M_\51_PFFI?
    ;3_OEO_BJY3[;;
    M[=WF<9Q]TT?;;?;N\SC./NFB\Q\F'_IG5_\`"::E_P`\;3_OEO\`XJC_`(33
    M4O\`GC:?]\M_\57*?;;?;N\SC./NFC[;;[=WF<9Q]TT7F')A_P"F=7_PFFI?
    M
    ;3_OEO_BJV?$AFSCRUSZ>6U>=_;;?;N\SC./NFNP\Q45#ECR2?YFJBY=
    M3&K&CIR_F4;SQWJT.SRX$YSG<&'_LU56^(>MH,M9V:CWB?_`.*KG^6*A]J[33=0AU&W\R+AAPZ$\J?\`#WKA*GL[N:RN%F@;##J.Q'H?:@#8UW1/
    M)W7=HO[OJ\8_A]Q[?RG3 KN]-U"'4;?S(N&'#H3RI_P]ZP]=T3R=UW:+[Z
    MO&/X?<>W\OIT`,"MKPI_R$I/^N)_FM8M;7A3_D)2?]<3_-: -+Q7_P`@V/\`
    MZ[#35)\,?\`D8;C_KT;_P!#2H_%?_(-C_Z[#35)\,?1AN/O1O_0TH X\
    M`DX`R34V?+8%6JAX93R6'H?\XI(]H1FSR."!V'^?R_F_>9%'``_D*EZF
    MJ5EZE_8MQ&MP$",L3;D7@$?-]WH[=?I0]\S\*.`!_(5:B+#RI@"NV-L%3C
    M!;@>]-\O[9\C3#C@Q(/O?[H_F.W7V$K0TELBO][YGX4< #^0KT'[ORKRQY
    M)/\`,UY]][YGX4<`#0KT'[ORKRQY)/\S5&9Y]][YGX4< #0H^]\S\*. !_
    M(4?>9%' `_D/O?,_"C@`?R% !][YGX4<`#0H]\S\. !_(4?>9%'
    M`_DLA+)XU>2XN%/`B!<#U ._\`I_.@"M][YGX4< #^0JW&P;2K@OD+Y\6
    M!QPLG .AH[!AO-S<[00`/LZCCT'SU85;$Z9/I%SL\^+_EW`Z!^!\Y[$G_]
    M= &9][YGX4<`#0H]\S\*. !_(5;:.P8;S<W.T$`#[.HX]!\]-E2R,9=;BX
    M)'"J8%4'VSO/\J WWOF?A1P`/Y"C[WS/PHX`'\A1][YGX4<`#0H]\S\.
    M`!_(4 'WOF?A1P`/Y"O0?N_O+'DD_S->??>9%' `_D]!^[\J\L>23_,T
    M`>??>9%' `_D*/O?,_"C@`?R%'WOF?A1P`/Y"C[WS/PHX`'\A0!90;E20K
    MA1&PXX'\7%0*=P/F';&>!@=#[?G_`)-3H-RI(5PHC8<<#^+BJWWOF?A1P /Y
    M"D:-VL-8%3@]:Z_QI_R+WAC_`*]/_9(ZY-SOC#D`$':,=Q_];BNL\:?\B]X8
    M_P"O3_V2.J1A))/0X^BBBF26=-_Y"5K_`-=D_F*<7_`)&N#CD:
    M*5)$.'0AE/H17<Z;J$.HV_F1<,.'0GE3_A[T`<)16_KNB>3NN[1?W?5XQ_#[
    MCV_E].F!0 4444 %%%% $]G=S65PLT#88=1V(]#[5VFFZA#J-OYD7##AT)Y4
    M_P"'O7"5/9W<UE<+- V&'4=B/0^U`&QKNB>3NN[1?W?5XQ_#[CV_E].D7A3_
    M`)"4G_7$_P`UKH=-U"'4;?S(N&'#H3RI_P`/>HK;2H[34WNH,+')&5,?H<@\
    M>W'>P!5\5_\@V/_`*[#35)\,?1AN/O1O_0TJ/Q7_`,@V/_KL/Y-4GPQ_
    MY&&X_P"O1O\`T-* .11MK9QD=QZBGNOS;F/[L?=QW'M45.5MN> 0>H-)HN,M
    M,M(-RI(5PHC8<<#^BJWWOF?A1P`/Y"K:H)-CJI($;#`[?>X_\`K^U5/O?,
    M_"C@`?R%2C::T1/_`,?>"P/FYQP?]9WP,_Q?SSZ]>Z^[\J\L>23_`#-<+:0"
    MZE(DRJ@<;?Y5Z 8E'RIDR'DD_P`S2O87*VKGG'WOF?A1P /Y"C[WS/PHX '\
    MA6FVG0L<EG '0 CC]*&TZ%CDLX Z`$<?I1SHT^KS,S[WS/PHX '\A1][YGX4
    M< #0K3;3H6.2S@#H 1QE#:="QR6< =`"./THYT'U>9F?>9%'``_D*MQL
    M&TJXY"^?%@`<<)P/SJPVG0L<EG`'0`CC]*LK8PG3IU+28,T9&.@P']O>CG
    M0?5YF'][YGX4< #0H]\S\*. !_(5IMIT')9P!T (X_2AM.A8Y. .@!''
    MZ4<Z#ZO,S/O?,_"C@ ?R%'WOF?A1P /Y"M-M.A8Y. .@!''Z4-IT')9P!T
    M`(X_2CG0?5YF9][YGX4<`#^0KT'[ORKRQY)/\S7(MIT+')9P!T (X_2NS,2K
    M\J$ECR2?YFFI)DRI2CN><_>9%'``_D/O?,_"C@ ?R%6KZVCA,&;:<\9_
    M055^]\S\*. !_(4T[D2BXNS+#<J2%<(V''`_BXJ!5,AW-\J#_.*L(FX([J
    M541-TXX;@>]59)-_"C:HZ"DO(N=DDY?\.$KAW484<*/05UOC3_`)%[PQ_U
    MZ?\`LD=<?78>-/\`D7O#'_7I_P"R1U:T.9MMW9Q]%%% @J>SNYK*X6:!L,.H
    M[$>A]J@HH >/;C_
    M`#VRK.[FLKA9H&PPZCL1Z'VJQJ.KW.HQ+',(U13NP@ZG\3]:`*%%%% !1110
    M`4444 3V=W-97"S0-AAU'8CT/M7::;J$.HV_F1<,.'0GE3_A[UPE3V=W-97"
    MS0-AAU'8CT/M0!TOBO\`Y!L?_78?R:I/AC_R,-Q_UZ-_Z&E<]J.KW.HQ+',(
    MU13NP@ZG\3]:BT[4;O2[H7-C.T,H!7(`.0>Q!X/XT 3?V%K'_0*OO_ =_P#"
    MC^PM8_Z!5]_X#O\`X5H?\)MXB_Z"'_D&/_XFC_A-O$7_`$$/_(,?_P`30!77
    M1-5Q'G2[[(B8?ZAN/O<=/I47]CZR?OZ3>O\`[UN_
    5J+XRU\JA^W'E&)/DQ
    MXS\W^S[#\J@_X3;Q%_T$/_(,?_Q-R-'20FGZ/JIN,-I-U'\N 3`X'4>O%=
    MD-/NESA+GDY/[O\`M7.:/XOUVYU".*:W(2,CRD'<>BUUW]J7O_`#V_\='^
    M%397-54GRK8YHZ%JCJ6:RF\SKR/O?_7_`,_5G]@ZK_SX2_E74?VI>_\`/;_Q
    MT?X4HU2\_P">W_CH_P`CDBC7ZS4\CEO[!U7_GPE_C^P=5_Y\)?RKJ/[4O?
    M>W_`(Z/\*/[4O?>W_CH_PI\D0LU/(Y?\`L'5??"7\J/[!U7_`)\)?RKJ
    M/[4O?>W_CH_PH_M2]_Y[?\`CH_PHY$'UFIY'+_V#JO_`#X2_E1_8.J_\$O
    MY5U']J7O_/;_`,='%']J7O_`#V_\='%'(@LU/(Y?P=5_Y\)?RH_L'5?^
    M?"7\JZCU+W_`)[?.C_``H_M2]_Y[?.C_"CD0?6:GD<O\`V#JO_/A+5;H
    MTZ7.$N>3D_N_P#ZU6_[4O?>W_CH_PH_M2]_P">W_CH_P`*:BD3.M.6]CA=
    M4T750T:C2KF0C.=L+L!T[BJ)TC6>-ND7J8&,K;/_`(5T/B'Q5K5E>^7;7NQ?
    M3RD/8>H]ZRO$V\1?]!#_P`@Q_\`Q-5%*QE5J3<FV5QHFK'86TN+>6V3Y#_
    M`.U[>XJO_86L?] J\``=\*UU\9:50_;CRC$GR8\9;_9]A50?\`";>(
    MO^@A_P"08_\`XFFC.5[YG_V%K'_`$"K[_P'?_"NB\<1O%H7AJ.1&1TMBKP
    MP00L>016;_PFWB`*"'D&/_P")K-U36-0UB2.34EIC&,(,!0/7@`#\?8>
    ME,@HT444`%%%% !1110`4444`%%%% !1110`4444`%%%% !1110!90?+&<'_
    M`%3<]OXJK590?&<'_5-SV_BJM21I9?UV-P_\`\A6ZC_T(5WU<#X?_P"0
    MK%]1_P"A"N^I=2U\*"BBB@!>OUI*7K]:G8!*.E%, HHHI@%%%%`!1110!Q
    M?BS_`)"/?1:PZW/%G_(1_SZ+6'3CL15[OR#Y8S@_P"J;GM_%5:K#Y8
    MS@_ZIN>W\55J$$ME_78****9F%%%% !116_H6B>=MN[M?W?5(S_%[GV_G].H
    M`:%HGG;;N[7]WU2,_P`7N?;^?TZS>*+>VBM(72.-)=X4;1@E0/U P/I6MJ6H
    M0Z=;9+RQX1 >6/'O7%WEW->W#33MECT'8#T'M0!!1110`4444`%36BQM>0
    MK-CRC(H?)P,9YYJ&B@#M[S1[.YMVC6&.%NJO&@!!_J/:N1O;&XL)0EPF,YVL
    M#D-]UM"UOR=MI=M[Z)(?X?8W\OITZ&\M(;VW:&=<J>A[@^H]Z`//ZMZE
    MI\VG7'ER\J>4<#AA_C[54H **** +*#Y8S@_ZIN>W\55JLH/EC.#_JFY[?Q5
    M6I(TELOZ[&EX?_Y"L7U'_H0KOJX'P_\`\A6ZC_T(5WUJ6OA04444 %%%%
    M"^QI.E%GUYJ=M@$HI<9Z&DZ=:::8!1113 **** .\6?\A'_/HM8=;GBS_D
    M(_Y]%K#IQV(J_%]WY%E!\L9P?]4W/;*JU64'RQG!_U3<]OXJK4();+NP44
    M44S,***`)[-9;ZWC<91Y%5AZ@FN[N9?(MI9MN[RT+8SC.!FN&TW_D)6O\`
    MUV3^8KM=2_Y!MU_UQ?\`D: .(ON:]N&FG;'H.P'H/:H***`"BBB@`HHHH`
    M***`"NB\+WL\D[VLCEXECW+NYX(&![<]YVMKPI_R$I/\`KB?YK0!I>_^
    M0;'_`-=A_)JY.NL\5_\`(-C_`.NP_DU<G0`4444`64'RQG!_U3<]OXJK590?
