EAGLE User Support (English) How to remove bends / corners from tracks
  • Views 553 views
How can I remove bends and corners from a track when working on board
layout?
When manually routing I often find myself with tracks that bend and twist
all over the place, I want to be able to straighten them out. I've worked
out that I can manually align all the kinks into a straight line and then
right click, followed by 'optimise', but this only seems to work if I've
got each point on a track in a dead straight line. What I'm really after is
a way of deleting a corner from a track, is there any way of doing this
easily?
    Am 11.12.2011 15:28, schrieb Lima:
    easily?
    Yes. Corner deletion can be done with the DELETE command and Ctrl-click
    on the offending corner (see 'help delete').
    Andreas Weidner
