EAGLE User Support (English) Can I switch snap-to-grid off?
  • Views 2078 views
On occasion I would like to be able to place a track or component exactly
where I want it, even if that point is NOT on the grid. Can I do this?
At the moment my only option seems to be set a very fine grid, but I'd
prefer not to do this because it makes it harder for me to keep tracks
aligned vertically and horizontally.
The reason is as follows....
I've created a library component with 20 pins per cm, and I'm trying to
place it on a board with an identical grid setting, the problem is that I
can't get seem to align the board grid with the component grid, so the
result is that every single track is very slightly misaligned with each pad
on the component. I'm concerned that this slight misalignment may cause
issues when I come to build the board.
Regards
    On 12/10/2011 11:09 AM, Lima wrote:
    Regards
    You can set the alternate grid to be very fine but it sounds more like
    the origin of the library part is not in the right place.