    M&<'_5-SV_BJM21I9?UV-P_P#\A6ZC_T(5WU>?Z&XBU!9&SA<$X]B*Z_^
    MVK;Y+0_P`:ENS-81<H*QHT5G?VU;?W)?R'-']M6W]R7\A_C2NASEV-&B
    ML[VK;Y^0_QH_MJV_N2_D/\:H/9R[&C16=_;5M_<E_(?XT?VU;?W)?R'^
    M-%T'LY=C1I<FLWVK;Y^0_QH_MJV_N2_D/\:&TP]GL:7!]J""*S?[:MO[
    MDOY#_&@:W;CHDWY#_&E>VS#V<^QHT5G_`-MVQZQR_@!_C3QJD#@>6))#_=4#
    M(_#//X9HYUU#V<NQS'BS_D(_Y]%K#K9\2RB>\$BJR@Y&&&",`"L:KCL8U=)?
    M=190?+&<'_5-SV_BJM5E!\L9P?]4W/;*JU-!+9?UV"BBBF9A1110!9TW_D
    M)6O_`%V38KM=2_Y!MU_UQ?1KB=/94U"V9B%595)). !D5W-W$T]G-"I :2
    M-E!/3)&`//J?-#);S-%,A1U."#3* "BBB@`HHHH **** "MKPI_P`A*3_K
    MB?YK6+6]X4ADV2S[#Y0C*;NV<@X_2@"]XK_`.0;'_UV'\FKDZZSQ7_R#8_
    MNP_DU<G0`4444 64'RQG!_U3<]OXJK590?&<'_5-SV_BJM21I9?UV+NE_\
    M??[A_FUR]_X^6_W#_,5J5E/<[<-\`4445)T!1110`4444 %%%% !1110
    M`4444 5=3N"!"LD:3*,X#YXZ=""#^&<50\NWE_U4C1L>B2]/IN']0![U9U;_
    M`)9?C_2LZM(K30\RO_$9=:"2)8BZ'!B<!U(*G[W<<'\ZI5=@FDB1-A.TQ-N!
    MY4_?QD'@U%YEO+_K8VC8]7BZ?7:?Z$#VIIM$RV17HJ=K23:7C*3(!DF,Y('<
    MD=0/<BHI-,S"BBBF 5U7A_5VNO]$N3F51E')Y8>A]_\_7E:569&#2K*<@@
    MX(- ':ZOI4>HPY&$G4?(_P#0^W\JXIE9&L"K<$$8(-==HFLK?*()R%N5'T
    M#CU'O[?Y&C)9VLKEY;:%W/5F0$F@#SBN_L^R_Y\[?_`]_A1_9]E_SYV_
    M_?I?\* .!HKOO[/LO?.W_[]+_A1_9]E_P`=O\`]E_PH X&BN_L^R_P"?
    M.W_[]A19]E_SYV_\`WZ7_``H`Y2-*DU&;)RD"GYW_H/?^5=?_H]A:?PQ
    M01#\!_B?YTK-!96Q8[(88QG@8 "N/U?59-1FP,I`I^1/ZGWE0!/JFIMJ5I
    M,=NV))D$:]^C\GWK'JS'_P`@V?\`Z[1_R>JU`!1110!90?+&<'_5-SV_BJM5
    ME!\L9P?]4W/;^JU)&DME_78NZ7_`,?+?[A_FU*P8I7A8M&V"1CI4OVZY_Y
    MZ?\`CHJ)1;9O2KQA&S-FBL;[=<_\]/\`QT4?;KG_`)Z?.BER,UM0[,V:*Q
    MOMUS_P`]/_'11]NN?>G_CHHY&'UJ'9FS16-]NN?>G_`(Z*/MUS_P`]/_'1
    M1R,/K4.S-FBL;[=<_P#/3_QT4?;KG_GI_P".BCD8?6H=F;-%8WVZY_YZ?^.B
    MC[=<_P#/3_QT4<C#ZU#LS9HK&W7/_/3_P`=%'VZY_YZ?.BCD8?6H=F6=6_
    MY9?C_2LZI)IY)L>8V['3@"HZTBKQQU9<W)%E!\L9P?]4W/;^*JU64'RQG!
    M_P!4W/;^JU""6R_KLK,C!E)5@<@@\@U/\`:C)_Q\QK/_ML2'_,=?QSBJ]%
    M#29F6/(BEY@F4$_\LY3M/Y]/Q)'TJ6&6%MLL;QL1G#0<4RI8KB6)=JL"F<
    M[&4,N?7!XS[TM4!%1115`*K,C!E)5E.00<$&K']H7O\`S^7'_?UO\:K44 6?
    M[0O??RX_P"_K?XT?VA>_P#/Y<?]_6_QJM10!9_M"]_Y_C_`M_C1_:%[_
    M`,_EQ_W];_&JU% %GT+W_G\N/\`OZW-']H7O\`S^7'_?UO\:K44 6?[0O?
    M?RX_P"_K?XT?VA>_P#/Y<?]_6_QJM10!HI?7AT9OM4^X2Q@'S#D##_`. J
    MO_:%[_S7'_?UO\`&B/_`)!L_P#UVC_D]5J +/\`:%[_`,_EQ_W];_&CT+W
    M_G\N/_K?XU6HH T4OKS:AU7'K;GS#C+_``_2J$DCRN7E=G<]68Y)J=!\
    ML9P?]4W/;^JU)%RV04444R HHHH`*** "BBB@`HHHH`**** "BBB@`HHHH
    M`LH/EC.#_JFY[?Q56JR@6,X/J;GM_%5:DC26R_KL%%%%,S"BBB@ HHHH *
    M*** "BBB@ HHHH **** "BBB@"S'_P`@V?\`Z[1_R>JU68_^0;/_`-=H_P"3
    MU6H`***`+#Y8S@_P"J;GM_%5:KD+(8T^6,D(PRSX]>,9]Q32B]HH!GD9EZ
    M>W6IN;.-TK%6BK11>T4`SR,R]/;K047M% ,\C,O3VZT[D^S95HJT47M%`,\C
    M,O3VZT%%[10#/(ST]NM%P]FRK15HHO:* 9Y&9>GMUH*VB@&>1F7I[=:+A[
    M-E6BK11>T4 SR,R]/;K047M%`,\C,O3VZT7#V;*M%6BB]HH!GD9EZ>W6@HO:
    M* 9Y&9>GMUHN'LV5:M%%[10#/(S+T]NM!1>T4 SR,R]/;K1</9LJT5:+VB
    M@&>1F7I[=:"B]HH!GD9EZ>W6BX>S95HJT47M% ,\C,O3VZT%%[10#/(S+T]N
    MM%P]FQ$'RQG!_P!4W/;^JU769%0'9&,(PXDR5SNXZ\]15A!-6L@HHHIF84
    M444`%%%%`!1110`4444`%%%%`!1110`4444`3I(HL98R?G:1& ]@&S_,5!11
    M0 4444 %%%% !1110 4444 %%%% !1110 4444 %%%% !1110 4444 %%%%
    M!1110 4444 %%%% !1110 4444 %%%% !1110 4444 %%%% !1110 4444 %
    M%%% !1110 4444 %%%% !1110 4444 %%%% !1110 4444 %%%% !1110!__
    !V0``
    end
    M_]C_X `02D9)1@`!`0```0`!``#_VP!#`$,N,CHRD,Z-CI+1T-/99L9%Q<
    M9,R2FGFF\=3^NW4Z>7__________7I____________________________
    MVP!#`4=+2V179,1L;,3__^G_____________________________________
    M________________________________P `1" %_`2$#`2(``A$!`Q$!_\0`
    M'P```04!`0$!`0$```````````$"`P0%!@<("0H+_\0`M1 ``@$#`P($`P4%
    M! 0```%]`0(#``01!1(A,4$&$U%A!R)Q%#!D:$((TQP152T? D,V)R@@D*
    M%A7J#A(6&AXB)BI3E)66EYB9FJCI6FIZBIJKSM6VM[BYNL#Q,7&
    M)R@IC4V-S@Y.D-$149'2$E4U155E=865IC9&5F9VAI:G-T=79W>'EZ@H.$
    MA8:'B(FDI.4E9:7F)F:HJ.DI::GJFJLK.TM;:WN+FZPL/$Q<;'R,G*TM/4
    MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W^/GZ_]H`# ,!``(1`Q$`/P"A1110`444
    M4 %./**?J/\`/YTVG#E"/0@_Y_2@!M%%% !1110`4444`%%%% !1110`4444
    M`%%%% !1110`4444`%%%% !1110`4444`%%%% !1110`4444`%%%% !1110`
    M4444`%.3N/4'_&FT-6W=I(SZ4`,HIQC<'&QORH\M_[C?E0`VBELHR5(H
    MI* "BBB@`HH`). ,FG>6_P#<;\J &T4[RW_N-^5'EO\`W&_*@!M%%% !1110
    M`444H!8X`)E`"44[RW_`+C?E1Y;_P!QORH`;13BC@9*-5-H **** "BBB@
    M`HHHH **** "BBB@`HHHH **** "BBB@`JVL\>T<[?;'2JE%`%\.KD[3GO2/
    MB'#'!^E1VW9_#?-1W7^L'TH`DEFC,9 ^8GVJK110`4J@L0`,DTE7(HA$
    MN3U[F@`BB$2Y/7N://C_`WZ&H)IMYVK]W^=14 7//C_`WZ&E6:-B &Y-4J
    M* +,\.<N@Y[CUJM5F";.$<\]CZTEQ$,&0<>HH KT44JC<P`[G% `B%VVKUJX
    MBK"G7ZFA%6%.OU-5I93(?11T% %CSX_[WZ&CSX_[WZ&J=% %Y94<X5LFH)X<
    M9=!QW'I4`X.15N&;>-K?>_G0!4HJ:XB"?,O )Z5#0 4444 %%%% !1110 44
