EAGLE User Support (English) How can I move a net connection from on e pin to another?
  • Views 288 views
In the schematic editor I want to pick up a net that I've already placed
and named and drag 'n' drop it to another pin, can I do this? I know I
could just delete and re-create the net, but often if I've spent a while
laying out just where I want it I'd rather just move it.
Can I do this?
    Thank you.
    You can't move a net from a pin It would  "rubber band" staying
    connected to the pin, but you can delete just the last segment or two
    and run a net from there to the new pin.