    M44 %%%% !1110 4444 %%%% %FT/RN/3%,NO]8/I3[/^/\*9=?ZP?2@"&BBB
    M@ J])_JVAJC5Z3_`%;?0T 4:***`"BBB@`IS2,X`9L@4VB@`IT?L7ZBFTJ
    MG:P/H<T`6[C_`%+?A_.J=7OEFC]C5.2,QM@].Q]:`&T444 %26_^N7\?Y5'4
    MEO\`ZY?Q_E0!-=?ZL?6JM6KK_5CZU5H`***`"BBB@`HHHH`***`"BBB@!V
    M%/0X/H?\:0J1U%)2AB.AH 2BG94]1@^U)L.,C!'M0 E%%!!!(/44`6+/JWX4
    MVZ_UHE.M/X_PIMW_K1]* (:*** "KTGK;Z&J-7I/\`5M]#0!1HHHH`****
    M`"BBB@`HHHH`='(8VR.G<>M6_DFC]0?TJE3D=D/RG&: +'V9/5J/LR>K5#Y\
    MG][]!1Y\G][]!0!-]F3U:G) J,&!.15?SY/[WZ"GPRNTH#-D'VH`?=?ZL?6J
    MM6KK_5CZU5H`***`"BBB@`HHHH`**`"BBB@!2O&1R/Y4E`)!R=@-TX/I
    M0 VCH<BBB@!V[/WAGWZ&G2+F1MIR<G@U'3I/]8WU- $]J""X(P>*;=CYU/MB
    MG6A.&&>!BBY /4XQCM("M12E2!DCCU[4E,`J])_JVAJC5]QN1@.XQ0!0HI
    M6!4D$8(I* "BBB@`HIT<9D; Z=SZ5++ $3<#G'7-`$%%%*HW, .YQ0`E%6&M
    MOE4Y/OWJN>#@T %%%% !4EO_KE_'51U-;(3(&["@"2Z_U8M5:M77K'UJ
    MK0`4444`%%%%`!1110`4444`%%%%`!15BXM6A&]3NC/0BH0$QRS?E_\`7H ,
    MAOO=?6FD$'FG83^\W_?/_P!>E!0#!+$?[O\`]>@!E2O#(SL0O!)INU,9#,1_
    MN]/UJPUPBL00W!Q0`EO&R;MPQG%$T;.YVC.5Q^M'VE/1J47*$@8-`%<QR1C<
    M1@4F0?O#'N/\*G>X4J5PP)XZ56H`=L)[\WTZU+!-C".>.Q]*@IV_/WAN]]
    M`%N6(2#T8=#5;R)/[OZBI(I@HVDY'OV_S^%/-PH."KCZB@"#R)/[OZBE6WD)
    M`(P/7-2_:4]&H^TIZ-0!( L2>@%5993(?11T%))TAYX'I3`"BBB@"S!-G"
    M.>>Q]:=-#O&Y?O?SJI4\=S@8<$^XH 9Y$G]W]11Y$G]W]14WVE/1J/M*>C4`
    M1I;N6^88%6"5B3T`J,W28X#57DD:0Y;\J "20R-D].P]*;110 4444 %%%%
    M!1110 4444 %%%% $UO<O;D[>5/534[00WE[8[6YRA[_P"'\OI5E5BIRI(
    M([@T`#HR,588(ZBDJXD\5R-ER K<8<<?Y_E]*AN62 Y(W_`'A_6@"$$@Y%
    M22 -(V.#D\>M1TZ3_6-]30`VBG9#?>ZM-((/- $H +L2.N#=.VKZ#\J1.5
    M!]L?Y_2G5)I'83:OH/RHVKZ#\J6B@H3:OH/RI1@#&!CTQ110%@VH>P'X4%!U
    MVC'KBB@''2@5B!OO'ZTE/8@L=R]HI-F?NG=[=ZHR&T4=#@T4 %%%% !4U?
    M0?E4%63B)M7T'Y4;5]!^512+$VKZ#\J-J^@_EHH`3:OH/RHVKZ#\J6B@
    M".0`P!UJ.I9?N_C45-&<MPHHI0I(ST'J:9(EMXRW I<@?='/J:;U.30 [*
    M?W6_[Z_^M13:* "BBB@`J>"Z>$;2-\?/RFH** +DELDX,MJ0<]4]/\__`*JJ
    MR\2O_O&A':-MR,5/M5OSH;L;9@(Y.</V_P`_Y[T`4J4-@8/(I\UO) <../[P
    MZ5'0!-&/D.#D`TZF0'[V/2I,`].#Z5)I'82BBB@H***`"BBB@"!OO'ZTEW
    MWC]:2J,1=QQ@@,/>EPIZ''L?\_X4VB@!2I7J,4E*&(Z&ERI[;?ITH ;5BH-A
    MQD<CU%3TF7 ****184444 %%%% #)?N_C40!)X%32 !>>>>@J(L2,=!Z"FC.
    M6XORK_M']*:22>3113)"BBB@`HHHH *4@CZ>HI`"BBB@`HHHH`LP791?+E
    M7S(F#VITMJKKYEJ=Z\Y'<?Y_.JE/BE:%PZ'!'ZT`.@]3ZL(\-WU_=R\9/8
    M_P"?SJ*:-HW8=>0:EFD6$1S(,]?6K%5HO\`6"K--"D%%%% B"?[XE1U)/]
    M\?2HZ1:V(&^\?K24K?>/UIHR"BBB@`HHHH`.ARLYSU&:K58I,N(Y -XP>]
    M6:JI]]?K5JD@D%%%%,1%.!\N:BSZ<5)/_#45(M;#)?N_C452R_=_&HJ:(EN%
    M%%%,D**** "BBB@!0Q'0TN W3@^A--HH`.AP:7=QAAD?J"O&1R/Y4`)111
    M0 4444 21=ZN1SC:$F&]3W/453B[U_!]#4LT2T(M\,LD1W(?SI:@MW9)!M
    M/7J/6KF%EY'RMZ>M,3(J5EG!&2@1!/]\?2HZDG^^/I4=(M;$#?>/UI5O
    MO'ZTE49!1110`4444 %6*KU8I,N J??7ZU:JJGWU^M6J$.04444$D,_\-15+
    M/_#45(M;#)?N_C452R_=_&HJ:(EN%%%%,D**** "BBB@`HHHH * 2#D'!HHH
    M`=\K=?E/Z4T@@\BBE#8&, CT- "44[;G[G/MWIM $LD@D G\E"M@C:>GI4
    ML/$2X]!3A(A.,_I29:>A%$K"0$@_E4],\U/7]*/-3U_2@'=DZR C;(,CUI'C
    M\CD5#YJ>OZ4Y+A4/#<>F!69%,I+C )XJ/8W]T_E5T&.8$QGYAU%1,ZJQ5C
    M@CVH&F46C?<?D;KZ4GEO_<;\JMF>/)^;]#2>?'_>_0TR"KY;_P!QORH\M_[C
    M?E5KSX_[WZ&CSX_[WZ&@"KY;_P!QORH\M_[C?E5KSX_[WZ&CSX_[WZ&@"KY;
    M_P!QORJ?8W]T_E3_`#X_[WZ&I/-3U_2DRHLA56WCY3U]LTSS4]?TH\U/7]
    M!N['T4SS4]?TH\U/7]!6&S G;@$U%L;^Z?RJ?S4]?TH\U/7]"DV5958)DJ
    M>OI4-:)PR^H-9U,AN["BBB@04444`%%%% !1110`4444`%%%% !3LAOO=?44
    MVB@#0B&(U^@JO4\1Q&OT%5-Q;[IP?3_"DRD[$K?>/OS25&SMA>>M&]O6
    MBP<R)JAWMZT;V]:+!S(OC[B_2LZK\9)C7/HH4S-A1110`4444`%%%%`!11
    M10`4444`%%%%`!112X]:`L?^K7Z"J-7D_U:\]A5/88_*@=AP.8_FYP>OI_
    MG%-*\9'(_E3E.01QTIN3GC'Y4@L)13\AN `#].O?\XI#D'&!5 6&T4N>PQ
    M5&>PQ5,"4J.R,&4X(Z&C/88_C/88_@%M98KH;)\)(!Q)_G_/TI&LIE
    M5U5=WS#!R.1S57/88_K]R[)9P%&\#H<=J WVX_YY_P#CP_QH^Q7'_//_
    M`,>'^-,,TW:9S_P(T>?-_P`]7_[Z- ALD;Q-M=<&FU;U/_CX7_<'\S52@ HH
    MHH **** "BBB@"]'_JU^@JC5Z/\`U:_051H`***`"BBB@`HHHH`*=\K=?E
    M/KVI"I'44 )1110`4444`/UHP>@I*!WT?$:Y]!5V%78P/7@=!5)]30
    M&@J?? '?@TGL,GU-Y.
    G!YI!H)["E!QQU%)D^IHR?4T!H+@$?*?KFD]A1
    MN/J:7=GAB0?6@- 5F'RHQ'T-.,DG_/1OSIC9'4Y!]Z2F%QYE?^^WYU[F$\VY00`,<U!3)"BBB@`H
    MHHH`***`+T?^K7Z"J-7H_\`5K]!5&@`HHHH`*** "BBB@`I0Q'0TE*B%VV
    MKUH`7Y3_`+)_3_/YTT@@\U.UOMCSN^8#)]*A#$#'4>AH`2BG85NG!]#T_P`_
    MYS32"#R`"BBB@"]'_JU^@JEM/H:NQ_ZM?H@7[H^E(:5R':WH?RISJ3M.#R
    M/_K5+2_P?0T7Y2OM;T/Y4;6]#^53T47#E(-K>A_C:WH?RJ>BBX<I"-P[''
    M<>MLW= 0?2I:*ARE<@CJ"*?_RQ(]Q_6G2GH&Y]_2FD''R\KQF@5K#?84>P
    MH]A1["F(&ZT;6]#^5#=:GI#2NR#:WH?RHVMZ'\JGHHN/E(-K>A_*C:WH?RJ>
    MBBX<I!M;T/Y4;6]#^53T47#E)X_]6OT%4*T1]Q?I6=3(84444 %%%% !1110
    M`J(7;:O6KL:+$O'XFB-%B7C\35::;>=J_=_G0!9D_P!6WT-4:O2?ZMOH:HT`
    M%*&(&.H]#244`.P#]TX]C_C32"#@C!HI0Q P>1Z&@"['_JU^@I!!@#YOTJ!)
    MF"X3!QV:I1,!D#-(J-@[R/]K]40\$;OTI8G+YSCBI!W9#Y'UE'D?[7
    MZ5-10%V01_M?I1Y'UE344!=D/D?[7Z4>1_M?I4U122%&P,=* NQCV['S
    M_I3?L_</C\*)AQC`6F?:'SP%H$QYMP1][![X'6D^RX'W\?A3?MYX"TOVE\
    M]%- A?LV>=_Z5+Y'UE1&=_X0I[XJ3SF]!04KW=A?(_VOTH\C_:_2D\YO05
    M,IRH/J!NZ(O(_VOTH\C_:_2IJ!79#Y'UE'D?[7Z5([%4)%1><WH*!J[)
    M<84#TK.JS+,SC SW%5J9#"BBB@04444`%%%% $LTV\[5[_`#J*BB@"])_J
    MV^AJC5Z3_5M]#5&@`HHHH **** "K"GY1GGBJ]3K]T?2DRXD\&/FQ4M0P?Q5
    M-0#W"BBBA""BBB@`J"?[XE3U!/]\?2AC6Y7E[4P@]*?+VIA]!Z4 ]P]A1[
    M"CV%'L9('@\58SGKU]:KMUJ>DRX[L",593[B_2JP.M)]P?2D@D+1113)&2
    M_P"K-5ZL2_ZLU7H941DOW?QJI9?N_C45")EN%%%%,D*** "BBB@ HHHH O
    M2?ZMOH:HU>D_U;?0U1H`****`"BBB@`J=?NCZ5!4Z_='TI,N)-!_%4U0P?Q5
    M-0#W#M1110(**** "H)_OCZ5/4$_WQ]!K<KR]J8?0>E/E[4P^@] >X>PH]
    MA1["CV%,D&ZU/4#=:GI,N.["K*?<7Z56JRGW%E""0ZBBB@D;+CRSFJ_RA_
    M.IY?]6:KTF5$;(5V]#U]?_K5'E/[K?\`?7_UJ?+]W\:BIHF6X[*?W6_[Z_\`
    MK493^ZW_`'U_]:FT4R1V$_O-_P!\_P#UZ,)_>;_OG_Z]-HH`=A/[S?\`?/\`
    M]>BFT4 %%%% %Z3_`%;?0U1J])_JVAJC0`4444`%%%%`!4Z_='TJ"IUZ/I
    M29<1RL5Z'%+YK^OZ4V@#)I%DBR-QD]>!3?-?U_2DSSD=NE###''2@5A?-?U_
    M2CS7]?TIM% 6'B5_7/X4C$N<YR?2FT4!8CE[4P^@]*DE(.-W/OWIC ]N1ZTR
    M6)["CV%'L/84R0;K4]0-UJ>DRX[L<)' P#3:10[S7]?TH\U_7];10*PX
    MR,PP3Q3:**!C)?N_C452R_=_&HJ:,Y;A1113)"BBB@`HHHH`N>1'_=_4T>1'
    M_=_4U5\Q_P"WYT>8_\`?;\Z`+Q ((/0U'Y$?]W]357S'_OM='F/_?;\Z +
    M7D1_W?U-1SPHJ;EX(_6H?,?^WYTA9F\2?J: $HHHH`G7[H^E05.OW1]3
    MB2G@8[F@#N>@I"<G-(L*5NQ]124O\`"/8T`)1110`4444`1R]J;D@\>E.E
    M[4P@]9#W%X/ X/Z&D((./84H;'J*"1&ZU/4++GE3GCIWJ:@N.["BBBD4
    M%%%%`!1110`R7[OXU%4LOW?QJ*FC.6X4444R0HHHH **** "BBB@`HHHH **
    M** "BBB@`HZG`HIR_*-WX#ZT`(W "C\?<TE%% !3EY1A^/\`G\Z;3H_O@>O%
    M`#:*** "BBB@`I3VQW%)2CD8% T'L/84>PH_EWH`#P>7(;[W7U_P`::>3F
    MB@&01]/44E&(Z&EP&Z<'T/2@0VBCH<&B@`HHHH`**** "BBB@`HHHH`***
    M* "BBB@`HHHH`**** "BBB@``R05CD\=!P7[J^Y_E_]?\`SUIM`!1110`4
    M`D$$=1110 K@!R!TSQ24Y_X3ZC_ZW];0 4444 %%%% "]N0^E%% [A1110
    M(**** %W<8;D?K1MXRO(_6DHZ'(H`*=D-UX/J.E(5(ZB@!*** "BBB@ HH
    MHH **** "BBB@ HHHH **** "E49)ST')I*EYG:67_
    M965E965E965E965E965E965E965E967_P `1" (<`:0#`2(``A$!`Q$!_\0`
    MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W^/GZ_]H`# ,!``(1`Q$`/P# HHHKG/9"
    MBBB@`HHHH **** "BBB@`HHHH **** "BBB@`K"N//F7_?/\ZW:PKC_`(9
    M?]\_SJX')BMD1U);_P#'S%_OC=1U);_`/'S%_OC=:,XX[HW:***P/7"BBB
    M@ HHHH **** "BBB@ HHHH **** "BBB@ HHI0"Q``))X %("6?CRT_NH.?K
    M\W]:AJ6Y(-Q(5(*[B!CICM45);"6P44450S&U#_C\D_#0JO5C4//R3\/Y"
    MJ];K8\FI\;]0HHHID!1110`4444`%36;K'=PO(<('&__`'>_Z9J&BDU=6 =(
    MC12-&XPR$J1Z$45-?\W;/WD"R'ZLH8_J:*$[JX&S1116![(4444`%%%%`!11
    M10`4444`%%%%`!1110`4444`%85Q_P`?,O\`OG^=;M85Q_Q\R_[Y_G5P.3%;
    M(CJ2W_X^8O\`?'\ZCJ2W_P"/F+_?'\ZT9QQW1NT445@>N%%%% !1110`4444
    M`%%%% !1110`4444`%%%% !4UMQ.K?W,O]<#/]*AJ:'B.9NGR8!]R1_3/ZU+
    MV$]B&BBBJ&%%%% &-J'_`!2?A_(57JQJ'_'Y)'\A5>MUL>34-H4444R
    MHHHH`**** "BBB@#4MM-FU.TA>!HU$0,;;R1SN+<8'HPHJK:ZC=V<9CMY=BD
    M[B-H//XBBL&JM_=:L/0UZ*CT0_\]H_^A1]HA_Y[1_]]"E8];F7<DHJ/[1#
    M_P`]H_\`OH4?:(?>T?_`'T!SN245']HA_P">T?\`WT/M$/_`#VC_P"
    MA18.9=R2BH_M$/\`SVC_`.^A1]HA_P">T?\`WT*!SN245']HA_Y[1_]]"C
    M[1#_`,]H_P#OH46#F7<DHJ/[1#_SVC_[Z%'VB'_GM'_WT*!SN245']HA_Y
    M[1_]]"C[1#_SVC_[Z%%@YEW)**CT0_\]H_^A1]HA_Y[1_]]"BP<R[DE85Q
    M_P`?,O\`OG^=;/VB'_GM'_WT*QIR#<2$'(+'!'UK2!RXIII6(ZDM_P#CYB_W
    MQ_.HZD@(%Q&2< ,,D_6M&<<=T;M%1_:(?>T?_?0HT0_P#/:/\`[Z%<]CUN
    M9=R2BH_M$/\`SVC_`.^A1]HA_P">T?\`WT*!SN245']HA_Y[1_]]"C[1#_
    M`,]H_P#OH46#F7<DHJ/[1#_SVC_[Z%'VB'_GM'_WT*!SN245']HA_Y[1_]
    M]"C[1#_SVC_[Z%%@YEW)**CT0_\]H_A1]HA_Y[1_]]"BP<R[DE%1_:(?
    M>T?_`'T/M$/_/:/_OH46#F7<DHJ/[1#_P`]H_\`OH4?:(?^>T?_`'T!S
    MN25-]VT_WW_+`_\`LOTJK]HA_P">T?\`WTFFGA6.%3@.S)&X=R>?RQ^&*3
    M0.2[C:*CT0_\]H_A1]HA_Y[1_]]"G8.9=R2BH_M$/_/:/_OH4?:(?>T?
    M_?0HL',NYE:A_P`?DGX?R%5ZGOF5KMV4@@XY!]J@K=;'EU/C84444R HHHH`
    M****`"BBB@`HHHH`TO[!U/\`Y]O_`"(O-']@ZG_`,W_D1?\:[6B@#BO[!U
    M/_GV_P#(B_XT?V#J?_/M_P"1%_QKM:* .*_L'4_?;_R(O\`C1_8.I_\W_D
    M1?\`&NUHH XKP=3_P"?;_R(O-']@ZG_P`^W_D1?\:[6B@#BO[!U/\`Y]O_
    M`"(O-']@ZG_`,W_D1?\:[6B@#BO[!U/_GV_P#(B_XT?V#J?_/M_P"1%_QK
    MM:* .*_L'4_?;_R(O\`C1_8.I_\W_D1?\`&NUHH XKP=3_P"?;_R(O-'
    M]@ZG_P`W_D1?\:[6B@#BO[!U/\`Y]O_`"(O-']@ZG_`,^W_D1?\:[6B@#B
    MO[!U/_GV_P#(B_XT?V#J?_/M_P"1%_QKM:* .*_L'4_^?;_R(O\`C1_8.I_\
    MW_D1?\`&NUHH XKP=3_P"?;_R(O-']@ZG_P`W_D1?\:[6B@#BO[!U/\`
    MY]O_`"(O-']@ZG_`,W_D1?\:[6B@#BO[!U/_GV_P#(B_XT?V#J?_/M_P"1
    M%_QKM:* .*_L'4_?;_R(O\`C1_8.I_\W_D1?\`&NUHH XK^P=3_P"?;_R(
    MO-']@ZG_P`W_D1?\:[6B@#BO[!U/\`Y]O_`"(O-']@ZG_`,W_D1?\:[6
    MB@#BO[!U/_GV_P#(B_XT?V#J?_/M_P"1%_QKM:* .*_L'4_^?;_R(O\`C4UY
    MHFHO<MMM\JH"`[UY"@#/7OC-=@GWUSTSS2=>M3U XKP=3_Y]O\`R(O-']@
    MZG_S[?\`D1?\:[6BJ XKP=3_P"?;_R(O-']@ZG_P`^W_D1?\:[6B@#BO[!
    MU/\`Y]O_`"(O-']@ZG_`,W_D1?\:[6B@#BO[!U/_GV_P#(B_XT?V#J?_/M
    M_P"1%_QKM:* .*_L'4_?;_R(O\`C1_8.I_\W_D1?\`&NUHH XK^P=3_P"?
    M;_R(O^-4)H9+>9HID*.IP0:]$K!\5PQ_8XI]@\T2!-W?&"<?I0!RU%%2Q0-(
    MN\D1Q X,C9VY]..I]A0W8"BK'FV\?RI`LP_OR[@3"MQO]*F_D!I?\)/>
    M_P#/*W_[Y;_&C_A)[W_GE;_]\M_C6+15`;7_``D][_SRM_\`OEO\:/\`A)[W
    M_GE;_P#?+?XUBT4`;7_"3WO_`#RM_P#OEO\`&C_A)[W_`)Y6_P#WRW^-8M%
    M&U_PD][_`,\K?_OEO\:/$GO?>5O_WRW-8M% &U_PD][_SRM_^6_QH_X2
    M>]_YY6__`'RW-8M% &U_P`)/>_
    K?_`+Y;_&C_`(2>]_YY6_\`WRW
    -8M%
    M`&U_PD][_P`\K?\`[Y;_`!H_X2>]_P">5O\`]\M_C6+10!M?\)/>_P#/*W_[
    MY;_&C_A)[W_GE;_]\M_C6+10!M?\)/>_
    K?_OEO\:/$GO?>5O_P!\M_C6
    M10!M?\`"3WO_/*W_P"6_QH_P"$GO?>5O_`-\M_C610!M?\)/>_\`/*W_
    M`.6_P`:/$GO?\`GE;_`/?+?XUBT4 ;7_"3WO\`SRM_^^6_QH_X2>]_YY6_
    M_??XUBT4 ;7_"3WO_/*W_[Y;_&C_A)[W_GE;_\`??XUBT4`;7_``D][_SR
    MM_\`OEO\:/\`A)[W_GE;_P#?+?XUBT4`;7_"3WO_`#RM_P#OEO\`&C_A)[W_
    M`)Y6_P#WRW-8M% &U_PD][_`,\K?_OEO\:/$GO?>5O_WRW-8M% &U_PD
    M][_SRM_^6_QH_X2>]_YY6__`'RW-8M% &U_P`)/>_
    K?_`+Y;_&C_`(2>
    M]_YY6_\`WRW-8M%`'00>)+QEF<QP8CCW8"GG)"OOG\*A_X2>]_YY6__?+?
    MXUFI\NGRGH7D50?4`$D?GM_2J]2MV!M?\)/>_P#/*W_[Y;_&C_A)[W_GE;_]
    M\M_C615`;7_``D][_SRM_\`OEO\:/\`A)[W_GE;_P#??XUBT4`;7_"3WO_
    M`#RM_P#OEO\`&C_A)[W_`)Y6_P#WRW-8M% &U_PD][_`,\K?_OEO\:/$GO
    M?>5O_WRW-8M% &U_PD][_SRM_^6_QH_X2>]_YY6__`'RW-8M% 'H]8WB
    M>-Y;")(T9V,PPJC)/RM6T%XR3@5B^W(TM%7J90#SUX/6E?L!S.V*W_`-9M
    MFD_N`Y0?5@>?H/SZBHI97F;<Y' P````/8#@4RBA( HHHI@%%%% !1110 44
    M44 %%%% !1110 4444 %%%% !113D1I&"HI9CT &30`VBIOLES_S[R_]\&HF
    M!5BK`@@X(/:E=,2:8E%%%,84444`%%%%`!1110`4444`%%%%`!1110`4444`
    M%%%%`%B;Y;.V3KNW29^IVX_\<_6J]6+3'8 H
    MHHJ@"BBB@ HHHH ***L>0L'-UN#?
    1P_P!3D<?S]L'-)NP$443S-M0#@9))
    M``'N3PEW16_KVS2?WR,H/HI'/U/Y=#3)9VD78`(X@<B-<[<O/4^YJE:^
    MX'HY))R3DUB>*_\`D&Q_]=A_)JVZQ/%?_(-C_P"NP_DU4!R=%%% !1110 44
    M44 %%%% !1110 4444 %%%% !1110 5;VTMS($B4GGD]A]:6W>YG6)`>3R
    M<=!ZUT]O!';1".(84?F3ZFLJE3E]3&K5Y-%N5+72;>#F0><_JPX_KZ@H50
    M``,`#M39)$BC:21@JJ,DFLR?6T5BL,188X9CCGZ>E<]I3.6TZC[FK2.BR*5=
    M0RGJ",BL+V[GY%1_QJW!K<3MB:,Q#L0=PINE)#=&:U%NM'BERT!\I_3$
    M_P"'^>Q)8I(72H4;T-=:I#*&4@@C((UNX-5"JUHRJ=9Q
    MTD<M13I(WBD:.12K*<$&FUU':%%%% !1110`4444`%%%% !1110`4444`%26
    M\7GW$46=OF.%SC.,G%1U8L>)F?ILC=MW]T[3@W.,>*3T0$=QY]Q+C;YC
    MEL9SC)S4=%%-: %%%% !113HXWE<)&C.QZ*HR30`VI8H&D7>2(X@<&1L[<^G
    M'4PIVW_UFV:3X#E!]6!Y@_/JBEE>9MSD09-^XCG&1QG'%<U7:_\RU_V
    MY_\`LE '%4444 %%%% !1110`4444 %%%.1&D=4499C@#WH`W]'MO(M-[??E
    M;\.W?>KLDB11M)(P55&233E 50J@``8 ':LK7IBL<<L,,2S#//'3\/\X
    ME[\CSU>I/U,R\NY+N7>_"C[J]@KT45V)6T1WI)R"BBBF,N:=?-:2@$YB8_
    M,#V]ZZ12&4,I!!&01WKCZZ'19C+9[68$QMM'/..W^?:N>M#[1RXB"MS(AURV
    MW1K<U3Y6^G;]?YUB5U=U'YMK&%#%D(`/KVKE*JB[QL5AY7C;L%%%%;'0%%
    M%% !1110`4444 %%%% !1110`58A^6SN7Z[ML>/J=V?_`!S]:KU8?Y=/B'0O
    M(S$>H `!_/=M2P*]%%%4 44*)YFVH!P,DD@ #W)X%2[HK?_5[9I/[Y&4'T
    M4CGZG\NAI-@-C@&P23/Y<9Z8P6;ZG]>G![\423C88X4\N,]<X-]6Q^G3@=
    M^:CDD>5R\CL['JS')--HMW ***8!1110 4444 >CUB>_\`D&Q_]=A_)JVZ
    MQ/%?_(-C_P"NP_DU`')T444`%%%%`&U_PC%[_P`];?\`[Z;_``K>GB:#09(6
    M(+1VI4D=,A<5@_\`"3WO_/*W_P"^6_QK>GE:?09)F #26I8@=,E<T </1110
    M`4444 %%%% !1110`5-9_P#'[!_UT7=0TJDJP9200<@CM2>PFKHZL'7O\`
    MC]3_`*YC^9K=1UD174Y5AD'VK-UV%GMTE'2,\CV..?\`/K7)2=I'#1=IZF%1
    M1178=X4444 %;'A__EX_X#_6L>NCTB%H;%2W60[\>@/2LJSM$QKNT+%VN/KJ
    MKV3RK.9]Q4A"`1ZG@?K7*U%!:-F>&6C84445T'4%%%% !1110 4444 %%%%
    M!1110 58O/E\B+Y$O/KN?_`-FQ^%0*K.P5068G``')-6[F$S74SJRK;HY1
    M93G;@<,CKQCU/?WJ6]0=6/(6#FZW!O>(X?ZG(X_G[8.://6#BUW!O>QX
    M?Z#!X_G[X.*KT:L"66=I%V ".('(C7.W/KSU/N:BHHJDK %%%% !1110`444
    M4 %%%% 'H]8GBO\`Y!L?_78?R:MNL3Q7_P`@V/\`Z[#^34 ;;F%C
    ?3/=?_K?X5I,`RE6`((P0>]<E#*T,JR(<,IR
    MZ:SNX[N>G##[R]P:Y:L.Z.M3Y7S(PK_3Y1R5!>LV.GL:IUV# ,I5@"
    M",$'O5"?1[:5BR;HR1T7IGZ54*W\Q<,0K6D<]16Q_87_`$\_^.?_`%ZMP:3:
    MPMNF0]M_('X5;K11HZ\%L9NF:<\TBRS5B4@@$??_\`K5OT54U"^2SCP,-*
    MP^5?ZGVKGE)U&<LI2JR6N77W;9#_M/C]!_7\JQZ5B68LQ)).23WIZXQY58
    M[81Y(V"BBBJ++%O9R7"%T*@`XY-2_P!F3?WH_P`S_A5C2_\`CV;_`'S_`"%7
    M*R<FF=U.A"44V9?]F3?WH_S/%']F3?WH_S/%:E%+G9?U:!E_V9-_>C_,_X
    M4?V9-_>C_,_X5J44<[#ZM R_[,F_O1_F?\*/[,F_O1_F?\*U**.=A]6@9?\`
    M9DW]Z/\`,_X4JZ5<.P5"C,>PR?Z5KK&-H>1MJ'IW)^@H:0;2D:[4/7N3]32]
    MH^@OJ\"G9:8;>X221TDDCRX13\O SU'?C]>_2JTMC<S-N=XN!@`<`#V &!6O
    M#PDK]"$P#[DX_EFH:2D[W']7@9?]F3?WH_S/%']F3?WH_S/%:E%5SL/JT#
    M+_LR;]'9_PJE70USU7%MG/7IQA:P44459S!1110 4444 %%%% 'H]8GBO_
    M`)!L?_78?R:MNL3Q7_R#8_\`KL/Y-0!R=%%%`!1110`45T?_``BG_3[_`.0O
    M_KU!>>&Y;>!IH[A)%12S!E*G`&>.N: ,.BBB@ HHHH **** "BBB@ HHHH *
    M='(\4BR1L593D$4VB@#;M=:1OEN5V'\O(_+K6A'=02E1',C%AD`-S5QSRP\7MH=A4,EY;1!M\Z`J<$`Y/Y5RM%2J"ZLE89=6;%UK75;5?^!M_0
    M?YE9#$LQ9B22<DGO245M&*CL;QA&&P4445184444 :NE_\`'LW^?Y"KE4]
    M+_X]F_WS_(5<K"6YZE'X$%%%%(U"BBB@`J2)UC?<R!AZ?_KR*CHI;@2RJQ/F
    M%S(#_$3S^/I_]:HJ<CLARN/0@C(/X5)Y8EYA!W=X\?R]?\]>M+86P?=M/]]_
    MRP/_`+]AJ:7Y8H4Z?6(]R?\ AH0(***H85SU=#7/5I3.%]`HHHK0XP
    MHHHH`**** "BBB@#T>L3Q7_R#8_^NP_DU;=8GBO_`)!L?_78?R:@#DZ*** "
    MBBB@#OPWV.U9[JY+A1EI' 'Y`#_$\USNK>(&N \%H-L1RK.1RXQCIV'Z_2LV
    M_P!2N=0?,[X48Q&O"C\/6JE !1110 4444 %%%% !1110 4444 %%%% !111
    M0 4444 %%%% !1110 4444 %%6>SDN$H5 !QR:E_LR;]'9_PI<R-%2FU
    M=(I45=_LR;]'9_PH_LR;]'9_PI<R'[&?8I45=_LR;]'9_PH_LR;^]'
    M9_PHYD'L9]BE15WS)O[T?YG_"C^S)O[T?YG_"CF0>QGV*5%7?[,F_O1_F?
    M\*DM=+D:ZB$A0Q[AO&3]WO\`I0YI![&?8;>M'-=R12D))&=GG$L=Y48);KUQ
    MV_'/44I$:-RCC!%79"XED:1WC.2Q.>I/X5)'9S;!%,5DB'1=Y!7Z'!Q[^O
    MY8E-10>QGV,RBM"32)E&Y)(VC)X;//XCL:9_9DW]Z/\`,_X57,A>QGV*5%7?
    M[,F_O1_F?\*I4TTR90E'=!1113)"BBB@`HHHH **** /1ZQ/%?\`R#8_^NP_
    MDU;=8GBO_D&Q_P#78?R:@#DZ*** "BBB@ HHHH **** "BBB@ HHHH ****
    M"BBB@ HHHH **** "BBB@ HHHH **** "BBB@#5TO_CV;_?/\A5RJ>E_\>S?
    M[Y_D*N5A+<]2C\""BBBD:A1110`444Y&53\R!@??'Y4@&U-!QYC_`-U#Q]?E
    M_K1Y:/\`ZN0`_P!U#?3^5+M:*"3KI]RR_ZPA7_`+_//U_Q_P#U
    MUS4B-&Y1Q@BM;./%=!M%%%:G&%%%% !1110`4444 >CUB>_P#D&Q_]=A_)
    MJVZQ/%?_`"#8_P#KL/Y-0!R=%%% !1110!T?_"*?]/O_`)"_^O4%YX;EMX&F
    MCN$D5%,&4J<`9XZYJK_`&]J?_/S_P"0U_PIDFM:A$\;W&4<%6&Q>0?PH H
    M4444`%%%% !1110`4444`%%%% !1110`4444`%%%% !1110`4444`%%%% &K
    MI?\`Q[-_OG^0JY7/45#A=G5#$\L4K'0T5SU%+V97UOR.AHKGJ/9A];\CH:
    MYZBCV8?6_(Z&K)E:.WA3AE.6PW(ZXQ^AY]ZY6K%[\LJ1C@1QJN/0XRP_[Z)J
    M73NT@>OT-_]R_3,3>__P"(_6FO$Z#<0"O3<I!&?3(KFJ?%+)"VZ-BI(P?0
    MCT(:\C>HK&\Z&7_7PX;_%A?S7H?PQ1]D9;=EF!Z!3A_IMZ_E
    MD>]E[C^M>1LUB1S_((I@TD0ZNP5AYQ[OY8AHJU"QA5J^TMH2RPE%\Q&#
    MQ$X##J/8CL>OY'&:BI\4KPMN0CD8((!!'N#P:E\E;CFV#>9U,.,_]\^O\Q[X
    M)IWMN8E>BBBJ`**** "BBB@#T>L3Q7_R#8_^NP_DU;=8GBO_`)!L?_78?R:@
    M#DZ*** "BBB@`HKTWGCN8A)%N'H64KGZ9'2J6N/:)8O]I$9D9&6+S?[Y_DN5FYM,[:>'C*
    M;,;[#<_
    _\`QX4?8;G_`)Y_/"MFBESLOZK#NS&PW/_//_`,>%'V&Y_P">
    M?_CPK9HHYV'U6'=F-]AN?>?_CPHPW/_//_`,>%;-%'.P^JP[LRH--N)9XX
    MRNT.P4MD'&3]:BVN9[B67R=OF.6QN!QDYK;MN)=_P#<4L#Z$#C]<5#4\[N
    MZM#NS&PW/\`SS_\>%'V&Y_YY_\`CPK9HJN=CJP[LQOL-S_`,\__'A1]AN?
    M>?_`(\*V:*.=A]5AW9G;+MB!9@>I8@/\`7=U_/(]JK^3#_J)L-_<EPOY
    M-T/XXK9KGJ<=3GKTE3M8?#"VV6-XV(SAE(.*94L5Q)$NSAHR<F-AE3_@?<
    M<T__`$:;_IW?\63I'Z_A57:W.<-Z7'$Q6.3_GKS\W]C/Y@?7.:6.?Y!%,&DB'1=V"OT/./?U_+ O("&BI982
    MB8C!XB<!AU'L1V/7\CC-152=P"BBB@#T>L3Q7_R#8_NP_DU;=8GBO_`)!L
    M?_78?R:@#DZ*** "BBB@#J=4\11Q!HK+$CX(,G93[>O\NG6N9FFDN)FEF<N[
    M'))IE% !1110`4444 %%%% !1110`4444 %%%% !1110`4444 %%%% !112J
    M"QP.M ;B4\1.1G;@'H6X'ZT\%8 ",,YZ''3\_P#/]6?=96/(!_F?\`/_UY
    MN:\B6YJ::C);L&QG=G@@]A5O%4],!%NQ;J7SS]!5RL97N>G24>1!BC%%%3J:
    M6B&*,444:A:(8IR!,XD)`]5YQ^%-HHU"T295,<$K=0V$!'0\Y_IT]ZAQ4P=H
    M[< <;V).?X@.G]?\BF[4D/R?(W]UFX_ _P"/YU;%9$>,4I!4D,"".H-)5#
    MM$,48HHHU"T0Q6"87'& 3Z!@3^5;U8'W?F?ECR ?YG_/_P!?2%SDQ2CI<:RE
    M3A@0?0TE2[LB7<V>0,\CWICH5QZ'H:U3.&4;:H6:6%MT4CQL1CL0<5YT
    M,O\`KX<-_?BPOYKT/X8JO10TB"W%#*K;[1TF!&-N`6/L4/7L>,CWXIGDK<<V
    MP;S.IAQG_OGU_F/?!-5ZL?:WDXN1YX]7/S#Z-U_#D>U2TP*]%:&VVONDJP3?
    MWIC][ZL.#]<#\<Y%62%MLBE21D>A'J#W'O34KZ`>B5B>*_^0;'_P!=A_)J
    MVZQ/%?\`R#8_NP_DU4!R=%%% !1110`459_L]_Y\[C_OTW^%136
    &/.AD
    MCW=-ZD9_.@".BBB@`HHHH **** "BBB@`HHHH **** "BBB@`HHHH **** "
    MI4_=QERO<G]3452QD&-AC)7YES^OU[?E29I3W_`*_K_@C?N_,_+'D`_P`S
    M_G_ZY]WYGY8\@'9_P`__7/N_,_+'D S/\`GZY]WYGY8\@'9_S_\`70QZ
    M2R1#/F,">0,_J:43S(-S2N6/0%C^9_S_`/71(I"-_ELY/3C/XG_/_P!=1!,/
    MG:)V8] 5)_$TM"US= $\R#<TKECT!8_F?\__`%P3S(-S2N6/0%C^9_S_`/7!
    M!,/G:)V8] 5)_$T""8?.T3LQZ J3^)HT#WP$\R#<TKECT!8_F?\`/_UP3S(-
    MS2N6/0%C9_S_P#7!!,/G:)V8] 5)_$T""8?.T3LQZ J3)HT#WP$\R#<TKE
    MCT!8_F?\_P#UP3S(-S2N6/0%C9_S_\`7!!,/G:)V8] 5)_$TJV\0?)D=V/
    M`VD\^_\`G_ZYH'ODUS<21B%?.9F6)<?-US\V3]-V/P_"H!/,@W-*Y8] 6/YG
    M_/\`]>>]BD-YXC9P&Q\9&T<#Z\`?7< @F'SM$[,>@*D_B:4;6#WR:.E5
    M`MP\DJ_PC?AE].>>/;I0_G1Q<ERTJ]<;CE?=E_+U'/7UA$$P=HG9CT!4G\
    M33HTN87$RK*)>Q .1[G_`#_]<LN@>\-$\R#<TKECT!8_F?\`/_UP3S(-S2N6
    M/0%C9_S_P#7L>3YQWR1&*4YYV,5)]2.<=G'3@#K"UK<1',D+ESTXR#[Y[_
    M`.?Q+H/?&B>9!N:5RQZ L?S/^?\`Z\?W?F?ECR ?YG_/_P!>003#YVB=F/0%
    M2?Q-1_=96/(!_F?\__`%Z$[]0[\S\L>0#_,_Y_P#KN4%AM<Y95!]?7\:
    M;]WYGY8\@'9_P`__7>@V RN3NZJ/4O]?\`/(PCN0T4451@%%%%`!5JVOGA
    M3RI!YL/]QL':?49!`[]N]5:*32>X'I)"GGH/;_/%8GBN-O[+1@"5$H)(Y X-
    M;()'2LKQ&LK6,1M2XE$H("'YONMT[FIU0SC:*L>?%+Q/"H)_Y:1#:?RZ?@`/
    MK1]E,G_'M(L_PH(?\CU_#.*=XBO1115 =9_P`)/9?
    KC_`+Y7_&HKOQ%9
    MSV<T*QSAI(V4$J,9(QZUS%% !1110 4444 %%%% !1110 4444 %%%% !111
    M0 4444 %%%% !2J2IR.M)10&Q-KDL!^\_ND\'WYZ_2D($EQESV/\S_`)_^
    MO'3QX&-V0.@;D?K4V-5-/<T],!%NQ;J7SS]!5RJFFNSP,S8SO/8#LMYK&5
    M[GITG'D5@HHS1FIU-Q"BC-&:-0O$*DMA_4G'?7 S_2H\U+#]V9NZIP?J
    M0/Y$TG>PFXV(J,T9IZCO$,T9HU"\0IZR%5VD!ESG:P_SC\9FC-%@O$D\
    MKS#YW-_LG&?P]:YS[OS/RQY`/\`,_Y_OOYK'2Y5P1/E7)SYL:C=(XS8Z
    MGK5PNCDQBK:_P!?>1JFT>9GYN1D9S[^_\`G\8W<N?;TI
    3H0SL'#='#9!
    M_P`\<'FHJU7<XI2TL@HHHJC,****`"BBB@#T>L3Q7_R#8_\`KL/Y-6W6)XK_
    M`.0;'_UV'\FH`YO>EQQ,5CD_YZ\_-_O8S^8'USG(AD1HW*.,$4VIHY_D$4P:
    M2(=%W8*_0\X]_7\L3:VP#OMMP?OLLI]945S^; T4?9&;YHI(F0]"TJJ?Q!/'
    M>M%+W!FQJ/ALQ0F6R=Y-HYC;DGZ$?RKGZZC0M;\[;:7;?O.B2'+V/O_/Z]
    M4U_1E=7O;8!74%I4Z!AW(]_Y_7K8CF**** "BBB@`HHHH **** "BBB@`HHH
    MH **** "BBB@`HHHH **** "BBB@#5TO_CV;_?/\A5RL.YFA4K&^ 3GH?]
    MNN?>G_CHK-P;9VT\1&,4F;-%8WVZY_YZ?\`CHHW7/_`#T_\=%+D9?UJ'9F
    MS16-]NN?^>G_`(Z*/MUS_P`]/_'11R,/K4.S-FIH?]7/_N#_`-"6L#[=<_\`
    M/3_QT58M[VX,-T3)TB!'RC^M2X.PGB8=F:-%8WVZY_YZ?\`CHHW7/_`#T_
    M\=%5R,?UJ'9FS16-]NN?^>G_`(Z*/MUS_P`]/_'11R,/K4.S-FBL;[=<_P#/
    M3_QT4?;KG_GI_P".BCD8?6H=F;-<]5C[=<_\]/\`QT57JHQL<]>JJEK$D4\D
    M.=C8#?>4CM]0>#4GEQW'H23_GD3G<?]D_T//3DDU7HJK'.RLC%6!5@<$
    M$<@TE3K.'41W`J!A7ZL@]O4>Q_#&<TDEN0ADB;S8AU8`_[,.W\O0FB_<"&
    MBBBF`4444 >CUB>*_P#D&Q_]=A_)JVZQ/%?_`"#8_P#KL/Y-0!R=%%% !111
    M0 5VS,S^'"S$LS6F22<DG97$UVO_`#+7_;G_`.R4`<51110`4444`%%%% !1
    M110`4444`%%%% !113D1I&"HI9CT`&30`VBIOLES_P`^\O\`WP:B8%6*L""#
    M@@]J5TQ)IB4444QA4KQ (I#9;&2OM453.0CJ^<MM7:/3@<TF:02LVR&BI)5R
    M/,"A0<94=JCH3N3/[#TBD<92-F'J!FESS?
    9/
    36CI?_'LW^?Y"KE0
    MYV9TPPZE%.YA?9YO>,G_?)HSS?
    9/^^36[12YR_JJ[F%]GF_YXR?]\FC[
    M/-_SQD_[Y-;M%'.'U5=S"SS?
    9/
    35BV@F$%WZ?F(?PG^^M:M30_ZN?_
    M`'!_Z$M*4] JKN<Y]GF_P">,G_?)HSS?\`/&3_`+Y-;M%/G#ZJNYA?9YO^
    M>,G_`'R:/L\W_/&3_ODUNT4<X?55W,+[/-_SQD_[Y-'V>;_GC)_WR:W:*.</
    MJJ[F%]GF_P">,G_?)J.NAKGJN,KF%:DJ=K!1115&`4Z-VC<.AP13:* +&8KC
    MJ%AE[8&$8/RRG6HI8I(6VR5)&1Z$>H/<>],J68HOENH>(G)4]1[@]C
    MT_(9S4V:V BHJ=H%=3) P90,E"?G4?U[\CL,G%04T[@>CUB>*_\`D&Q_]=A_
    M)JVZQ/%?_(-C_P"NP_DU,#DZ*** "BBB@"WINGS:C<>7%PHY=R.%'^/M76:@
    M8;19(F?"B$Q)NZD[< ?6GL;/1[(D*(HE.<#DL3_`#-<AJ6H3:C<>9PHX1
    M>%'^/O0!4HHHH **** "BBB@`HHHH **** "I;>VEN9 D2D
    GL/K1:V[W,Z
    MQ(#R>3CH/6NGMX([:(1Q#"C\R?4UE4J<OJ8U:O)HMRI:Z3;P<R#SG]6''Y5?
    M4!5"J `!@ =J;)(D4;22,%51DDUF3ZVBL5AB+#'#,<<_3TKGM*9RVG4?<U:1
    MT612KJ&4]01D5A?VW<_W(OR/^-6X-;B=L31F(=B#N%-TI(;HS6HMUH\4N6@/
    ME/Z?PG_#_/%8DL4DE)4-Z&NM4AE#001D$=Z@O2.[BV/PP^ZW<&JA5:T9
    M5.LXZ2.6J:3"L&."=JX'X#K4<D;Q2-'(I5E."#4DF%8,<$[5P/P'6NAGHP^%
    MOT_412%.Z0D[NH[X]:C92K%3V_6G?=96/(!_F?\_\`UW2 M$'8_,#@YZD=
    MC_/]"FKKT-#2_\`CV;_`'S_`"%7IZ7_P`>S?[Y_DN5E+<[J/P(***1J%
    M%%% !4L+!(K,%WK@$]!R#_2HJ35P'O&\>-PX/0@Y!^AIE/21X\[3P>H(R#
    M]13_`-U)_P!,F_$K_B/U_"E=K<1#13G1D.&QZ@@Y!_&FTQA1113 *YZNAKGJ
    MTIG%B@4445H<84444 %%%% "JS(P9258'((/(-3;'/Q.-LA_Y;`]3ZL._U
    M&#U/)JO12:N!Z.01].QK$\5_\@V/_KL/Y-6V"1].XK(\3Q>=IT:H1O\`-&%/
    M\1P>![TKVW XBE961BK`JP."".0:2J ****`"BIY[.YMT5YX)(U;H67'KO
    M%04`%%%%`!1110`4444`%%%%`!113D1I'5%&68X`]Z -_1[;R+3>WWY?F_#M
    M_GWJ[)(D4;22,%51DDTY0%4H `&`!VKUZ8K''"K##$LPSSQT_#_"N)>_(\
    M]7J3]3,ON2[EWOPH^ZO8"J]%%=B5M$=Z22L@HHHICFG7S6DH!.8F/S`]O>
    MND4AE#*001D$=ZXNAT68RV>UF!,;;1SSCM_GVKGK0T<N(@K<R(=<MMT:W"
    M]45OIV_7=9+E1M?J2HP/IQD_E7374?FVLL84,60@`^O:N90CRCQDH<C\>/
    M\*=)WB;825XN+_KM1OW?F?ECR ?YG_/_P!=\8;#DEI!@#Z]"?QQ_GJS[OS
    M/RQY`/\`,_Y_NH)0[V.7/(_Q/\`G_ZIU)V>HL5S-"I6-\`G/04_P"W7/\`
    MST_\=%12@ZC@!B!3=DR7*<=EC[=<_P#/3_QT4?;KG_GI_P".BJ]%%D+V
    MD[+'VZY_P">G_CHHW7/_/3_P`=%5Z+(/:3[LL?;KG_GI_XZ/MUS_`,]/
    M_'15>BBR#VD[+'VZY_YZ?\`CHHW7/_`#T_\=%5Z*+(/:3[LN1ZI=H,>8&3
    M.2C"#_GU'-2?;&F_P!7-Y`-QP"I^C8X'\36?12Y$'M)]RW<WD+;9&D
    MC(48(]0>X]Z9]NN?>G_CHID4[1KL($D1.3&V=N?7CH?<4_RH9O]1)L;_GG
    M0/R;I>/QI:+=![2?=A]NN?>G_`(ZKTZ2-XG*2(R,.JL,$4VJ5N@G)RW8
    M4444R0HHHH **** "BBB@#T>L3Q7_P`@V/\`Z[#35MUB>*_0;'_P!=A_)J
    M`.:6=741SJ&4# <#YU']>W![# Q3982B8C!XB<!AU'L1V/7\CC-14*62%M
    MT;%21@A'H1W'M2M;8!E%6/-MF:2"3>>OER!5_ ;3BBE=]@.PM+JUUBR8%0
    M01B2)NJG_/0US&KZ5)ITV1EX&/R/_0^_\ZJV=W-97"S0-AAU'8CT/M78W;K=
    M:%+*R#$EN7VGG!VY'Y50'#T444 %%%% !1110 4444 %36?_`!^P?]=%_G4-
    MIL&4D$'(([4GL)JZ.OK!U[_C]3_KF/YFMU'61%=3E6&0?:LW786>W24=(S
    MR/8XY_SZUR4G:1PT7:>IA4445V'>%%%%`!6QX?\`^7C_`(#_`%K'KH](A:&Q
    M4MUD._'H#TKL[1,:[M"Q=KD4<HX88..QKJ+V3RK.9]Q4A" 1ZG@?K7U%!:
    M,C"W5VB4`'<ZAF/7!YQ[GU_S^?N_,_'D S/\`GZ[`2#D'!%2"4YRRHWU
    M'^<UM8[E)/<2?_7R?[Q_G35V+N6/4G-)36Q$G>384444R0HHHH`***`"BB
    MB@`HHHH`****`)H[EU01N%EC'1'Y`G<?@1FG>0DW-LW/_/)V;\#@`_3K[=
    MZKT4K=@%961BK JP."".0:2IUN6*A)U$R 8&[[RCV/4?3D>U+]G6;FU9G;_G
    MD1\_X8Z_S]L4KVW KT4450!1110`4444`>CUB>*_^0;'_P!=A_)JVZQ/%?\`
    MR#8_^NP_DU ')T444 %%%% !7:_\RU_VY_\`LE<57;,K)X<*L"K+:8((P0=E
    M`'$T444`%%%%`!1110`4444`%%%%`&]HMUYMN86/SQ],]U_^M_A6DP#*58 @
    MC!![UR4,K0RK(APRG(KIK.[CNXMZ<,/O+W!KEJPL[HXJU/E?,C"O]/DM')4%
    MXNS8Z>QJG78,`RE6`((P0>]4)]'MI6+)NC)'1>F?I50K?S%PQ"M:1SU%;']A
    M?]//_CG_`->K<&DVL+;BID/;?R!^%6ZT4:.O!;&;IFG/-(LLRE8E((!'W_\`
    MZU;]%5-0ODLX\##2L/E7I]JYY2=1G+*4JLBEKEU]VV0_P"T/T']?RK'I6)
    M9BS$DDY)/>DKKC'E5CMA'DC8***HL*** "BBB@`HHHH **** "BBB@`HHH
    MH **** "BBB@`HHHH L?:O,XND\[_;SA_P#OKO\`CGVQ1]E\SFU?SO\`8QA_
    M^^>_X9]\57HJ;6V **L?:%FXNE9V_P">H/S_`(YZ_P`_?%(ULQ4O`PF0#)V_
    M>4>XZCZ\CWIW[@04444P/1ZQ/%?_`"#8_P#KL/Y-6W6)XK_Y!L?_`%V'\FH`
    MY.BBB@`HHHH`ZG1-#-NPN;Q1YH/R1YR%]S[_`.?I)JFJQEY;"'#DQ2>8W9<(
    M3@>_'^>U;Q.986C%L\>X8W)-@CZ?+5"R>S\]ML$X/E2=9@>-C9_AH SJL[
    M[GWN/^P"O_P`11OLO?>X_P"_Z_\`Q% %:BK.R_Y][C_`_K_P#$57;:
    M6.T$G@$Y(% "4444 %%%% !1110`4Z.1XI%DC8JRG((IM% &W:ZTC?<KL/
    M]Y>1^76M".Z@E*B.9&#( ;G\JY2BL71B]CGEAXO;0["H9RVB#;YT!4X(!R
    M?RKE:E4%U9PRZLV+K6NJVJ_P# V_H/\_2LAB68LQ)).23WI**VC%1V-XPC
    M#8***HL**`"BBB@`HHHH`**`"BBB@`HHHH`**`"BBB@`HHHH`***
    M`"BBB@`I59D8,I*L#D$'D&DHH L>>DW%RO/_`#U1?F_$9 /UZ^_:FR6SJAD0
    MK+&.KIR!]>X_$#-0TZ.1XG#QNR,.C<$5-K;`>BUB>_^0;'_P!=A_)JW,@_
    M>&/<5B>+%(TR,]1YPY'^ZU._<#DJ**8!1110 59L/\`CX;_`XR_P#HMJK5
    M9L//AON,O_`*+:@"M1110`4444`%%%% !1110`4444`%%%% !1110`4444
    M4444`%%%% !1110`4444`>CUC^)I9(=/C:-BI,H!]",'@CN/:MBL3Q7_`,@V
    M/_KL/Y-0!S>";_6Y_`-]!E3]5[?A`IDMO)$N_AHR<"13E3_@?8\U%3XI
    M7A;<A'(P00""/<'@U-FM@&458\RU;EK:0'TCEPOX9!/ZT47?8#;_`.$4_P"G
    MW_R%_P#7J6W\->3(6U[LHRX\O\`O*1Z];]%4!S?_"*?]/O_D+_`.O1_P`(
    MI_TP#D+Z]=)10!S?_``BG_3[_`.0O_KT?\(I_T_^0O\`Z]=)10!S?_"*
    M?]/O_D`.O1P`(I_T^_P#D_Z]=)10!S?_``BG_3[_`.0O_KT?\(I_T_
    M0O\`Z]=)10!S?_"*?]/O_D`.O1P`(I_T^_P#D_Z]=)10!S?_``BG_3[_
    M`.0O_KT?\(I_T_0O\`Z]=)10!S?_"*?]/O_D`.O1P`(I_T^_P#D_Z]
    M=)10!S?_``BG_3[_`.0O_KT?\(I_T_0O\`Z]=)10!S?_"*?]/O_D+_`.O1
    M_P`(I_TP#D+Z]=)10!S?_``BG_3[_`.0O_KT?\(I_T_^0O\`Z]=)10!S
    M?_"*?]/O_D`.O1P`(I_T^_P#D_Z]=)10!S?_``BG_3[_`.0O_KT?\(I_
    MT_0O\`Z]=)10!S?_"*?]/O_D`.O1P`(I_T^_P#D_Z]=)10!S?_``BG
    M_3[_`.0O_KT?\(I_T_0O\`Z]=)10!S?_"*?]/O_D+_`.O1_P`(I_T^_P#D
    MZ]=)10!S?``BG_3[_`.0O_KT?\(I_T_0O\`Z]=)10!S?_"*?]/O_D_
    M`.O1_P`(I_TP#D+Z]=)10!S?_``BG_3[_`.0O_KT?\(I_T_^0O\`Z]=)
    M10!S?_"*?]/O_D`.O1P`(I_T^_P#D_Z]=)10!S?_``BG_3[_`.0O_KT?
    M\(I_T_0O\`Z]=)10!S?_"*?]/O_D`.O1P`(I_T^_P#D_Z]=)10!S?_
    M``BG_3[_`.0O_KT?\(I_T_0O\`Z]=)10!S?_"*?]/O_D+_`.O1_P`(I_T^
    M_P#D+_Z]=)10`5B>*_\`D&Q_]=A_)JVZYWQ5=PF&.T5LRAP[`?PC!Z^_- '-
    M4444`%%%% %GT+W_G\N/_K?XT?VA>_\_EQ_P!_6_QK4^SP_P#/&/\`[Y%'
    MV>'_`)XQ_P#?(K/G.OZJYE_VA>_\_EQ_P!_6_QH_M"]_P"?RX_[M_C6I]G
    MA_YXQ_\`?(HSP_
    8_
    11SA]5?<R_[0O??RX_[M_C1_:%[_S7'_`'];
    M_&M3[/#_`,\8_P#OD4?9X?\`GC'_`-\BCG#ZJYE_P!H7O\`S7'_?UO\:/[
    M0O??RX_[M_C6I]GA_YXQ_]\BC[/#_SQC_[Y%'.'U5]SM"]Y_C_`+^M
    M_C1_:%[_`,_EQ_W];_&M3[/#_P`\8_\`OD4?9X?^>,?_`'R*.</JK[F7_:%[
    M_P`_EQ_W];_&CT+W_G\N/\`OZW-:GV>'_GC'_WR*/L\/\`SQC_`.^11SA]
    M5?<R_P"T+W_G\N/K?XT?VA>\`/Y<?]_6_QK4SP_
    8_^^11]GA_YXQ_]
    M\BCG#ZJYE_VA>_\_EQ_W];_`!H_M"]_Y_+C_OZW-:GV>'_`)XQ_P#?(H^S
    MP_\`/&/_`Y%'.'U5]S_M"]_P"?RX_[M_C1_:%[_S7'_?UO\`&M3[/#_S
    MQC_[Y%8TX N)`!@!C@#ZU497,JE%TU=LE_M"]_Y_+C_OZW^-']H7O_/Y<?\`
    M?UO\:K5)``;B,$9!89!M49)7=B7T+W_G\N/^_K?XT?VA>_\_EQ_P!_6_QK
    M4SP_P#/&/\`[Y%'V>'_`)XQ_P#?(K/G.KZJYE_VA>_\_EQ_P!_6_QH_M"]
    M_P"?RX_[M_C6I]GA_YXQ_\`?(HSP_
    8_^11SA]5?<R_[0O??RX_[^M_
    MC1_:%[_S7'_`'];_&M3[/#_`,\8_P#OD4?9X?\`GC'_`-\BCG#ZJYE_P!H
    M7O\`S7'_?UO\:/[0O??RX_[^M_C6I]GA_YXQ_]\BC[/#_SQC_[Y%'.'U5]
    MSM"]Y_C_`+M_C1_:%[_`,_EQ_W];_&M3[/#_P`\8_\`OD4?9X?>,?_
    M`'R.</JK[F7_:%[_P`_EQ_W];_&CT+W_G\N/\`OZW-:GV>'_GC'_WR/L
    M\/\`SQC_`.11SA]5?<R_P"T+W_G\N/_K?XT?VA>_\`/Y<?]_6_QK4^SP_\
    M\8_^11]GA_YXQ_]\BCG#ZJYE_VA>_\_EQ_W];_`!H_M"]_Y_+C_OZW^-:G
    MV>'_`)XQ_P#?(HSP_\`/&/_`Y%'.'U5]S_M"]_P"?RX_[M_C1_:%[_S^
    M7'_?UO\`&M3[/#_SQC_[Y%'V>'_GC'_WR*.</JK[F7_:%[_S7'_`'];_&C
    MTW_`)_C_OZW^-:GV>'_GC'_P!\BC[/#_SQC_[Y%'.'U5]SM"]Y_C_O
    MZW-']H7O_/Y<?\`?UO\:U/L\/\`SQC_`.11]GA_P">,?\`WR*.</JK[F7_
    M`&A>_P#/Y<?]_6_QH_M"]_Y_C_OZW^--OE5;MU4``8X`]J@K1:G)<K:+/]
    MH7O_`#7'_?UO\:/[0O??RX_P"_K?XU6HH$6?[0O?\`G\N/^_K?XT?VA>_\
    M_EQ_W];_`!JM10!9_M"]_P"?RX_[^M_C5=F9V+,2S,<DDY)-)10`4444`%%;
    MMGX:FGMUDGF\AFY";,D#WY&#[44`24445SGLA1110 4444 %%%% !1110 44
    M44 %%%% !1110 5A7'_'SOG^=;M85QP`?,O\`OG^=7 Y,5LB.I?_`(^8
    MO]\?SJ.I+?\`X^8O]\?SK1G''=&[1116!ZX4444`%%%%`!1110`4444`%%%%
    M`!1110`4444`%%%%`!1110`4444`8VH?\?DGX?R%5ZL:A_Q^2?A_(57K=;'D
    MU/C?J%%%%,@**** "BBB@ I58JP88R#GD9'Y4E% '1_\)7_TY?\`D7_ZU%<Y
    M10!T-%%%<Y[(4444`%%%% !1110`4444`%%%% !1110`4444`%85Q_Q\R_[Y
    M_G6[6%<?\?,O^?YU<#DQ6R(ZDM_/F+_?'\ZCJ2W_X^8O\`?'\ZT9QQW1NT
    M445@>N%%%% !1110`4444 %%%% !1110`4444 %%%% !1110`4444 %%%% &
    M-J'_`!2?A_(57JQJ'_'Y)'\A5>MUL>34-H4444R HHHH`**** "BBB@`
    MHHHH`Z&BBBN<]D**** "BBB@`HHHH **** "BBB@`HHHH **** "L*X_X^9?
    M]\_SK=K"N/\`CYE_WS_.K@<F*V1'4EO_`,?,7^/YU'4EO\`\?,7^/YUHSC
    MCNC=HHHK`]<**** "BBB@ HHHH **** "BBB@ HHHH **** "BBB@ HHHH *
    M*** ,;4/^/R3\/Y"J]6-0_X_)/P_D*KUNMCR:GQOU"BBBF0%%%% !1110 44
    M4JL58,,9!SR,C\J T>B:C(@=;5@#_>(4_D3FBM3_A*_^G_`,B__6HH`;11
    M17.>R%%%% !1110`4444`%%%% !1110`4444`%%%% !6%<?\?,O^^?YUNUA7
    M'_'S_OG^=7 Y,5LB.I?_CYB_WQ_.HZDM_^/F+_`'Q_.M&<<=T;M%%%8'KA
    M1110`4444 %%%% !1110`4444 %%%% !1110`4444 %%%% !1110!C:A_P`?
    MDGX?R%5ZL:A_Q^2?A_(57K=;'DU/C?J%%%%,@**** "BBB@`HHHH`**** .A
    MHHHKG/9"BBB@`HHHH **** "BBB@`HHHH **** "BBB@`K"N/^/F7_?/\ZW:
    MPKC_`(9?]\_SJX')BMD1U);_P#'S%_OC=1U);_`/'S%_OC^=:,XX[HW:**
    M*P/7"BBB@ HHHH **** "BBB@ HHHH **** "BBB@ HHHH **** "BBB@#&U
    M#_C\D_#0JO5C4//R3\/Y"J];K8\FI\;]0HHHID!1110 4444 %%%% !111
    M0!T-%%%<Y[(4444`%%%%`!1110`4444`%%%%`!1110`4444`%85Q_P`?,O\`
    MOG=;M85Q_Q\R_[Y_G5P.3%;(CJ2W_X8O\`?'\ZCJ2W_P"/F+_?'\ZT9QQW
    M1NT445@>N%%%% !1110`4444`%%%% !1110`4444`%%%% !1110`4444`%%%
    M% &-J'_'Y)^'\A5>K&H?\?DGX?R%5ZW6QY-3XWZA1113("BBB@`HHHH`****
    '`"BBB@#_V0``
    end
    "Pepe" <pepe@pepe.pepe> wrote:
    components.
    Pepe
    An image of a failing area and the exact error messge (and what layer it
    happened on) would help.
    Is just the area between the pads hightlighted with errors, or the pads
    themselves too?
    What exact drc settings did you tweak?
